Load sensor valve op 3.0 DVD.
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Thu Jan 05, 2017 9:46 am
Het iemand dalk n foto waar die load sensor valve gestel is op n DVD 3.0 spesifiek.Hy het nuwe vere ingesit en die bakkie n bietjie gelig. Toyota weet nie waarvan hy praat toe my broer vir hulle vra die load sensor valve te steL
Town: Bellville
Vehicle: Langpad (RAV4)
Thu Jan 05, 2017 10:43 am
net langs die agter diff, tussen die as en die chassis.
soek net so bietjie op die forum, dink Pieter het laas n link geplaas na n thread waar die valve behoorlik bespreek word.
Mylux
Vehicle: 4.0L V6 Vigo 4x4
Real Name: Greg
Club VHF Licence: HC249
Thu Jan 05, 2017 12:15 pm
Hi Dawie,
Here, I hope this will help.
Cheers
Greg
The Legend
Real Name: Dawie
Thu Jan 05, 2017 1:27 pm
Thanx Greg
FIRSTGEER
Town: King WilliamsTown
Real Name: Tony Geer
Club VHF Licence: HC 109
Sun Jan 08, 2017 4:12 pm
I have also changed my syspention to OME and wish to set the load sensor.Can someone explain how one does this.
Sun Jan 08, 2017 5:46 pm
Tony, you've raised the suspension but you've also increased the load on the rear axle with you camper build. The load sensor is there to apportion more braking power to the rear as the load increases, so you could increase the proportion quite dramatically without having the rear wheels locking up - thus improving your overall braking and easing the work-load of the front brakes.
Without looking at your LSPV setup, there must be an adjustment on one of the linkages (probably the one at the axle end) ... turn it out to it's fullest or if the adjustment thread is long enough, to the same amount as what your suspension was raised by. If the thread is not long enough, you might have to "tweak" the long link arm a bit by bending it downwards a bit ( you cannot bend it too far before you run the risk of inverting the lower linkage on full extension .... best is to do this with the rear lifted and the axle hanging freely).
FIRSTGEER
Sun Jan 08, 2017 9:52 pm
Thanks Andy makes sense.I will check it out this week.I feel my front brakes are wearing much too fast.
Mon Jan 09, 2017 12:09 am
Yup, needs to be done. :winkx:
Nutydread
Vehicle: Toyota Hilux
Real Name: Jason
Tue May 23, 2017 9:41 am
Fantastic thank you for this thread I need this checked.
I'm doing a brake upgrade to improve braking, but I now believe this could quite well not be set up properly after my lift is as done.
Obelix and Dogmatix
Town: ROODEPOORT
Vehicle: HILUX 4.0 V6 4x4 named Obelix, donated to some clown, HILUX 4.0 V6 4x4 named Obelix II Onca front and rear Amade extreme Suspension and under water breathing apparatus
Real Name: Quentin
Wed May 24, 2017 6:35 pm
Guys download the manual from the club website, it explains exactly how to do it.
God made man before
woman so as to give him time
to think of an answer
for her first question
    Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot]
