Good Day
Please can someone tell me what this ( attached image) connection is for at the base of the carb?
It is between the intake manifold and carb.
Carb Connections 4Y Engine
- OFE007
- Town: Bloemfontein
- Vehicle: Toyota hilux raider 1994
Re: Carb Connections 4Y Engine
Mine is connected with a rubber hose back to the tappet cover!
Crank-case ventilation or brake booster vacuum. Johan says his is connected to the tappet cover, which is crank-case ventilation, but I'm not sure that's how it should be. maybe one of the 4Y guys like Dawie can confirm.
What makes sense to me and what is normally the case, is that crank-case ventilation is taken off before the carb, normally somewhere between the air filter element and the carb barrels, while brake booster vacuum is taken of after the carb, either off the base of the carb or the manifold itself. (This gives fairly constant vacuum to the booster and is also not a free flow of air that interferes with the air / fuel mixture ratio.)
- Club VHF Licence: X93-
Andy, my 4y is an EFI now so I can not check it but as far as I can remember it was just a rubber pipe connected to the carb with some metal breather or filter on it hanging down the engine.It is open at the end and does not connect anywhere.
- batavia
- Town: Mossel Bay
- Vehicle: Toyota
- Real Name: Christo
Presies soos Dawie sê.
Wonder nou al 10 jaar wat de hel is dit.
