Who is online |
Users browsing this forum: Google [Bot]
Congratulations to: HennieJ2 (52) on their birthday today. |
Page 1 of 1
[ 24 posts ] |
The Importance of having an operational Engine Thermostat
| Author |
Message |
Dadz Toy BFI
When we opened up my old 4Y's water pump outlet this is what we found (see photo) Just the upper part of the thermostat remained to effect the O-ring seal (the body of the thermostat was totally absent - hence the motor had no functioning thermostat) Which got me thinking: what really is the function of an engine thermostat in a temperate climate like ours Your feedback would be really appreciated guys (this is a "thought provoking" any comment - "rather than give only the correct answer" welcome thread nê) Rich
File comment: Only the top half of the Engine Thermostat was in place
| Wed Oct 22, 2008 10:17 pm |
Joined: Tue Dec 04, 2007 11:52 am Posts: 21192 Location: Rynfield
ORRA Call Sign: B15
 Re: What is the role of an engine Thermostat in our Climate
My guess would be that the engine gets to operating temperature quicker and if it's not installed you're engine will actually run cooler than supposed to...
_________________
TETA approved advanced 4x4 driver (US254135 / US254154)
| Thu Oct 23, 2008 6:27 am |
Riceburner
Joined: Wed Jul 11, 2007 12:15 pm Posts: 1175 Location: Mondeor
Town: JHB
Vehicle: D2 V8
Real Name: Darryl
Engine gets to operating temp quicker if its installed. Thermostats keep your engines temp stable. If it runs too cold it will wear prematurely. It also gives the water time to cool down in the radiator. Thermostat is very important in hot and cold climates.
| Thu Oct 23, 2008 6:52 am |
Spook
Town: Swakopmund
Vehicle: Hilux 4Y 4x4 s/cab, 3.0 D-4D
Real Name: Ockie
 Re: Do we need an Engine Thermostat in a Temperate Climate?
As jy my raad vat, vervang daai termostaat met 'n nuwe Toyota genuine een want die termostaat in die 4Y is een wat baie styf is wat veroorsaak dat die enjin baie vinnig op werkstemperatuur kom vroeg in die oggend in die veld. Verder, waarom dink jy het hulle die kar ontwerp met 'n termostaat? 'n Te koue enjin slyt vinnger as een wat op die regte temperatuur hardloop. As jou kar warm word met 'n termostaat, soek die rede daarvoor by die regte plek en maak dit reg.
| Thu Oct 23, 2008 8:48 am |
Dadz Toy BFI
Spook wrote: As jy my raad vat, vervang daai termostaat met 'n nuwe Toyota genuine een want die termostaat in die 4Y is een wat baie styf is wat veroorsaak dat die enjin baie vinnig op werkstemperatuur kom vroeg in die oggend in die veld. Verder, waarom dink jy het hulle die kar ontwerp met 'n termostaat? 'n Te koue enjin slyt vinnger as een wat op die regte temperatuur hardloop. As jou kar warm word met 'n termostaat, soek die rede daarvoor by die regte plek en maak dit reg. die translasie software can't help  - can a human please help me verstaan (Ingels) Dankie mense
| Thu Oct 23, 2008 9:18 am |
ORRA Call Sign: B15
Dadz Toy BFI wrote: Spook wrote: As jy my raad vat, vervang daai termostaat met 'n nuwe Toyota genuine een want die termostaat in die 4Y is een wat baie styf is wat veroorsaak dat die enjin baie vinnig op werkstemperatuur kom vroeg in die oggend in die veld. Verder, waarom dink jy het hulle die kar ontwerp met 'n termostaat? 'n Te koue enjin slyt vinnger as een wat op die regte temperatuur hardloop. As jou kar warm word met 'n termostaat, soek die rede daarvoor by die regte plek en maak dit reg. die translasie software can't help  - can a human please help me verstaan (Ingels) Dankie mense  I you take my advise... replace your thermostat with a new genuine Toyota one because the thermostat in the 4Y is very stiff which causes the engine to reach operating temperature very quickly early morning in the field. Further, why do you think cars were designed with a thermostat? A to cold engine wears quicker than one runnign at the correct temperature. I your car runs hot with a thermostat, find the reason in the right place and fix it.
_________________
| Thu Oct 23, 2008 9:26 am |
Dadz Toy BFI
Thanks Casie Think he was misunderstanding my predicament nê I should have added that I bought a New Genuine Toyota Thermostat for the replacement Korean, I wasn't gonna risk that, no, no, no... Thanks v.much vir die translasie mos
| Thu Oct 23, 2008 9:35 am |
ORRA Call Sign: B15
 Re: Y Do we need an Engine Thermostat in a Temperate Climate?
Pleasure Rich... I'm also like that... when it comes to spares for my bakkies engine... only genuine Toyota parts will do
_________________
| Thu Oct 23, 2008 10:49 am |
BenHur
Joined: Fri May 18, 2007 7:12 pm Posts: 7055 Location: Doornpoort
Vehicle: '96 D/C Raider
Real Name: Bennie
Ha rich glad you remembered and followed my advice.
What Darryl said is very imported let me elaborate: Apart from regulating the temp so the engine does not run too cold in cool conditions, it restricts the flow of water. Without a thermostat the speed of the water increases with the speed of the engine because the pump runs faster. Then you get to a situation where the water gets pumped through the radiator so fast that their is no time for heat exchange so the water leaves the radiator at the same temperature in arrived at the radiator and no cooling takes place.
| Thu Oct 23, 2008 12:51 pm |
Dadz Toy BFI
Aaaahaaaarr Sommer nou makes a lot of sense mos Qu: So do you think the absence of thermoset in my old motor contributed* to its demise (*In detail, 2000 words maximim, 50 Marks) Rich
| Thu Oct 23, 2008 12:58 pm |
ORRA Call Sign: B15
Dadz Toy BFI wrote: Aaaahaaaarr Sommer nou makes a lot of sense mos Qu: So do you think the absence of thermoset in my old motor contributed* to its demise (*In detail, 2000 words maximim, 50 Marks) Rich Only one word needed..... yes!
_________________
| Thu Oct 23, 2008 1:58 pm |
BenHur
Real Name: Bennie
Dadz Toy BFI wrote: Aaaahaaaarr Sommer nou makes a lot of sense mos Qu: So do you think the absence of thermoset in my old motor contributed* to its demise (*In detail, 2000 words maximim, 50 Marks) Rich OK here goes ========================================================================= Yes, for sure, most certainly, most probably, definitely, very likely, of course, undoubtedly, undeniably, unquestionably, indisputably, without a doubt, obviously, clearly, evidently, plainly, perceptibly, markedly, unmistakably, possibly , to be expected, apparent, plain as the nose on your face, or the hair on your back, as certain as death and taxes and Nissans being unreliable, as cetain as cape town has shyte weather, as certain as the Bulls is going to trash the Sharks, affirmative, all right, amen, aye, beyond a doubt, by all means, certainly, definitely, even so, exactly, fine, gladly, good, good enough, granted, indubitably, just so, most assuredly, naturally, of course, okay, positively, precisely, surely, sure thing, true, undoubtedly, unquestionably, very well, willingly, without fail, yea, yep, all righty then, certainly, dead sure, for a fact, for certain, for real, no doubt, no question, no two ways about it, really, sure thing, unquestionably, according to Hoyle, actual, appropriate, cooking with gas, dead on, equitable, factual, faithful, faultless, flawless, for sure, free of error, impeccable, just, legitimate, nice, okay, on target, on the ball, on the beam, on the button, on the money, on the nose, on track, perfect, precise, proper, regular, right, right as rain, righteous, right on, right stuff, rigorous, stone, strict, true, undistorted, unmistaken, veracious, veridical, absolutely, altogether, bang, carefully, completely, correctly, definitely, explicitly, expressly, faithfully, faultlessly, for a fact, for certain, for sure, indeed, in every respect, just, literally, methodically, no mistake, on the dot, on the money, on the nail, on the nose, positively, precisely, quite, right, rigorously, scrupulously, severely, sharp, specifically, square, strictly, the ticket, totally, truly, truthfully, unequivocally, unerringly, utterly, veraciously, wholly, spot on, on the dot, absolutely, assuredly, cert, exactly, for a fact, of course, positively, posolutely, geniune, right on, surely, unquestionably, without fail, Is the Sky Blue?, Is the bulls going to trash the sharkies on Saterday, Is EFI the best mod you ever did on your lux?, I think I am almost on two hundred words now, maybe I should copy and paste the same stuff over, I wonder if rich would notice? affirmative, all right, amen, aye, beyond a doubt, by all means, certainly, definitely, even so, exactly, fine, gladly, good, good enough, granted, indubitably, just so, most assuredly, naturally, of course, okay, positively, precisely, surely, sure thing, true, undoubtedly, unquestionably, very well, willingly, without fail, yea, yep, all righty then, certainly, dead sure, for a fact, for certain, for real, no doubt, no question, no two ways about it, really, sure thing, unquestionably, according to Hoyle, actual, appropriate, cooking with gas, dead on, equitable, factual, faithful, faultless, flawless, for sure, free of error, impeccable, just, legitimate, nice, okay, on target, on the ball, on the beam, on the button, on the money, on the nose, on track, perfect, precise, proper, regular, right, right as rain, righteous, right on, right stuff, rigorous, stone, strict, true, undistorted, unmistaken, veracious, veridical, absolutely, altogether, bang, carefully, completely, correctly, definitely, explicitly, expressly, faithfully, faultlessly, for a fact, for certain, for sure, indeed, in every respect, just, literally, methodically, no mistake, on the dot, on the money, on the nail, on the nose, ah five hundred and twenty words already maybe copy all again. affirmative, all right, amen, aye, beyond a doubt, by all means, certainly, definitely, even so, exactly, fine, gladly, good, good enough, granted, indubitably, just so, most assuredly, naturally, of course, okay, positively, precisely, surely, sure thing, true, undoubtedly, unquestionably, very well, willingly, without fail, yea, yep, all righty then, certainly, dead sure, for a fact, for certain, for real, no doubt, no question, no two ways about it, really, sure thing, unquestionably, according to Hoyle, actual, appropriate, cooking with gas, dead on, equitable, factual, faithful, faultless, flawless, for sure, free of error, impeccable, just, legitimate, nice, okay, on target, on the ball, on the beam, on the button, on the money, on the nose, on track, perfect, precise, proper, regular, right, right as rain, righteous, right on, right stuff, rigorous, stone, strict, true, undistorted, unmistaken, veracious, veridical, absolutely, altogether, bang, carefully, completely, correctly, definitely, explicitly, expressly, faithfully, faultlessly, for a fact, for certain, for sure, indeed, in every respect, just, literally, methodically, no mistake, on the dot, on the money, on the nail, on the nose, Yes, for sure, most certainly, most probably, definitely, very likely, of course, undoubtedly, undeniably, unquestionably, indisputably, without a doubt, obviously, clearly, evidently, plainly, perceptibly, markedly, unmistakably, possibly , to be expected, apparent, plain as the nose on your face, or the hair on your back, as certain as death and taxes and Nissans being unreliable, as cetain as cape town has shyte weather, as certain as the Bulls is going to trash the Sharks, affirmative, all right, amen, aye, beyond a doubt, by all means, certainly, definitely, even so, exactly, fine, gladly, good, good enough, granted, indubitably, just so, most assuredly, naturally, of course, okay, positively, precisely, surely, sure thing, true, undoubtedly, unquestionably, very well, willingly, without fail, yea, yep, all righty then, certainly, dead sure, for a fact, for certain, for real, no doubt, no question, no two ways about it, really, sure thing, unquestionably, according to Hoyle, actual, appropriate, cooking with gas, dead on, equitable, factual, faithful, faultless, flawless, for sure, free of error, impeccable, just, legitimate, nice, okay, on target, on the ball, on the beam, on the button, on the money, on the nose, on track, perfect, precise, proper, regular, right, right as rain, righteous, right on, right stuff, rigorous, stone, strict, true, undistorted, unmistaken, veracious, veridical, absolutely, altogether, bang, carefully, completely, correctly, definitely, explicitly, expressly, faithfully, faultlessly, for a fact, for certain, for sure, indeed, in every respect, just, literally, methodically, no mistake, on the dot, on the money, on the nail, on the nose, positively, precisely, quite, right, rigorously, scrupulously, severely, sharp, specifically, square, strictly, the ticket, totally, truly, truthfully, unequivocally, unerringly, utterly, veraciously, wholly, spot on, on the dot, absolutely, assuredly, cert, exactly, for a fact, of course, positively, posolutely, right on, surely, unquestionably, without fail, Is the Sky Blue?, Is the bulls going to trash the sharkies on Saterday, Is EFI the best mod you ever did on your lux? Thousand and twenty five words so far lets starts repeating again.Yes, for sure, most certainly, most probably, definitely, very likely, of course, undoubtedly, undeniably, unquestionably, indisputably, without a doubt, obviously, clearly, evidently, plainly, perceptibly, markedly, unmistakably, possibly , to be expected, apparent, plain as the nose on your face, or the hair on your back, as certain as death and taxes and Nissans being unreliable, as cetain as cape town has shyte weather, as certain as the Bulls is going to trash the Sharks, affirmative, all right, amen, aye, beyond a doubt, by all means, certainly, definitely, even so, exactly, fine, gladly, good, good enough, granted, indubitably, just so, most assuredly, naturally, of course, okay, positively, precisely, surely, sure thing, true, undoubtedly, unquestionably, very well, willingly, without fail, yea, yep, all righty then, certainly, dead sure, for a fact, for certain, for real, no doubt, no question, no two ways about it, really, sure thing, unquestionably, according to Hoyle, actual, appropriate, cooking with gas, dead on, equitable, factual, faithful, faultless, flawless, for sure, free of error, impeccable, just, legitimate, nice, okay, on target, on the ball, on the beam, on the button, on the money, on the nose, on track, perfect, precise, proper, regular, right, right as rain, righteous, right on, right stuff, rigorous, stone, strict, true, undistorted, unmistaken, veracious, veridical, absolutely, altogether, bang, carefully, completely, correctly, definitely, explicitly, expressly, faithfully, faultlessly, for a fact, for certain, for sure, indeed, in every respect, just, literally, methodically, no mistake, on the dot, on the money, on the nail, on the nose, positively, precisely, quite, right, rigorously, scrupulously, severely, sharp, specifically, square, strictly, the ticket, totally, truly, truthfully, unequivocally, unerringly, utterly, veraciously, wholly, spot on, on the dot, absolutely, assuredly, cert, exactly, for a fact, of course, positively, posolutely, right on, surely, unquestionably, without fail, Is the Sky Blue?, Is the bulls going to trash the sharkies on Saterday, Is EFI the best mod you ever did on your lux?, I think I am almost on two hundred words now, maybe I should copy and paste the same stuff over, I wonder if rich would notice? affirmative, all right, amen, aye, beyond a doubt, by all means, certainly, definitely, even so, exactly, fine, gladly, good, good enough, granted, indubitably, just so, most assuredly, naturally, of course, okay, positively, precisely, surely, sure thing, true, undoubtedly, unquestionably, very well, willingly, without fail, yea, yep, all righty then, certainly, dead sure, for a fact, for certain, for real, no doubt, no question, no two ways about it, really, sure thing, unquestionably, according to Hoyle, actual, appropriate, cooking with gas, dead on, equitable, factual, faithful, faultless, flawless, for sure, free of error, impeccable, just, legitimate, nice, okay, on target, on the ball, on the beam, on the button, on the money, on the nose, on track, perfect, precise, proper, regular, right, right as rain, righteous, right on, right stuff, rigorous, stone, strict, true, undistorted, unmistaken, veracious, veridical, absolutely, altogether, bang, carefully, completely, correctly, definitely, explicitly, expressly, faithfully, faultlessly, for a fact, for certain, for sure, indeed, in every respect, just, literally, methodically, no mistake, on the dot, on the money, on the nail, on the nose, ah five hundred and twenty words already maybe copy all again. affirmative, all right, amen, aye, beyond a doubt, by all means, certainly, definitely, even so, exactly, fine, gladly, good, good enough, granted, indubitably, just so, most assuredly, naturally, of course, okay, positively, precisely, surely, sure thing, true, undoubtedly, unquestionably, very well, willingly, without fail, yea, yep, all righty then, certainly, dead sure, for a fact, for certain, for real, no doubt, no question, no two ways about it, really, sure thing, unquestionably, according to Hoyle, actual, appropriate, cooking with gas, dead on, equitable, factual, faithful, faultless, flawless, for sure, free of error, impeccable, just, legitimate, nice, okay, on target, on the ball, on the beam, on the button, on the money, on the nose, on track, perfect, precise, proper, regular, right, right as rain, righteous, right on, right stuff, rigorous, stone, strict, true, undistorted, unmistaken, veracious, veridical, absolutely, altogether, bang, carefully, completely, correctly, definitely, explicitly, expressly, faithfully, faultlessly, for a fact, for certain, for sure, indeed, in every respect, just, literally, methodically, no mistake, on the dot, on the money, on the nail, on the nose, Yes, for sure, most certainly, most probably, definitely, very likely, of course, undoubtedly, undeniably, unquestionably, indisputably, without a doubt, obviously, clearly, evidently, plainly, perceptibly, markedly, unmistakably, possibly , to be expected, apparent, plain as the nose on your face, or the hair on your back, as certain as death and taxes and Nissans being unreliable, as cetain as cape town has shyte weather, as certain as the Bulls is going to trash the Sharks, affirmative, all right, amen, aye, beyond a doubt, by all means, certainly, definitely, even so, exactly, fine, gladly, good, good enough, granted, indubitably, just so, most assuredly, naturally, of course, okay, positively, precisely, surely, sure thing, true, undoubtedly, unquestionably, very well, willingly, without fail, yea, yep, all righty then, certainly, dead sure, for a fact, for certain, for real, no doubt, no question, bang, carefully, completely, correctly, definitely, explicitly, expressly, faithfully, faultlessly, for a fact, for certain, for sure, indeed, in every respect, just, literally, methodically, no mistake, on the dot, on the money, on the nail, on the nose, positively, precisely, quite, right, rigorously, scrupulously, severely, sharp, specifically, square, strictly, the ticket, totally, truly, truthfully, unequivocally, unerringly, utterly, veraciously, wholly, spot on, on the dot, absolutely, assuredly, cert, exactly, for a fact, of course, positively, posolutely, right on, surely, unquestionably, without fail, Is the Sky Blue?, Is the bulls going to trash the sharkies on Saterday, Is EFI the best mod you ever did on your lux? If you now count the words you will realise it is two thousand words exactly. ========================================================================= Try reading that aloud in one breath
| Thu Oct 23, 2008 4:23 pm |
ThysdJ
Joined: Wed Oct 24, 2007 7:31 am Posts: 15328 Location: Brackenfell
ORRA Call Sign: X22
 Re: The Importance of having an operational Engine Thermostat
_________________
Member of SANOTA / OGATO / Offroad Tour Guide : GP5044
2010 Hilux 3.0 D4D D/C 4x4 with GOMAD "Brood" Canopy. Drives like a Camry. 1997 Jeep Wrangler TJ 4.0 Sport. The original SFA. AGA... Gooi kole email: thys@teamoffroad.co.za
 Some minds are like Concrete: Thoroughly mixed up and permanently set!
| Thu Oct 23, 2008 4:44 pm |
Scorpion
Joined: Wed Jan 16, 2008 6:31 pm Posts: 2556 Location: Randburg
Town: Randpark Ridge
Vehicle: 1988 Hilux 4x4 D/C with more attitude than Mike Tyson
Real Name: Johann
You have way too much time on your hands, Bennie! Rather go spend it on your red lorrie...
_________________ 1988 Hilex D/C 4x4 (Import spec), Lexus V8; Marlin Crawler; Custom Suspension: front and new 4 link in the rear; Disc Brake conversion rear; 35" Cooper STT tyres; Xenon lights; Custom bullbar;Next? Aircon; new front seats, redo the whole interior in nice soft leather, Respray, Double Lockers 1978 Land Cruiser HJ45 1971 Mercedes Benz 280S Automatic 2011 Land Cruiser 79 V6 (60th Anniversary Edition)
| Thu Oct 23, 2008 4:47 pm |
Dadz Toy BFI
 Full Marks Scholar Bennie You are nou a Fully Fledged Mighty Blou Bull Bloke :D: Rich
| Thu Oct 23, 2008 5:20 pm |
Joined: Tue May 22, 2007 10:09 am Posts: 11539 Location: Klerksdorp, NW
It's not two thousand words. Attachment:
_________________
White Fang: 1999 2.7i DC Raider 4x4 Bull Dog: 1987 4Y-EFI 2.2 DC 4x4 Pra Dog: 1998 Prado VX 3.4 Hound Dog: 2000 2.7i SC 4x4
| Thu Oct 23, 2008 5:56 pm |
Dadz Toy BFI
Family_BullDog wrote: It's not two thousand words. Attachment: 1999 Words.jpg -F_D BustedSEE ME! Master Hurter
| Thu Oct 23, 2008 6:53 pm |
Scorpion
Real Name: Johann
Dadz Toy BFI wrote: Family_BullDog wrote: It's not two thousand words. -F_D BustedStandard Blue Bull Practise...
| Thu Oct 23, 2008 8:29 pm |
BenHur
Real Name: Bennie
| Thu Oct 23, 2008 9:30 pm |
BenHur
Real Name: Bennie
Scorpion wrote: You have way too much time on your hands, Bennie! Rather go spend it on your red lorrie...  The Internet is your friend
| Thu Oct 23, 2008 9:33 pm |
Sneaking an extra word in now after I did the count is not very PC.... -F_D
_________________
| Fri Oct 24, 2008 11:31 am |
Dadz Toy BFI
I'm gonna jump up and give him a Fatklap across his knee caps when I see him next Eric
| Fri Oct 24, 2008 11:40 am |
ORRA Call Sign: B15
Family_BullDog wrote: Sneaking an extra word in now after I did the count is not very PC.... -F_D Typical blue bull tactic Eric.... That is a yellow card for mr Hurter
_________________
BenHur
Real Name: Bennie
| Fri Oct 24, 2008 11:54 pm |
Page 1 of 1
[ 24 posts ] |
Who is online |
Users browsing this forum: Google [Bot] |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
