Airbag indicator light
Mikie
Town: Kyalami
Vehicle: Hilux 2006 3.0D4D 2x4 DC
Real Name: Mike
Thu May 11, 2017 7:52 am
My 2006 3.0 D4D yesterday decided that it should permanently inform me that I have Airbags, it warning light stays on permanently
Anyone know what could cause this?
Any ideas on how to rectify it?
Maybe disconnect the battery for a while to reset the error?
lukestoyzx
Town: Griffith
Vehicle: 07 Hilux SR5
Real Name: Luke
Thu May 11, 2017 9:01 am
Very common problem mate. It'll be the airbag clock spring in the back of the steering wheel. As I said it's very common, toyota did a recall on them years ago.
Die$eL
Town: Midrand
Real Name: Nishan
Thu May 11, 2017 10:13 am
You can still take it to Toyota for the recall. They will repair it free
Real drivers use three pedals
Mikie
Town: Kyalami
Real Name: Mike
Thu May 11, 2017 11:06 am
Thanks Gents, I will go past a dealer and see what they say about it
lukestoyzx
Town: Griffith
Real Name: Luke
Thu May 11, 2017 12:12 pm
They'll be able to look up you chassis number an see if it's done b4. If it hasn't they'll do it free otherwise get a clock spring on ebay and do it yourself.
Die$eL
Town: Midrand
Real Name: Nishan
Thu May 11, 2017 12:54 pm
even if it was done before they will probably do it again.
They did my Fortuner twice. Apparently the batch they used for the first recall was defective
Mikie
Town: Kyalami
Real Name: Mike
Thu May 11, 2017 2:14 pm
Shot guys
pieta.swanepoel
Vehicle: Toyota Hilux SRX 2.5D-4D 4x4 SC
Real Name: Pieta
Fri May 12, 2017 2:25 pm
I accidentally disturbed one of the wire plugs of the airbag sensor, that caused the light to come on when I was busy fixing one of the air vents. Maybe just check behind the glovebox if there is not a loose wire plug
lukestoyzx
Town: Griffith
Real Name: Luke
Fri May 12, 2017 2:33 pm
Make sure ya have the battery disconnected for a good ten minutes b4 ya fiddle with any airbag wires. Wouldn't want an airbag goin off in ya face!! It hurts!
Mikie
Town: Kyalami
Real Name: Mike
Mon May 15, 2017 6:44 am
So its now intermittent, off most of the time, bu every now and again it decides to stay on after starting
ERJ
Town: Stellenbosch
Vehicle: 3L Hilux 4x4 Xtra cab
Real Name: Ruben
Thu May 17, 2018 9:56 am
Hi all, I have a brand new Clock Spring or Spiral Cable for a 2013 Toyota Hilux for sale.
This tread was a real lifesaver when I needed it. My horn only worked intermediately, only when turning the steering wheel.
I was in Kenya at the time and had to buy a new one from Toyota in Stellenbosch because in Kenya, the Toyota recall was not valid.
And as you will agree, you can’t drive through Africa without a horn.
So once i got back in SA i send the bakkie in for the Clock Spring recall (free replacement), so now i still have a brand new Clock Spring (7000 km only).
I paid R 2700 for this piece of plastic!
Will sell for R 1500, and help you replace yours, even give you a cold beer while your wait. I’m in Stellenbosch.
Phone me at 082 seven 643 seven 32
Regards Ruben
    Users browsing this forum: blom
