I had a slight oil leak on No 3 cylinder's spark plug well.(noticed oil in there when I changed the plugs)
So I bought a gasket set from Autozone and pulled the valve cover on the weekend.
I changed the valve cover gasket and all 4 spark plug gaskets, old gaskets were all hard and brittle.
So while I had the cover off I checked the valve clearances, all were in spec except for No 4 cylinder Intake valves which where a tight 5 thou minimum is 6 thou.
Engine has 310000km on it, I have already order the special tools from China, once they arrive I will have to check the shim thickness and then order replacement shims from Toyota.
Here are some links on how to do it:
https://www.youtube.com/watch?v=c9QJ_zVlznA
https://www.youtube.com/watch?v=pKEkOdQuJR4
https://www.youtube.com/watch?v=wI4LznrDzcg
3RZ Check your Valve Clearances!
- GTO
- Town: Fish Hoek
- Vehicle: 2002 2700i 4x4 DC ; 1995 2.4 SRX
- Real Name: Stephen
1985 Suzuki DR600S
1984 Honda ATC200ES BIG RED
1985 Suzuki DR600S
- drew3
- Town: Tuli Block
- Vehicle: '01 Toyota Hilux 4x4 Raider 2.7i DC
- Real Name: Drew
Re: 3RZ Check your Valve Clearances!
Hey GTO,
I am interested in an update on this when you have one. I'm keen to check mine when my IFS turns 200k.
Sent from my SM-A520F using Tapatalk
2001 Hilux 4x4 Raider 2.7i DC
- GTO
- Town: Fish Hoek
I measured shims on the weekend, I need a No. 6 & No. 7 shim, ordered from Toyota but have to wait as they don't have No. 7 in SA has to come from Japan!
1985 Suzuki DR600S
1985 Suzuki DR600S
