Fuel gauge changing when spotlights on
Town: Calvinia
Vehicle: 3.0L KZ-TE 4x2
Real Name: HJ
Sun Feb 18, 2018 7:11 pm
I have a problem with my Fuel gauge dropping to half full if I switch on the brights. Had Hella 700’s on but changed them to LED spots. No change. Problem started after fitting the spots. “Professionally” mind you. Electrician says its a ground fault. But the bakkie has spent a week at an electrician and no luck. Any one have a similar problem?
Town: Potchefstroom
Vehicle: SRX 2.5 4x4 D/C
Real Name: James
Mon Feb 19, 2018 8:45 am
It is commonly called electrickery...
James Cameron
