Hi All
Thanks for adding me!
So I got my first diesel vehicle about a month ago, a 2012 2.5 D4D Hilux. It has been fitted with an intercooler and chip by SAC.
Ive had a diagnostics done, then a dyno by SAC. Both showed that the air mass meter is faulty, which I replaced. This seems to have improved fuel usage from 8.5 to about 9.4km/l. According to SAC I should be getting 10km/l plus.
When I accellerate hard, theres black smoke coming from the exhaust. Not much, but I know there shouldnt be any. From what Ive read,it means fuel to air ratio isnt correct,so fuel does not fully combust.
The dyno results showed that everything is in order, injectors function correctly etc.
I need some knowledgable advice on what the cause could be. ERG valve or air filter perhaps dirty? The engine oil is also quite black.
Id really appreciate advice from the big guns!
2012 2.5 D4D fuel economy
Re: 2012 2.5 D4D fuel economy
Welcome aboard Ian!
You will have to wait for the diesel heads to respond, but yes, from my limited diesel knowledge, black smoke generally means over fuelling and the possible causes can be numerous. The MAF that you replaced is one of them, injector calibration needs to be within spec and ideally all with closely similar values, EGR might well need cleaning - especially if it's been subjected to a period of black sooty exhaust gas. As far as I am to understand a dirty filter, as you mentioned, can also upset the apple cart. In fact, anything that provides the ECU with data input affects power and economy.
Hope that someone here will be able to give you some more meaningful pointers. Gooid luck.
- 4wiel
- Vehicle: Hilux 2012 2.5 D4D
- Real Name: Ian
Thanks Andy
According to the diagnostic I did, injectors are all in spec. 1 is slightly out, but mechanic said its very little and still within spec, almost not worth mentioning. Nothing else came up in the dyno.
The vehicle has 170k on the clock. So its done some work.
Is there an oxygen meter other than the MAF that might be faulty?
Been driving petrol all my life, diesel is new to me. Got tired of guiding people on tracks and not driving it myself...!
On petrol EFI one uses a an AFR meter in the exhaust (Air Fuel Ratio) that basically measures the CO and determines how efficient the combustion is - too rich or too lean. On diesel I think the EGR ( which I think stands for Exhaust Gas Ratio) takes over that function - I could of course have it wrong.
- 4wiel
- Real Name: Ian
So Ive checked the air filter and its new. Theres some soot on the inside of the filter where the MAF is located.Mud Dog wrote:On petrol EFI one uses a an AFR meter in the exhaust (Air Fuel Ratio) that basically measures the CO and determines how efficient the combustion is - too rich or too lean. On diesel I think the EGR ( which I think stands for Exhaust Gas Ratio) takes over that function - I could of course have it wrong.
I take it theres quite a bit of carbon build up inside the engine.
My logic tells me that the air that is recirculated to the engine from the exhaust via the EGR then already contains soot particles. Unless this air does not pass through the filter but straight to the engine again?
How can I locate the EGR valve,is it easy to remove and clean diy?
Ive read a thread on here on a nissan having it removed in 10 mins?
Sent from my LG-D855 using Tapatalk
