Is this something to worry about
Whisky
Town: Durbanville
Real Name: Ben
Club VHF Licence: HC 136
Mon Jun 04, 2018 9:39 pm
I changed the right rear wheel today and when putting the jack under the axle I noticed this wet patch where the axle and wheel hub is connected. Should I be worried about it or could I just leave it but keep an eye on it.
mcw
Town: krugersdorp
Vehicle: Prado 90 V6 3.4 Auto
Real Name: Martin
Club VHF Licence: X100
Mon Jun 04, 2018 10:21 pm
Hi Ben
i would be can only be the oil seal that has started leaking , on some Toyota axles this washes out the grease in bearing and can cause bearing to fail ,for instance on the Prado l have this is the case. Not to sure if Hilux has the same set up (semi floating axle) . i would only use genuine Toyota replacement seals ,the aftermarket ones are know to fail very quickly
Martin
Martin
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Tue Jun 05, 2018 4:27 am
Agree with Martin. Replace your oil seel with genuine Toyota one.
Dowe Koos
Real Name: Hennie
Tue Jun 05, 2018 7:10 am
Ek het ook so soortgelyke probleem. Moet die bearings afkom om die seels te vervang of kan mens net die seels vervang. Ry ń 2.7 2004 model. Is dit maklik om dit self te doen. Dankie.
Dowe Koos
Real Name: Hennie
Tue Jun 05, 2018 4:28 pm
Ek sien nou wat julle altyd so praat, van Toyota wat mens so beroof. 2 x Bearings vir R2450.00 terwyl Midas vra net R480.00 vir twee. So met ander woorde net die boksie met Toyota se naam op kos dus R1970.00.
Vir die 4 olieseëls vra hulle maar net R780.00. Ek het maar op Martin se woord gegaan om die oorspronklike seëls maar by Toyota te gaan koop.
Wat stel julle ouens voor, watter brand kan mens maar vertrou by Midas of Autozone.
Dankie.
The Legend
Real Name: Dawie
Tue Jun 05, 2018 4:35 pm
Hennie maak nie saak by wie jy koop nie. Koop net Timken of NSK bearings. Het jy pryse by Bearing man (BMG) gekry?
Dowe Koos
Real Name: Hennie
Tue Jun 05, 2018 4:38 pm
Sal more bel, dankie Dawie.
mcw
Town: krugersdorp
Real Name: Martin
Tue Jun 05, 2018 4:45 pm
Haai Hennie
Bearing man het n bearing brand wat hulle aan al die Taxi verkoop,het Desember twee jaar terug op die Prado gebruik
nog geen klagtes nie ,kon niks aander make kry nie
Onthou daar is n Toyota handelaar wat 20% afslag gee op parte gee vir Hilux club lede
Jy kan ook vir Gemini spares vra wat hulle aanhou ,baie taxi koop daar
Martin
Dowe Koos
Real Name: Hennie
Tue Jun 05, 2018 5:09 pm
Dankie Martin, sal so maak.
louis fourie
Club VHF Licence: X101
Tue Jun 05, 2018 5:43 pm
The Legend wrote:Hennie maak nie saak by wie jy koop nie. Koop net Timken of NSK bearings. Het jy pryse by Bearing man (BMG) gekry?
Of SKF of Koyo. N1 4x4 sal ook hê/kan bestel. Hulle verkoop egte onderdele en daai seëls gaan omtrent die helfte goedkoper wees by hulle.
Dowe Koos
Real Name: Hennie
Tue Jun 05, 2018 9:43 pm
Dis sommer naby my, sal daar draai maak more. Dankie Louis.
louis fourie
Wed Jun 06, 2018 4:41 pm
Dowe Koos wrote:Dis sommer naby my, sal daar draai maak more. Dankie Louis.
Dowe Koos
Real Name: Hennie
Wed Jun 06, 2018 5:53 pm
Gaan more my 2 bearings kry by N1 4x4 vir R569.00. Sal Saterdag dit aanpak. Dankie Louis.
Wed Jun 06, 2018 9:18 pm
Sterkte, het nog nie self gedoen nie, maar ek hoor altyd die ouens praat van dit is nie maklik om daai bearings af te kry en jy moet passop dat jy nie die ABS ring breek in die proses nie.
louis fourie
Thu Jun 07, 2018 5:24 pm
Dowe Koos wrote:Gaan more my 2 bearings kry by N1 4x4 vir R569.00. Sal Saterdag dit aanpak. Dankie Louis.
My plesier Image
Dowe Koos
Real Name: Hennie
Sun Jun 10, 2018 8:58 pm
Hallo Ben, Dit is wat ek die naweek gedoen het. Ek het ook so by Februarie gesien soos joune op die fotos en gedog ek sal dit maar net dophou. Maar na Martin se kommentaar het ek maar besluit ek moet die bearings vervang aangesien ek met skoolvakansie Suidwes toe gaan en was glad nie lus om iewers langs die pad te sukkel nie.
Dit is nadat ek die as uitgehaal het, kyk wat is die toestand van die bearings en seels. Roes en water.
Midas se retainer ring uit die boks uit en dis oor geverf. Toe ek die verf afkrap kon ek sien dit is swak kwaliteit, seker maar Made in China, koop liewers by Autozone, beter kwaliteit.
(24.21 KiB) Not downloaded yet
Hallo Louis, het my bearings by N1 4x4 gekry en gedink dis alles. Ek het eers Saterdagmiddag die pakkie oopgemaak en gesien daar is nie retainer rings in nie. was verplig om by Autozone te koop net om die retainer rings te kan hê. N1 4x4 was in elke geval toe. Kon nie wag tot Maandag nie.
Dis die eerste keer wat ek so iets aangepak het en het toe nie geweet daar moet retainer rings wees nie.
louis fourie
Mon Jun 11, 2018 7:00 pm
Dowe Koos wrote:Hallo Ben, Dit is wat ek die naweek gedoen het. Ek het ook so by Februarie gesien soos joune op die fotos en gedog ek sal dit maar net dophou. Maar na Martin se kommentaar het ek maar besluit ek moet die bearings vervang aangesien ek met skoolvakansie Suidwes toe gaan en was glad nie lus om iewers langs die pad te sukkel nie.
Eish. So leer ons almal.
Whisky
Town: Durbanville
Real Name: Ben
Tue Jun 12, 2018 7:07 pm
Naand Hennie, dankie vir die terugvoer. Ek het dit ook nog nie self gedoen nie so sal dit maar na Toyota toe vat. Sal sien wat kwoteer hulle my. :siffler: Het jy albei kante gedoen of net die een wat natgesweet is?
Ons ry Aug Noord Kaap toe so sal dit liewers doen as probleme langs die pad optel :slap:
Groete.
Tue Jun 12, 2018 7:41 pm
Hi Ben. Yes, have it seen to before your trip - chances are that if it is going to fail, it will do so on a long trip. It might just be the seal, but if there has been water ingress and it looks anything like Hennie's, it will fail you.
Good luck. :winkx:
Dowe Koos
Real Name: Hennie
Tue Jun 12, 2018 8:53 pm
Yes Ben I had done both wheels, better safe now than sorry later. I had lot of tools at home and it was not easy to take the bearing out. The assembling job was easy because I had a press, but it is not something you can take it with you. Do it before you go on your trip.
Whisky
Town: Durbanville
Real Name: Ben
Sun Jun 17, 2018 8:50 pm
Ek sien hier is nou nie baie Kapenaars wat op hierdie blad was nie so sal op die Community Forum ook pos. My vraag is na wie kan ek my Toyota hier in Durbanville neem om die seëls te vervang. Wil nie na Toyota garage gaan omdat hulle my 'n arm en been gaan vra.
Dankie,
The Legend
Real Name: Dawie
Mon Jun 18, 2018 4:19 am
Dankie,
Ben vat jou bakkie na Allan Venter toe in Brackelfell.Hy is jou Toyota man.
Whisky
Town: Durbanville
Real Name: Ben
Mon Jun 18, 2018 8:53 pm
Dankie,
Dankie, kontak besonderhede asb.
The Legend
Real Name: Dawie
Tue Jun 19, 2018 4:13 am
Jammer Ben ek het dit nie meer nie. Het dit verloor toe my selfoon in was vir reparasies.Seker een van die ander forum manne kan jou help.
Tue Jun 19, 2018 7:34 am
Ben, speak to the guys at 4x4 Direct in Cape Town. Hoppy's place was in the same complex, sure they can direct you.
Contact details for 4x4 Direct in the left side "Quick Links" of this forum.
george
Vehicle: Prado 90 VX 3.4 V6
Club VHF Licence: HC107
Tue Jun 19, 2018 7:51 am
Hi Ben
Skakel vir Francois
Francois at 4xLux
Address: Unit 64B, Gemini St, Brackenfell, Cape Town, 7560
Phone: 072 424 0500
Whisky
Town: Durbanville
Real Name: Ben
Tue Jun 19, 2018 2:28 pm
Dankie vir die inligting. Ek sien almal is in dieselfde omgewing. Sal 'n draai by hulle maak.
    Users browsing this forum: Baidu [Spider], Google Adsense [Bot], Whisky
