Spongy brakes
Danman
Vehicle: 2000 Hilux DC 2.7 aka "Noster"
Real Name: Danie
Wed Jun 13, 2018 8:24 am
Good day fellow hiluxers,
I have replaced my brake pads 2 weeks ago on my 2000 IFS , ever since my brake pedal travel have been doing strange things.
Sometimes it has the normal amount of travel(like before) but every now and then it travels way down(still braking luckily).
There is no leak in the system that I can see and it was fine up to the pad change.
What could be the cause?
Any suggestions would be much appreciated
dd6
Vehicle: 1995 SFA
Real Name: Jaco
Wed Jun 13, 2018 11:00 am
This sometimes happens with new pads. If there is no apparent problem and you have brakes, maybe give it another few km's until the pads "bed" in. Is the discs worn? Maybe bleed the brake fluid just to be safe.
Danman
Real Name: Danie
Wed Jun 13, 2018 1:00 pm
Thanx
yes the disks is worn a bit. I will bleed it this weekend, maybe replace the fluid, cause I think it still has the factory brake fluid in the system :shock: :silent:
LouisZ
Wed Jun 13, 2018 9:43 pm
Bleed the brake fluid out till you get only the new fluid. Always good.
Let pads wear in too.
Obelix and Dogmatix
Town: ROODEPOORT
Vehicle: HILUX 4.0 V6 4x4 named Obelix, donated to some clown, HILUX 4.0 V6 4x4 named Obelix II Onca front and rear Amade extreme Suspension and under water breathing apparatus
Real Name: Quentin
Thu Jun 14, 2018 9:30 am
Another could be that the pads have developed a glassy surface, remove the pads and on a 1000% flat surface with sandpaper tape to it (ie granite kitchen counter and wait for swambo to go shopping) "roughen them up a bit" and re install Always drive like miss daisy the first couple of Hundred kilos for the pads to bed in. Wish I would listen to myself then i would have this "advise" to give.
God made man before
woman so as to give him time
to think of an answer
for her first question
    Users browsing this forum: Family_Dog
