Oil pump
Zatopec
Town: Strand
Vehicle: 82 Hilux 4x4 S/C
Real Name: Rodney
Sun Jul 08, 2018 9:16 am
Hello guys
The 2C non turbo motor in my 4x4 has been standing for a month now.. i replaced the front crank and oil pump oil seals. The oil pump was removed. My question, does the oil pump need to be primed or bled before starting and if so how will this be done?
Rodney
FIRSTGEER
Town: King WilliamsTown
Real Name: Tony Geer
Club VHF Licence: HC 109
Sun Jul 08, 2018 11:14 am
Howzit Rodney.IF possible,fill the pump up with oil prior to installing .Also remove the oil pressure sensor and attempt to pump oil into the system via this hole by using a oil can pump.
Sun Jul 08, 2018 11:49 am
I see that Tony had posted while I was typing and his idea of oiling through the pressure sensor is a good one .....
It will prime itself but typically these are not high volume pumps so it might take about 15 / 20 seconds to prime and then a few more to fill the filter (which would have drained by now) and galleries before reaching all the necessary places.
The fact that it has stood for so long is not in your favour - oil will have seeped out of the bearing surfaces and although there will still be oil there, all the bearings will be running fairly dry relative to normal conditions.
Typically the pump will deliver to the filter before anything else so if you like you could remove the filter and squirt some oil down the delivery pipe which will run down to the pump and help with priming. You could also remove the top cover and put some oil on the cam journal bearings and lobes. That's all optional and will help, but what I would do in any event is to disable ignition (maybe remove the glow plugs so that there is also no compression load either) and turn the motor over with the starter in a few 5sec bursts using a jumper battery before actually starting it. That way at least the crank bearings won't be dry when starting under normal load. You could also squirt a small amount of oil into the cylinders through the glow plug holes so as to lubricate the rings as well.
I somehow doubt that a workshop would go to all that trouble and would probably just start it up as is, but then again in most such cases it would not have been standing so long either.
Good luck. :winkx:
Zatopec
Town: Strand
Real Name: Rodney
Sun Jul 08, 2018 8:44 pm
Thanks guys. I have a manual oil pressure gauge and took a chance by cranking the motor with out starting. Pressure was around 3 after about 5 seconds. Power back onto the IP and upon start up went to 7 bar.
I now have a oil leak on the alternator. Engine start up with out the alternator turning. Truly hope this did not do damage to the alternator.
Regards
Sun Jul 08, 2018 11:05 pm
The alternator runs on it's own sealed bearings .... not oil from the motor. What makes you think it has an "oil leak"? Has oil perhaps not dripped onto it from when you were working? Or from somewhere else like the rocker cover?
Mon Jul 09, 2018 7:41 am
Does the alternator have a vacuum pump at the back?
Rigger
Town: Oudtshoorn
Real Name: Martiens
Mon Jul 09, 2018 10:37 am
Yes, the 2C alternators have the vacuum pump at the back. The oil leak could come from it.
Zatopec
Town: Strand
Real Name: Rodney
Mon Jul 09, 2018 7:47 pm
Correct. Vacuum pump at the back of the alternator. I opened the pump but could not see any where the leak could have come from. Only thing i can think of was the oil pressure bypassed the o ring because the alternator was not turning with the engine.
Regards
FIRSTGEER
Mon Jul 09, 2018 9:59 pm
Yes Andy.Many of the diesel engine setups utilize a small vacuum pump attached to to the rear of the alternator to provide the vacuum for the brake system.The petrol engines receive the needed vacuum from the inlet manifold
The beauty of the 5cyl 300d merc engine ,which we installed into Wades hilux ,is that the engine has its own vacuum pump driven off the engine .
This alternator/vacuum pump setup used by many diesel results in a very costly repair or replacement of the alternator.
Tue Jul 10, 2018 12:29 am
Thanks Tony. We petrol heads don't know about those things but we live and learn. :D:
    Users browsing this forum: Google [Bot]
