Warning... All SFA Owners!
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Sun Mar 08, 2009 12:29 am
Hi All,
As we all know the SFA is an incredible vehicle. :angel: Even in stock standard guise these vehicles can go where others can't... But they do have there Achilles Heel :wth: ... rust :shock: ! Most body rust is easily seen and therefore taken care of quickly before it gets out hand... but there are 2 unseen spots that most SFA owners neglect, not because they don't care, just because it's out of site and out of mind... :confused: where? ... behind the front fenders! :!:
So this Saturday I decided to check for, and, if needed, repair any rust found behind the fenders... When water runs down the windscreen it enters a water escape channel below the windscreen, this channel has exit holes behind the left and right fenders. Over time sand and other debris builds up and blocks the channels, this wet debris leads to rust at the channel exits... :eh:
Yes Richard... I hear you... where da peekcha's :!: ... here da peekcha's :!: ... and explanation...
First I loosened and removed the left and right fenders, this also required the removal of the front grille and loosening of the front bumper...
In this pic, passenger fender removed, busy cleaning all the muck off with prepsol...
Pic of a section of the rust, after basic debris cleaning, in the exit hole: :shock:
Another pic of a section of the rust, after basic debris cleaning, under the exit hole sill: :shock:
During the initial cleaning I stuck a hose pipe into the water channel, take a look at all the muck that came out... scary... :wth:
Pics of the rust on the drivers side: :shock:
Then I stuck some towel inside the cabin, behind the holes, and whipped out the high pressure cleaner... only to find my dog Whiskey had found a new use for the cleaning machine... :evil:
Fixed the plug, killed the dog... drank some Whisky, and gave the wheel wells and the water channel an extra good clean :twisted: , then I left everything to dry... and then I whipped out the drill with wire brushes attached and cleaned off as much rust as I could find and get to... one of the problems I noted with these exit holes is that they are slightly higher than the lowest point of the water channel, therefore wet debris builds up behind the sheet metal in the corners of the water channel... my solution was to make another exit hole at the lowest point of the water channel in the corner :idea: , this extra hole should reduce the chance of rust accelerating debris building up in the channel... :wink:
How did I make to the holes? First I drilled 4 evenly spaces holes with 3mm drill bit, then I drill the 3mm holes out with a 10mm bit, and filed the remaining edges down... by making the extra hole on the drivers side I actually uncovered a nasty bit of rust in the water channel corner(right through into the cabin)... :shock:
I cleaned out the rust holes as best as I could, then used Duram NS1 rust converter and primer, on all the cleaned surfaces... I left this for a while to cure and dry and watched some of the Sharks/Blues game :thumbup: ... yes I got started early... once the NS1 was absolutely dry I painted the whole area with black Velvaglo, it goes on nice and thick, coats like tar...
Ag well it's so lekker painting, might as well do the whole wheel well... :P
Next step, seal off the holes with flash banding, tools used... a decent scissor... one roll of flash band... a carpet knife... a raco mini heat gun... :arrow:
Once the black paint was about 80% dry, tacky to the touch, but not wet... I measured and cut appropriate pieces of flash band, then I heated up the bitumen surface of the pieces of flash band with the heat gun and applied it to the holes... this stuff really works well...
Passenger side:
Drivers side(note the bigger extra hole because I needed to access and repair the rust hole in the corner):
Once the bitumen had cooled a bit I painted over the aluminium foil of the flash band with the black paint...
This is a time consuming job, depending on the state of the water channel exits, it could take about 6-7 hours to complete. I would advise all SFA owners to take the time to inspect these rust prone exit holes, and fix any rust found. It is possible to inspect the water channel exist without removing the whole fender, by just removing the plastic protectors in the wheel wells. If your lux has unexplained water leaking into the footwells this may well be the problem on your lux! It is also a good idea to remove the water channel cover, below the windscreen, once or twice a year, and clean the water channel out with a hose pipe, you'll be surprised how much muck and debris is stuck in there! For me the next part of the job is to remove the dashboard and remove/repair the rust found there... but thats another job for another time!
Oh, believe it or not, I changed the engine mounts as well today! :D:
B :thumbup:
hentey
Town: worcester
Vehicle: 2700i 4x4
Real Name: hentey pople
Sun Mar 08, 2009 7:30 am
For a SLUG to do that amount of work in one day!!!!! Unbelievable.Great job SLUG, sorry, BRETTON. I always admire people that can be so focused.Did you reassemble as well? Taking out the dash will be another ball game though. Unfortunatly it has to be done to get to the inside of the metal plates you have painted,right?
Now for the punchline........WHERE IS YOUR DOGGY AVATAR?............(traitor) :x :x :x
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Sun Mar 08, 2009 8:04 am
Thanks Hentey!
Another dog avatar implemented! Yip taking out the dash is the next step! It's not a difficult job but just another timing consuming project! I learnt another trick with the engine mounts as well... if you have suped up 4Y, like brospeed spec(exhaust/cam/flowed head) and fuel injection... the standard engine mounts seem to take alot more stick and sometimes fail... like one of them on my lux... the trick is to use the 2.4D's engine mounts(AutoQuip), they are much stronger than the standard one, weigh alot more as well... I put these mounts in, I had to rim the alignment holes on the shroud and mounting arms to 8mm, the original holes are 7mm, the 2.4D mounts alignment pins are 8mm, hence the need to drill it out... I struggled a bit to get the mounts back in and aligned to get the bolts though, especially on the exhaust side... but it done and she is much happier...
B :wink:
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Mon Mar 09, 2009 1:53 pm
I think the rest of you boys are in denial... This can't happen to my lux... hence 85 reads and only one reply :twisted:
Scorpion
Town: Emmarentia
Vehicle: 1988 Hilux 4x4 D/C with more attitude than Mike Tyson
Real Name: Johann
Mon Mar 09, 2009 2:16 pm
snipes wrote:I think the rest of you boys are in denial... This can't happen to my lux... hence 85 reads and only one reply :twisted:
What are you looking for a pat on the back? :twisted:
Anyway, great idea! I now have a new project to do. (was wondering what I'll keep myself busy with once my baby is finished)
1978 Land Cruiser HJ45
hentey
Town: worcester
Vehicle: 2700i 4x4
Mon Mar 09, 2009 4:13 pm
Dont worry Bretton,the guys are all busy inspecting their Luxes,and 95% will thank you cause that is a common problem on the sfa.I bet you Thys is one of them,thats why he's so quiet!!!!! 8 ) 8 ) 8 )
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Mon Mar 09, 2009 4:53 pm
Thys is still fuming cause of something that happened Friday afternoon! :twisted:
dalkill
Town: Cape TOwn
Vehicle: 2007 3.0 d4d DC 4x4
Real Name: Shaakir
Mon Mar 09, 2009 4:54 pm
I'm afraid to reply, in case it's case of from my mouth to Gods ears....
I already have few spots of rust.
had rust problem with my last lux, on the top corner of the window, at the join of firewall and fender.
Not looking forward to this ordeal again.
TOYOTA IS MY LEWE
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Mon Mar 09, 2009 4:56 pm
Dalkil your bakkie will be very prone to this based on the fact that it lives on the beach the entire weekend!
B
Spartan
Town: Vanderbijlpark
Real Name: Jaco
Mon Mar 09, 2009 6:34 pm
Bretton
This is a very handy piece of information thank you sir, on the 2.4D engine mounts we use them to mount the inline sixes (turbo and N/A) also in the Hiluxes and works like a charm.
:clap: :clap: :clap:
This info is so good I think we must call you OU GROOT UIL :twisted: :twisted:
Me and my boet had been loooking for this problem with the water in the cab for a few moons, never went as far as you.
MOBILITATE VINCERE
Spartan
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Mon Mar 09, 2009 8:27 pm
Snooping around Hoppy's workshop on a Friday, you can pick up a hell of a lot of tips and tricks... The okes a Hilux genuis(Alan paid me the say that... :twisted: )
B
Hoppy
Vehicle: Hilux SFA & IFS
Real Name: Allan 0721291160
Mon Mar 09, 2009 10:27 pm
Ja ou Snippies, wat doen jy saterdag?
BenHur
Vehicle: '96 D/C Raider
Real Name: Bennie
Mon Mar 09, 2009 10:41 pm
Hoppy wrote:Ja ou Snippies, wat doen jy saterdag?
Hy gaan jou kom lastig val. :wink:
ThysdJ
Club VHF Licence: HC102
Tue Mar 10, 2009 6:53 am
hentey wrote:Dont worry Bretton,the guys are all busy inspecting their Luxes,and 95% will thank you cause that is a common problem on the sfa.I bet you Thys is one of them,thats why he's so quiet!!!!! 8 ) 8 ) 8 )
Thys worry nie oor so ou bietjie roesies nie... Kaspaas se lyf het so hier en daar 'n roes-gewassie, maar daai sal uitgesort word as hy eendag sy full off-road kit en roll-cage aantrek.. tot dan toe sal hy hou.. :twisted: :twisted: :twisted:
Lama
Town: Hartbeespoort
Vehicle: Hilux '88 SFA
Fri Jan 15, 2010 8:24 am
Is this not only applicable to the chosen few who lives next to the coast?
I saw that RUSTYrod lives in slaap stad!
Anyway, my VW caddy bakkie also have that rubbery exit holes for water to escape that needs to be cleaned regularly!
I am still new to my SFA and will check it out, thanks!
"If you can't drove there, do it..." - Random oom in Orania
Stubs
Town: Onrusrivier Hermanus
Vehicle: 89, Hilux D/cab 3.0L V6 Ford !!
Real Name: Stuart
Wed Jan 27, 2010 1:09 pm
hi everyone, firstly new to the site and already I find it so useful, love this articale on rust, I have just stripped my truck and am now on the up hill task of doing the rust etc, at least some of the work I can do myself to save some bucks...am not looking forward to taking of the load bin to get to back of the cab and the load bay etc..I must say I really battle with the front window braces and along the top of the roof though...have attached a pic of my baby, however now its all off, roll bar/side bars to be galvanized, powder coated, roof racks off, KC hilites resprayed. and get all the rust fixed up !!! its a 89 model 2.2 petrol ...
Wed Jan 27, 2010 2:54 pm
Hi Stuart, and welcome to the forum! :thumbup: Nice pic .... I don't see any fishing rods .... what were you doing, whale watching?? :D:
Stubs
Real Name: Stuart
Wed Jan 27, 2010 3:05 pm
thanks alot... fishing can be quite good here...but the day in question the wind was blowing on shore hectic...so I did what i thought was the next best thing ! :angel:
Piesang
Town: Grabouw
Vehicle: '99 Hilux SRX d/c 4x4
Real Name: Pieter Pieterse
Wed Jan 27, 2010 3:24 pm
stubs5536 wrote:thanks alot... fishing can be quite good here...but the day in question the wind was blowing on shore hectic...so I did what i thought was the next best thing ! :angel:
:o: :o: :o: shooting at bottles on you r toys bonnet :?: :?: :?: ag no man... :lol: :lol: :lol:
Welcome to the forum
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Wed Jan 27, 2010 3:36 pm
Stuart welcome... if u make use of the information in this article it's going to cost you R 1800...
Yes R 1800... that what I paid you for the canopy and roof rack! Remember me??
Thanks for the canopy and roof rack... they've been doing duty very nicely!
mr b
Stubs
Real Name: Stuart
Wed Jan 27, 2010 3:40 pm
ha, ha hows it brett....glad to hear... you spray ya bakkie white ?? yep Rust .. got a mission ahead of me...plus I have a bent rear drivers side leaf !! hey ho....
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Wed Jan 27, 2010 3:55 pm
Zepplin(CT based) is selling a full set of OME leaf springs, in excellent nick... may be worth your while... check if the leaf purches aren't worn/bent... it's pretty common on a SFA... and there's instructions on how to fix it 100%! This I've still got to do on my lux!
Shoot I see the leafs are sold!
mr b
Adventurecentreco.za
Town: Winterton
Vehicle: 1992.2 D/C SFA
Real Name: Jakes
Tue Nov 02, 2010 9:07 pm
Hi all,,, allso new to the site. Talking about usfull information, daar's genoeg hie om n man mee besig te hou vi n lang tyd. Now allso the proud owner of a D/C Lux.(After the Lada experience....gapoe!) Stiped it down and gave it a respray myself (why pay a pro if u gonna scrach it). Scrached around under the cab and found some rust at the feet of the back passenger on the left. Was nicely hiden behind some flaky ould paint, but now there's a good reson to take those fenders off and fix the aireal after our Kalaharie trip.
Wed Nov 03, 2010 12:00 am
Hi Jakes and welcome to the forum! :thumbup: Why not go and introduce yourself here viewforum.php?f=137" onclick="window.open(this.href);return false;
and post a pic or three of your ride here viewforum.php?f=136" onclick="window.open(this.href);return false; For tips on loading photos .... viewtopic.php?f=21&t=10068" onclick="window.open(this.href);return false;
Enjoy the forum! ;-)
Town: Winterton
Real Name: Jakes
Wed Nov 03, 2010 7:32 am
Thanx 4 the advice Andy, need to learn how to drive this thing now:)
SYRON CONVERSIONS
Town: Tamboekieland
Vehicle: SFA HILUX
Real Name: SIMON
Wed Apr 13, 2011 9:51 pm
There is also another place that all double cab 4x4 owners must look at, this is at the bottom of the centre post from behind the front seats to the front of the rear seats, at the bottom you will find rust on most vehicles of this model.
A very well presented article and thank's for sharing it with us all, Admin please save and put it with the other interesting articles for future use.
simoan
Gunta
Real Name: Mark
Thu Apr 14, 2011 8:32 am
where are the pics :mrgreen:
Spartan
Real Name: Jaco
Thu Apr 14, 2011 10:32 pm
Gunta wrote:where are the pics :mrgreen:
Hello Hello weet jy nie waarvan hy praat nie :twisted: :twisted:
MOBILITATE VINCERE
Spartan
wakkjobb
Town: colorado springs
Vehicle: 85 4Runner
Real Name: Dan
Sun Apr 17, 2011 7:32 pm
Rust is bad over there too, eh? Check out what I have gotten myself into:
That tan lump is expanding foam... not helpful preventing rust:
...and that's just the right-side panel! THe left side is a little better, but not much.
>>Dan
krazy_kameleon
Town: Fourways
Vehicle: 1993 Hilux D/C 4X4 2.4 22R (fuel injection in the pipeline)
Real Name: Rick
Mon Apr 18, 2011 12:46 pm
that sucks Dan but it looks like you are doing a great job! -it will be well worth the effort, should be good for another 20 years to come
wakkjobb
Vehicle: 85 4Runner
Real Name: Dan
Wed Apr 20, 2011 5:27 am
Thanks! It's not mine; I'm doing it for a friend's dad who wants to keep it until the tires fall off. The money from this side-job is going towards rebuilding my new (for me) engine: a 3.4 liter 5VZ-FE. I have grand plans to get a supercharger for it since there is no way it'll be on the trail this year; so it is now a "slow build" for next season.
>>Dan
Wed Apr 20, 2011 5:43 am
Good luck with the project. :thumbup:
wakkjobb
Vehicle: 85 4Runner
Real Name: Dan
Wed Jun 01, 2011 3:24 am
Finished the right side this weekend; time to flip it over and do the other side... :tease:
>>Dan
rydaar rocky
Town: piketberg
Vehicle: hilux 4x4 sfa
Real Name: richard
Club VHF Licence: no
Mon May 21, 2012 10:54 am
NIIIIIIIICE.
beaut job
SideKick
Vehicle: Toyota Hilux '89 2.2 (4Y) EFI D/C 4x4, Mikem Suspension, PowerFlow Exhaust, BroSpeed Branch, 31" M/T, Long Range Fuel Tank, Front Diff-Lock
Real Name: Stephan
Club VHF Licence: X108
Mon Jul 16, 2012 6:00 pm
Where did all Bretton's pictures go??? :blink:
Stress: :irate: The confusion created when one's mind overrides the body's desire to choke the living $H!t out of some asshole that desperately deserves it!
Oupoot01
Town: paul Roux
Vehicle: 1991 Hilux SFA,7MGE,50mm bodylift
Real Name: Hentie
Sun Jan 12, 2014 7:55 am
thanks for the advise,im busy giving my sfa some tlc and painted the whole cab under the mats with stone chip and also stone chip under the fenders.There was luckily no rust but with the stone chip its sorted
Frontier 320
Vehicle: Isuzu KB320
Real Name: Garreth
Sat Jun 21, 2014 3:34 pm
Hows the rust fix holding up? normally once fixed it comes back over time...
barleigh
Town: Durban
Vehicle: 1995 2.4P Toyota Hilux Raider Dbl Cab - 22R
Real Name: Barend
Mon Aug 04, 2014 11:00 pm
Thanks for the advice. Definitely going to inspect mine when I get my SFA down to Durban.
Just bought it - a 1995 2.4L Dbl Cab Hilux Raider. Looks pretty rust clear as its been an inland car most of its life I believe.
But having lived in Durban I know how rust creeps up on you and attacks silently. Especially after seeing my first project car an old '72 VW beetle disintegrate over 2 years! Time for some diy work ;-)
DMH
Town: Durban
Vehicle: Nissan Hardbody & Patrol
Real Name: Tejan
Wed Aug 05, 2015 3:15 pm
whoa a lot more work than anticipated.. thanks for the write-up
Dadz Toy
Real Name: Richard
Club VHF Licence: HC 286
Sun May 15, 2016 10:42 pm
I have worsening rust on my A pillars and front doors above the stays.
Feels like I'm fighting a losing battle.
Any suggestions for chemical treatments?
R
Back from the Dead!
[img]
Tim86
Real Name: Tim
Fri Feb 23, 2018 10:35 am
Is there any way to view the pics of Mr_B's first post?
Fri Feb 23, 2018 11:27 am
Sjoe Tim, afraid not. It's a 9yr old post and somewhere along the line they have become orphaned from the thread and deleted. Maybe Bretton still has the pics and although not as active on the forum as he used to be, he still pops his balding head ( :twisted: :D: ) in here from time to time. With a bit of luck he might be able to re-post them for you. :winkx:
Fri Feb 23, 2018 8:37 pm
When Bulldog was resprayed some years ago, this is some of the muck that we found after removing the air-flow plate between the windscreen and bonnet:
I don't have any other pictures but those leaves were from the far corners (right & left) of the plate and they effectively blocked the water drains that Mr. B. is talking about. Luckily, no damage from rust was caused.
It's a good ideas to keep those channels clean, those leaves etc that collect there can do some serious damage if left unattended.
Tim86
Real Name: Tim
Tue Mar 20, 2018 8:06 am
I had some some solid rust holes in there that have consequently been patched up - is there any reason not to seal the openings on top? Air can get to the vent intake from the sides...
niclemaitre
Town: Stellenbosch
Vehicle: 87 DC 2.8D
Real Name: Nic
Tue Mar 20, 2018 8:14 am
I put fine SS mesh underneath mine to stop the crud getting in. Seems to work mostly.
Happy trails
Nic
SFA '87 DC "Rooies"
Tue Mar 20, 2018 9:46 am
This would be the better and even the easiest solution IMO. :thumbup:
Tim86
Real Name: Tim
Thu Mar 29, 2018 10:04 am
Done! Meshcape Industries makes the perfect SS mesh for anyone in the CT area.
Thu Mar 29, 2018 11:52 am
:thumbup:
    Users browsing this forum: Google Adsense [Bot]
