olie lig
chizz
Vehicle: hilux4x4 1989 dc 22R
Real Name: chris
Mon Oct 01, 2007 9:48 pm
Hi
Het vrydag n duur les geleer DIY werk nie vir almal nie.
Olie lig werk nie autoelek toets skakelaar in die blok foutief. Midas toe kry nuwe een
24` spander, breek hom in die blok af. Hex breek dit ook in die gaatjie af.
Enjin uit te haal R1900.00
weld of uitboor ?
Laat dit n les wees
chris
:cry:
Mon Oct 01, 2007 11:03 pm
Eina, dit is nie lekker nie.
SYRON CONVERSIONS
Town: Tamboekieland
Vehicle: SFA HILUX
Real Name: SIMON
Tue Oct 02, 2007 10:25 pm
please explain in English. :oops:
simoan
Scooter
Town: JHB
Real Name: Scott
Wed Oct 03, 2007 6:45 am
In short, Chizz had a problem with his oil light and found that it was the switch in the block.
After buying a new one, he attempted to replace it and had the unfortunate experience of breaking the switch off in the block. It then cost him R1900 to repair, because the engine must be removed to reach the hole. :shock:
Chizz, don't beat yourself up about it. Bolts break all the time and some times it's an inferior material and not the mechanic. :mrgreen:
