Removing Alternator 2.5 / 3.0 D4D
Wed Oct 28, 2009 8:24 am
Hi, I need to remove the alternator of my 2.5 D4D.
What I have done so far:
1) Disconnected battery
2) Removed airfilter housing connected to snorkel
3) Loosened alternator bolt
Now this is where I am stuck. The belt is holding the alternator and not sure how to release it! One of the pully's needs to be released....
Can anyone help?
Hannes.S
Town: 11
Vehicle: 111
Real Name: Hannes
Wed Oct 28, 2009 8:58 am
Werk die alternator nie op n verstelbare arm "bracket" soos die 4y's nie?
Wed Oct 28, 2009 9:03 am
Hannes, nee. Die pully langs die alternator is die een wat verstlbaar is, het ek nou uitgefigure. Maar daar is bitter min plek, so ek sal die water bottle nou ook gou uithaal! ....die chinks....
Tx
ORRA Call Sign: B15
Wed Oct 28, 2009 9:22 am
Jy kan altyd net die belt sny :shock: :shock: :shock:
Hannes.S
Town: 11
Vehicle: 111
Real Name: Hannes
Wed Oct 28, 2009 9:25 am
En dan weer vas welt as jy klaar is? Kan ok werk.... :lol:
0000DS
Town: Roodekrans
Vehicle: Tuna, 4X4, Longrange Fuel tank, BF's AT, Intergrated bumber, Roofrack, Awning, Air suspension,winch
Real Name: Danelle
Wed Oct 28, 2009 9:40 am
Toemaar, OOOOMS het reg gekom. Die alternator is uit. :thumbup:
Sal die happy snappies later pos :thumbup:
ORRA Call Sign: B15
Wed Oct 28, 2009 9:53 am
0000DS wrote:Toemaar, OOOOMS het reg gekom. Die alternator is uit. :thumbup:
Alternators hou nie van modder nie :shifty: :shifty: :D:
Dit sal gaan wees as jy fodies kan post van die before en die beafter en dan kan ons sommer sien watse brand altenator is in die nuwe wa's
Hoppy
Vehicle: Hilux SFA & IFS
Real Name: Allan 0721291160
Wed Oct 28, 2009 11:37 am
Hy het n "spring loaded auto tensioner" wat jy met n 14mm spanner na ondertoe swaai en dan haak jy net die belt af, jammer dis seker bietjie laat.
Wed Oct 28, 2009 12:07 pm
100% Hoppy, ek het reg gekom,
Dankie
Wed Oct 28, 2009 3:17 pm
Alternator skoon gemaak, al die modder and 1sq gras.....is nou uit. Ingesit en werk 100%.
Sal foto's en part nommers later pos.
Dankie :thumbup:
Bloues
Vehicle: Hilux 2.2 D/C
Real Name: Solly
Wed Oct 28, 2009 8:20 pm
Het jy 'n m @ e r gestrip ??
Waar is die foto's ????
Bloues
(Nie blou bul maar SHARKS ondersteuner)
Don't fence me in.....
'91 D/Cab 2.2(4y) AKA - Bloues. Lifted Suspension, Dual Battery, 80Liter Freezer, Bridgestone Dueler A/T, 29Mhz Radio, Mud Creeper Winch(Aus), EasyAwn Rooftop Tent, Roofrack, Garmin Nuvi, Long Range Fuel Tank, Jacks+straps for landi recovery.....
Wed Oct 28, 2009 9:14 pm
For the amatures like me, here is how it is done: on 2,5 D4D 4X4.
1) Remove battery terminals
2) Remove air filter and housing
3) Remove fan-belt
(Pully is springloaded and fanbelt can be loosened 14 spanner or socket)
5) Remove pully in front of the alternator. There are two bolts holding the alternator in place. One visible from the side and one underneath.
Strip and clean alternator.
Alternator part number:
Bosch 70
0 124 315 034 new part number now ends with 033
KCB1 - 14V 70A
27060 - OLO5O
Toyota
Regulator part number:
Bosch
BR14 - M2
F 00M 145 324
While the air filter and housing is out (something I have never checked) is a water / dust trap, under neath the housing! Clean it out. Mine was full of sand and bug's
Wed Oct 28, 2009 9:15 pm
Regulator Pic:
Bloues
Real Name: Solly
Thu Oct 29, 2009 6:26 am
Mark - vat hom eerder na Quanton toe next time - minder merke op jou hande he en bloedruk laer... :lol: :lol: :lol:
Bloues
Thu Oct 29, 2009 7:00 am
Ai Solly, as ek nie reggekom het nie sou ek dit gedoen het. Nou weet ek darem :thumbup: .
Oh ja, vergeet om the noem....moet nie jou air filter op die grond plaas, as jy hom uitgehaal het nie. Toe ek week kyk het my 6 maande oue 'staffie' die splinter nuwe (R260.00) air filter in 50 stukke geskeur..... :thumbdown:
Sy het obviously gedink dit was 'n ou een :lol: :lol: :lol: Ek het haar mooi laat verstaan dit was nie.....
legend35
Vehicle: Hilux 2700i
ORRA Call Sign: HC262
Thu Oct 29, 2009 7:58 am
Mark ,sy wou maar net help.Sy het seker gedink sy moet hom uitmekaar haal om skoon te maak.
Hilux2Hilux
Vehicle: Toyota Hilux
Real Name: Derick
Fri Mar 25, 2011 1:14 pm
Mark,
Het jy die alternator afgehaal net om skoon te maak?
Was daar enige iets wat jou besluit het om dit te doen? Soos liggies wat brand wat nie moet brand nie.
Hoekom ek vra is ek het 'n probleem op my lux waar die battery liggie sommer aangaan terwyl ek ry. Gewoonlik nadat die bakkie warm gery is +- 30 km of so.
Gewoonlik gaan hy weer af na 'n rukkie.
Maar soms bly hy sommer lank aan van Zambezi tot by Umoya.
Derick
Hilux 3.0 D4D, OME, Duel Battery, PBE Charger, Long Range Tank, GME300,ARB Bullbar and Winch, Replacement Rear Bumper, Bakkie Slide and Water Tank
Fri Mar 25, 2011 1:28 pm
Hilux2Hilux wrote:Mark,
Derick
Hi Derick, ons het innie modder gespeel en die modder het die 'bushes' laat sticky raak. Dis die eintlike rede......een was permanent teruggetrek.
Joune klink soos 'n diode wat voutief is, soos die probleem met Cassie s'n onlangs.
Fri Mar 25, 2011 1:31 pm
Lees meer hier:
viewtopic.php?f=3&t=17367&hilit=alterna ... leem+diode" onclick="window.open(this.href);return false;
Hilux2Hilux
Real Name: Derick
Fri Apr 01, 2011 6:33 am
More Mark,
My 3.0 D4D het blykbaar 'n Denso alternator en nie 'n Bosch nie.
Sou dink die 2.5 en 3.0 het dieselfde alternators in maar blykbaar nie.
Derick
Fri Mar 09, 2012 11:45 pm
OK, just an update on my alt. to keep the thread together:
The past few months my alternator has been playing up / sorta screeches now and again(not the belt noise, but more a bearing noise) but comes and goes every now and then. Tested it and found 13.8 Volt constant.
So this week I stripped it again, and found he bearings were no that fresh any more. So before attacking it with a 10 pound hammer, I decided to take it in to Motolec, in Krugersdorp. Dropped it off at 08h00 and by 14h00 it was ready for collection, efficient I may add. R450.00 for the two bearing & labour.
But.....when I got there, Chris - the owner advised me that the Alt. clutch was also not to good. Luckily he had a new one and I advised him to replace also R295.00.
So got home and replaced the 'refurbished alt.' - no problem!
Measured the alternator and now giving 14.25 Volt!
Great :thumbup:
Brand
Vehicle: Hilux 3.0 D4D 4x4
Real Name: Gerbrand
Mon Mar 12, 2012 5:49 pm
So vir ons wat nie so lekker weet nie, waar meet mens die volts. Op die alternator of op die battery se pole? As jy se alternator, wys asb 'n prentjie want sover ek weet is dit nogal diep weg gesteek. Dan, waarmee meet jy dit? Sommer met so multimeter vanaf adendorffs?
http://www.tooltime.co.za/DynamicData/P ... DM-850.jpg http://www.tooltime.co.za/ProductDetails.aspx?id=813" onclick="window.open(this.href);return false;
of is daar ander voorstelle?
Mon Mar 12, 2012 5:56 pm
Brand wrote:So vir ons wat nie so lekker weet nie, waar meet mens die volts. Op die alternator of op die battery se pole? As jy se alternator, wys asb 'n prentjie want sover ek weet is dit nogal diep weg gesteek. Dan, waarmee meet jy dit? Sommer met so multimeter vanaf adendorffs?
Gerbrand......as ek weer daai alternator moet uithaal om 'n foto te neem gaan ek........kots..... :roll: :roll: :roll:
Nee wat, die maklikste is op jou battery pole, daar behoort nie veel veskil te wees nie tensy jou drade m@ertoe is nie.
Jy meet dit met 'n multimeter, nie mid@S special nie (hulle hou nie) sommer 'n Major-Tec is goeie waarde vir geld :thumbup:
Brand
Real Name: Gerbrand
Mon Mar 12, 2012 6:04 pm
OOOOMS wrote:as ek weer daai alternator moet uithaal om 'n foto te neem gaan ek........kots..... :roll: :roll: :roll:
En dan sal jy 'n paar ander plekke ook moet skoon maak :blink:
Gedink dis te veel moeite om die alternator self te meet. Sal bietjie uitkyk vir die Major-Tec
Dankie
Mon Mar 12, 2012 6:07 pm
Net onder in jou straat, is daar 'n nice een!
Town: Bellville
Vehicle: Langpad (RAV4)
Mon Mar 12, 2012 6:25 pm
mooi stel fotos.
dankie vir die raad
Mon Mar 12, 2012 6:32 pm
ChrisF wrote:mooi stel fotos.
dankie vir die raad
:thumbup: :thumbup: :thumbup:
Town: Bellville
Mon Mar 12, 2012 7:59 pm
Kyk nou weer na daai phodies ... daai blou pype ... intercooler ??
Mon Mar 12, 2012 10:03 pm
ChrisF wrote:Kyk nou weer na daai phodies ... daai blou pype ... intercooler ??
It R, yes :thumbup:
Brand
Real Name: Gerbrand
Tue Mar 13, 2012 8:06 pm
OOOOMS wrote:Net onder in jou straat, is daar 'n nice een!
Sal maar 'n draai moet kom maak en loer...
Tue Mar 13, 2012 8:12 pm
Jy's welkom, jy weet mos!
