Rotating the SFA for use in Nissan conversion
- Town: Brits
- Vehicle: Land Rover
- Real Name: Jakes
Manne and Maninne:
The American Nissan IFS guys do a Solid Front Axle conversion in several ways, among these are:
1) Use a Jeep axle with LHS pinion and the standard Nissan transfer case
2) Rotate a Hilux SFA front diff so that the pinion is on the LHS
Now I have read a partial article where such a Lux SFA is rotated:
1. Cut off diff cover. Its pretty thin, apparently takes 5 minutes with a 115mm grinder.
2. notch the third member flange in the housing for the ring gear. The third member drops in without any notching, but maybe notch for safety
3. 4 studs, 2 at the top and 2 at bottom of the third flange need to be relocated. Remove the studs, weld up the holes and grind flush.
4. Install third upside down on the six remaining studs. use a transfer punch to mark the center. Remove the third and drill/tap the new stud locations.
5. After that just spin the balls/swivels ~180 (lloking for a write-up)
6. Then swap the knuckes side to side, and weld the cover back on(or a pipe cap)
Please don't flame me or anything for this process, I unashamedly stole it. But I need somebody to confirm if this is possible.
Lastly: is a 4.1:1 (or round about that number) ratio available for these diffs? If so, approximate cost?
- rock solid
- Town: Grand Junction
- Vehicle: 85 extracab
- Real Name: philip
Re: Rotating the SFA for use in Nissan conversion
thats how its done, and 4.10to1 gear ratio is the most popular gear ratio in toyotas
if u want to spend some $$ check out www.diamondaxle.com for a custom built housing
- Bfreesani
- Town: Roodepoort
- Vehicle: Nissan Sani 2.7TD
- Real Name: David
Not much $$ to spend, so thats why we are asking about goodies that would be local and easy to get hold of
Later....
David
Hillbilly
David
Hillbilly
- Town: Brits
- Real Name: Jakes
Philip, what are you doing on a South African Hilux forum?
So you can confirm the method? Any links to photos? I'm struggling to picture the process......
- Town: Brits
- Real Name: Jakes
By the way, most 4-banger SFA Hiluxes in SA run 4.88:1 ratios. We didn't get the 6-cylinder engines over here.
Colorado......
Jeez, that's far from our patch of earth.
Colorado......
The same could be asked of yourself, Nissan Jakes ...jakeslouw wrote:Philip, what are you doing on a South African Hilux forum?
- Town: Brits
- Real Name: Jakes
Maybe because I'm trying to inject some Toyota culture into my Nissan?
(dit was 'n doelbewuste gatkruip.....)
Of course you know that you're more than welcome here!jakeslouw wrote:Maybe because I'm trying to inject some Toyota culture into my Nissan?
- rock solid
- Real Name: philip
- Town: Brits
- Real Name: Jakes
Thanks Philip, that's where I got the process that I posted.
Sounds like a lot of trouble for a 55" axle? The Nissan axles are 59" at least.
- rock solid
- Real Name: philip
how about adding a few inches to the short side, making it 61.5" wide
http://www.pirate4x4.com/forum/showthre ... ttin+wider
- Town: Brits
- Real Name: Jakes
I'd rather use a Jeep axle and avoid all the expense.
Over here, the dealer spares people aren't called "stealers" for nothing.......
