Hi All
I am about to upgrade my existing 2009 Hulux for the 2012 shape -
I need to move my long range tank to the new vehicle, is this a simple job or do I need to take it to a fitment center to do the job.
Does any one know of any instruction manual that is available?
Thanks in advance
Neil
Long range swop (Kzn)
- Town: Kloof
- Vehicle: Hilux GD6
- Real Name: Neil
Thanks in advance
Neil
Neil
Re: Long range swop
Hi Neil, you have to look into the following:
They usually cut into the filler pipe approx. 15cm from the neck. (You would want to swap the 2009 and the 2011 around.) taking the one from the previous vehicle.
The other issue is there is a gravity feed pipe from your existing LR tank to your main tank, which would not be standard on your 2011 model.
So if you are a bit of a handy-may, you should not have a problem, otherwise pay the R500.00 odd rands and have it done
- Town: Kloof
- Real Name: Neil
Re: Long range swop
Who would be best to do the swop in the Durban/Pmb area
Neil
Neil
Thanks in advance
Neil
Neil
Re: Long range swop
Sorry, unabble to assist you here, perhaps some of the KZN can assist?neilh@webhouse.co.za wrote:Thanks
Neil
- Johannes van die See
Re: Long range swop (Kzn)
Neil
The best instruction manual is named "Hilux4x4 Forum"
I'd say if you're a confident DIY'r, do it yourself it is simple pipe work, nothing to it, just keep fire hazards
in mind seeing that you're working with fuel lines.
Fitment of the tank to the new Hilux shouldn't be a problem either, modified mounting brackets are easy to make and you only have three pipes to modify, breather, filler and gravity feed, that's it.
Use the forum, works every time!
Good luck.
Good luck.
