Cyclone Air Intake servicing: V6 owners
Dirka
Town: Doornpoort Pretoria
Real Name: Dirk
Mon Jul 18, 2016 3:27 pm
This is a simple task that takes almost no time at all.
Came across a friend's Prado 120 the weekend, and reminded me to have a look at my own.
We sometimes forget (Like myself) or maybe just don't know about it.
(Like the Toyota service centres) [Mine was serviced by Toy 1700Km ago]
So here's what you must do ever so often when the bonnet is open:
Have a look and find the air intake assembly (On drivers side)
At the bottom of the inlet tube is a rubber discharge valve. (Marked in the red circle)
What you need to do is squeeze the valve so that it's 'mouth' opens to let all of the ugly stuff come out.
You can also simply unhook and it slides off.
Have a look at that!!
I decided to disassemble mine and make sure all is ok.
It is a simple 2 min jobbie.
Unscrew the 2x clamps shown in the red arrows.
You also need to open and detach the air filter assembly.
(Unhook the 2x clips, slide forward and out sideways)
Unscrew the 2x 12mm bolts for the cyclone tube. (marked with the 2 x red arrows)
Now you can slide the tube out and remove the bracket bolts.
Here is a picture of the inside.
I had a big leaf stuck right next to the cyclone 'fan' blades on the intake side.
(Which may cause all sorts of problems)
Ok..so this is how it works:
The air sucked in by the engine passes through the cyclone 'fan' blades.
This causes a swirl in the airflow and results in the bigger bits and pieces to be pushed to the sides of the tube.
At the end of the tube you'll notice a sort of 'resess' or 'catchment chamber' that works almost like a funnel.
All of the dust and leaves and stones and stuff exits through the outlet port and into the dust discharge valve.
You also need to ensure that the water exit hole is clean and open. (Marked with yellow arrow)
This here (marked with blue square) you need to detach and make sure it is clean.
It is not a water trap or a dustbin from hell like mine was.
It is called an air intake resonator.
It's purpose is to baffel the air intake noise by slowing down and streamlining airflow and also
provides some performance abilities.
I don't know yet if it is adjustable by turning, but I just put it back like it was,
with the part number pointing towards the front of the vehicle.
And that's it!
I hope this may benefit some.
Regards
Dirk
” ― J. Kintz
Town: Bellville
Vehicle: Langpad (RAV4)
Mon Jul 18, 2016 3:37 pm
Dankie Dirk
mossie89
Town: Paarl
Vehicle: Toyota Hilux D/C 4x4 4.0 v6
Real Name: Riaan
Mon Jul 18, 2016 4:21 pm
Dankie Dirk, mooi volledig met prenties
Shimano
Town: Strand Cape Town
Vehicle: Hilux 4.0 V6 4x4
Real Name: Wynand
Club VHF Licence: HC125
Mon Jul 18, 2016 5:21 pm
Dankie Dirk ek gaan n bietjie kyk na myne ook. :thumbup:
Toyota Hilux 4.0 V6 4x4
Mon Jul 18, 2016 10:27 pm
Jong, daai Cyclone teorie klink maar suspect!
Het alle V6 Vigo's daai cyclone dingetjie in?
ahmedoo
Town: pre
Vehicle: toyota fortuner
Real Name: ahmed
Mon Jul 18, 2016 10:41 pm
I see when my snorkel was fitted that cyclone was removed I don't know if that can be a problem but I'm going to check the cleaning in the morning
Dirka
Real Name: Dirk
Tue Jul 19, 2016 1:26 pm
Thabogrobler wrote:Jong, daai Cyclone teorie klink maar suspect!
- :cooldude: Dis maar hoe hy werk Thabo..
(Google hom gerus)
- Ek weet nie. Maar as ek 'n klip innie donker moet gooi,
dan ja - al die 1GR-FE behoort te he.
Beste is om op toyodiy.com te gaan, gooi jou vin nommer
en soek vir die 17730 part no.
17730-0P010 PreCleaner Assy, Air W/Hose.
” ― J. Kintz
Dirka
Real Name: Dirk
Tue Jul 19, 2016 1:27 pm
ahmedoo wrote:I see when my snorkel was fitted that cyclone was removed I don't know if that can be a problem but I'm going to check the cleaning in the morning
I was wondering the same thing with snorkel fitment.
But I see Ironman (as example) keeps the cyclone pre-cleaner intact.
If I had to choose, I would do that also.
Here is a cut from their installation manual.
You can download the pdf on the link below.
https://www.google.co.za/url?sa=t&rct=j ... 8174,d.d24" onclick="window.open(this.href);return false;
” ― J. Kintz
Return to “Useful Articles”
    Users browsing this forum: Baidu [Spider]
