Wheel Spacers good or bad?
Bliksempie
Town: Pretoria Montana
Vehicle: 2.4 SFA
Real Name: Robbie
Club VHF Licence: HC115
Fri Jul 22, 2016 8:32 am
Good to know.
http://www.fourwheeler.com/how-to/1110o ... rs-safety/" onclick="window.open(this.href);return false;
When Life knocks you down, make sure you fall on your back. If you can look up, you can get up
Froll
Town: Vioolsdrift
Vehicle: 1995 2,4 D/C Hilux SFA 4X4 , 2010 4.0 V6 Fortuner 4x4
Real Name: Roger
Club VHF Licence: N/A
Fri Jul 22, 2016 10:49 am
Very interesting, thanks for sharing. :thumbup: :thumbup:
Bliksempie
Vehicle: 2.4 SFA
Real Name: Robbie
Fri Jul 22, 2016 10:52 am
:thumbup:
Fri Jul 22, 2016 11:06 am
Weet van iemand sin wat veroorsaak het dat sy studs af gebreek het en amper sy lewe gekos het
Fri Jul 22, 2016 12:00 pm
As much as I would like to widen my wheel base a bit, I would rather look for a deeper dish (bigger offset) rim than to fit spacers. Just don't trust them.
Knuppel
Town: White River
Vehicle: '87 SFA HILUX D/CAB
Real Name: Marius
Fri Jul 22, 2016 12:03 pm
Spacers wat breek is nie reg gemaak of vas gemaak nie!!!. Omdat daar n nuwe stel studs bygevoeg word gebruik die manne pirate of aftermarket studs wat nie die ekstra kragte kan hanteer nie. As jy spacers gebruik maak seker dat die nuwe studs dieselfde as die OEM op jou voertuig is!
Hanteer ook die spacers op dieselfde manier as alloy rims. Die toyota Owners manual sal jou se dat na n 1000km moet die wiel moere weer oor vasgemaak word anders kom hulle los! Dit beteken dat jy die wiel moet afhaal en die spacer weer vas draai. dan sit jy die wiel terug en as hy alloy is dan moet jy na n verdere 1000km hulle ook weer vas draai. As die wiel moere op n wiel met n spacer loskom breek hy sonder om te waarsku mors af!!!!!!
lukestoyzx
Town: Griffith
Vehicle: 07 Hilux SR5
Real Name: Luke
Fri Jul 22, 2016 2:39 pm
Bad news! Probably why they're illegal over here! Just buy the correct wheels to start with!
Johan Kriel
Town: Okahandja
Vehicle: 2.5 SC 4x4
Real Name: Johan kriel
Fri Jul 22, 2016 5:19 pm
Also depend on the on the axle such a full floater, referring to the rear axle mainly. One must make sure that the spacer sits tight on the drum, debris etc must be removed first.
Johan Kriel
Prado
Return to “Useful Articles”
