Garmin - Suction Cup fix
About a year ago I asked if anybody could assist me in finding a new suction cup for my Garmin Quest bracket that sticks to the window. This was because it bonded to the window so well that it was pitted when I removed it and after that it kept falling off because it lost "traction" on the window glass.
As I could not find a replacement suction cup without having to part with lots of cash, I came up with another idea. I got hold of a little piece of "sticker" vinyl, cut it to the same size as the suction cup and peeled off the backing paper. Then I stuck the vinyl to the suction cup. The bracket has now been on the window for quite a while and it still sticks. When I remove it nothing stays behind on the window any more either.
It could even be a good idea to stick the vinyl onto a new suction cup before it gets stuck to the window to prevent it from bonding with the window too closely. The vinyl can be removed from the suction cup without too much hassle if it needs to be replaced, although I can see why you would want to.
Re: Garmin - Suction Cup fix
Thys
This idea of your really sucks dude
Aw, Ben ... don't be such a stick in the mud.
What does sticks and mud got to do with the fact that his idea sucks :roll: :roll:
Not being tight lipped, and at the risk of sticking my head out further, I would say, at a thumb-suck that Thuys' idea has solid merit. :)
That still does not explain the mud. I don't think you are intended to have mud on the inside of your windscreen :wth: :wth: :problem:Mud Dog wrote:Not being tight lipped, and at the risk of sticking my head out further, I would say, at a thumb-suck that Thuys' idea has solid merit. :)
It does doesn't itBenHur wrote:Thys
- Niel
- Real Name: Niel
Avnic het my so pas verwys na n handelaar siende dat hulle nie met individue besigheid doen nie. Ek het dieselfde probleem met alby die suction cups, nou wil hulle he ek noet nog een koop ...... :evil: :evil:
- Niel
- Real Name: Niel
Avnic gaan nie help in hierdie opsig nie en jy kry ook glo nie die "rubber deel" los te koop nie :evil: :evil: :evil: Eric do you have any suggestions
Niel, kom kuier daar by my dan maak ek dit gou vir jou reg, gratis, verniet en vir niks nie.. Dis nou as jy nie omgee om Brakkenfell toe te kom nie..
Nee iemand moet brood op die tafel sit... is jy nou op pad die boendoes in?
- Niel
- Real Name: Niel
nee, toe ek die jobbie wil gebruik verlede Vrydag toe neek die ding weer die hele tyd af en toe strip my dinges sommer weer van voor af .....
Jou snob :roll: :roll:Kaspaas wrote: Dis nou as jy nie omgee om Brakkenfell toe te kom nie..
Nee Niel, al probeer jy hoe hard kan jy nooit die woorde "Brakkenfell" en "snob" in dieselfde sin gebruik nie... ons ouens is hopeloos te Kômmin... (met 'n hoofletter K en 'n kappie op die O)..
Nice solution Oom Thys
Can we make this a "sticky" please :shifty:
- Niel
- Real Name: Niel
Jy moet ligloop daar is n hele paar ouens wat in Brackenfell bly hulle gaan jou wil tik vir daai statement
hulle moet maar kom try... ek bly al langer as hulle almal daar...
- Town: Kathu
- Vehicle: 2.4 Hi Lux 4x4 DC 95'
- Real Name: Eben
- Club VHF Licence: ZS3EP
Thys jou idee is puik en dit sal werk as die rubber al stukkend is. Wat ek doen voordat ek die rubber laat plak is om so bietjie lip ice of sonroom aan die rubber te smeer, dit gee daardie lube wat nodig is asook dit laat nie die rubber vasklou aan die ruit nie. Na gebruik is daar so klien vetkol wat ek sommer met 'n lap skoon vee. Julle kan dit maar probeer dit werk ook goed.
Eben Pienaar
2.4 Hi Lux 22R 95'
2.4 Hi Lux 22R 95'
