RECOVERY POINTS
mytruck
Town: Little Falls
Vehicle: Hilux 4x4 3D
Real Name: Stefan
Thu Jun 17, 2010 3:18 pm
Hi all
Being new to the 4x4 game this site has given me so much info/tips and reading pleasure and would like to say thanks to all who respond so efficiently. Need some help on this one. I have a 2009 Hilux 4x4 Raider. I have read that when towing or trying to recover a vehicle with a rope/strap or winch that there are strategic "Recovery" points that one should use. Great but am not sure where they are. Checked the manual and am sure that the ones on the front are the ones to use, but what about on the rear of the vehicle. Forum has advised using the towbar is a big no no, which I can understand. So do I have have these fitted as an aftermarket thing or am I just blind - :shock:
Thu Jun 17, 2010 3:24 pm
Ideally recovery points must be directly on the chassis and in line with the chassis.
Thu Jun 17, 2010 3:28 pm
Usually fitted after market direct to chassis or to a sturdy bracket which is fitted to the chassis. Most integrated bumpers / bullbars / towbars will have recovery points built in. :wink:
Stef
Vehicle: '98 LTD
Real Name: Stefan
Club VHF Licence: X107
Tue Aug 02, 2011 1:48 pm
Just wondering...if I were to fit recovery hooks to the chassis in the rear, can I slip the bridal strap between the valence & towbar seeing that the chassis is higher than the towbar?
ThysdJ
Club VHF Licence: HC102
Tue Aug 02, 2011 2:13 pm
You could do that Stefan, but make sure that when the bridle pulls tight, it wont damage the valance. You must also make sure there are no "sharp" edges that could damage the bridle strap. :thumbup:
Tue Aug 02, 2011 2:23 pm
Somewhere on the forum are pics where I show how I drilled big holes in the tow bar brackets, if you cant find it I will post new pics
GeorgeJvR
Town: Louis Trichardt
Vehicle: 1998 Prado 3.4 V6 A/T, 2005 Vigo 3.0 D4D 4x4 ARB- protection plate -B/Bar -T/Bar, ONCA sliders, Winch, snorkel, Chipped; 1997 SFA D/C met 3.0 KZ TE motor.
Tue Aug 02, 2011 2:29 pm
Contemplating having some of these made
Kom wat wil ek bly 'n Bul!
george
Vehicle: Prado 90 VX 3.4 V6
Club VHF Licence: HC107
Tue Aug 02, 2011 2:37 pm
GeorgeJvR wrote:Contemplating having some of these made
Vry nice.i like that
Tue Aug 02, 2011 2:42 pm
viewtopic.php?p=8480#p8480" onclick="window.open(this.href);return false;
Stef
Vehicle: '98 LTD
Real Name: Stefan
Tue Aug 02, 2011 3:16 pm
pietpetoors wrote:viewtopic.php?p=8480#p8480
Saw that one yes, any issues with bending upwards? Will it be legal for the AAWDC fun day?
More like what I want, trick is to mount them to the SFA's rear :problem:
ThysdJ wrote:You could do that Stefan, but make sure that when the bridle pulls tight, it wont damage the valance. You must also make sure there are no "sharp" edges that could damage the bridle strap. :thumbup:
Thought of that, but I guees one could damage the valence with the strap under the towbar as well, although there is that gap between the two that gives one some leeway.
Tue Aug 02, 2011 3:57 pm
Stef:
I welded a piece if flat bar on the two bar bracket, underneath the chassis. This prevent the tow bar from moving upwards when you use it
Black Sam
Town: Pietermaritzburg
Vehicle: Toyota Hilux 4.0 V6 4x4 Double Cab.
Real Name: Gerrie
Wed Aug 03, 2011 7:54 am
Jy het nie dalk daardie tipe recovery hake beskikbaar nie?
Stef
Vehicle: '98 LTD
Real Name: Stefan
Wed Aug 03, 2011 8:14 am
pietpetoors wrote:Stef:
Cool tx :thumbup: Will definitely be some added protection for the bolts...
Royco
Town: Stellenbosch
Real Name: Roy
Club VHF Licence: X88
Wed Aug 03, 2011 8:18 am
I like these :
viewtopic.php?p=8480#p46786" onclick="window.open(this.href);return false;
Then you never have to worry about shackles (or shackle missiles!!) :thumbup:
Image Image Image Image
Stef
Vehicle: '98 LTD
Real Name: Stefan
Thu Aug 04, 2011 9:12 am
Het gisteraand gou die towbar afgehaal en die loods gate geboor...
Dis omtrent waar die shackle gaan hang
Thu Aug 04, 2011 9:29 am
Sal later 'n kiekie gaan vat, maar ek het toe in episode 2 van die recovery points twee washers/bushes ook bygesweis om die plaat dikker te maak, bloot net om die shackle meer stabiel te hou sodat hy nie heeltyd so heen en weer wieg nie. Die bushes se ID is dieselle as die gat wat ek geboor het, sy wand so 6mm dik en die ding is ook so 10mm dik. Dit gee net 'n breer skouer.
So as jy dalk iemand ken wat daagliks by 'n draaibank verbyloop kan jy sommer dit ook bysit.
Stef
Vehicle: '98 LTD
Real Name: Stefan
Thu Aug 04, 2011 2:25 pm
pietpetoors wrote:Sal later 'n kiekie gaan vat, maar ek het toe in episode 2 van die recovery points twee washers/bushes ook bygesweis om die plaat dikker te maak, bloot net om die shackle meer stabiel te hou sodat hy nie heeltyd so heen en weer wieg nie. Die bushes se ID is dieselle as die gat wat ek geboor het, sy wand so 6mm dik en die ding is ook so 10mm dik. Dit gee net 'n breer skouer.
Ek het daai update gesien, dink dis waar jy die t/bar brackets korter gemaak het...anyway..dis die plan, maar ek is lus om 2 bushes te maak elk 25mm lank, dan boor ek 'n gat die OD van die bush in die bracket, druk deur en weld altwee kante.
Wil sommer dieselfde trick trek op die bullbar se OEM gate :thumbup:
GeorgeJvR
Thu Aug 04, 2011 2:34 pm
Stef ek het die selfde plan maar wil 'n 5mm brace teen die bracket vas sit (weld / bout) met 'n punt wat op die chassis ook vas bout,
dan 'n pyp vat en tussen die twee brackets sit "horisontaal" net vir support as ek dalk 'n LR teen 'n angle moet recover in plaas van loodreg.
Stef
Vehicle: '98 LTD
Real Name: Stefan
Thu Aug 04, 2011 3:01 pm
Die LTD towbar het klaar 'n lekker brace in...kyk die eerste foto, en jy't klaar 2 pype tussen in. As jy so ver wil gaan sou ek sê jy moet braces oorkruis insit maw van chassis links na t/bar regs :think:
GeorgeJvR
Thu Aug 04, 2011 3:26 pm
:think: Klink my ek dink net vir my self werk uit :think:
Stef
Vehicle: '98 LTD
Real Name: Stefan
Thu Aug 04, 2011 3:41 pm
GeorgeJvR wrote::think: Klink my ek dink net vir my self werk uit :think:
:acute: :mrgreen:
Stef
Vehicle: '98 LTD
Real Name: Stefan
Tue Aug 09, 2011 8:46 am
Manne, bietjie hulp asb. Het bushes laat draai teen R220 vir 4 ; nou wil die karakter my nog R300 vra om die goed vas te weld... en ek wil dit nie eintlik met die inverter weld nie, of dink julle dit sal OK wees? Is daar iemand hier in Pta met 'n CO2 welder wat my kan help voor Vrydag vir 6 koues of so? :beg: Gaan intussen maar die Supa Quick ook vra.
Bestaande gate voor:
met die bush in:
Stef
Vehicle: '98 LTD
Real Name: Stefan
Thu Aug 11, 2011 2:47 pm
Gate geboor in towbar; bushes ge- 'tag'. Gaan vanmiddag by die exhaust plek draai.
george
Thu Aug 11, 2011 2:49 pm
Lyk lekker sterk.Launch jy 'n Ski-boot met daai tow ball?
Stef
Vehicle: '98 LTD
Real Name: Stefan
Thu Aug 11, 2011 2:54 pm
george wrote:Lyk lekker sterk.Launch jy 'n Ski-boot met daai tow ball?
Ek wens! Sukkel nog om die bakkie te betaal :blushing:
GeorgeJvR
Thu Aug 11, 2011 3:01 pm
:thumbup: Ek sal maar steel met die oog :thumbup:
Stef
Vehicle: '98 LTD
Real Name: Stefan
Mon Aug 15, 2011 9:53 am
GeorgeJvR wrote::thumbup: Ek sal maar steel met die oog :thumbup:
aag ek vertel jou sommer, daai voorste gate in die LTD bullbar is 40mm ;-)
Het 35mm gate in towbar geboor; bushes almal 25mm dia binne
GeorgeJvR
Mon Aug 15, 2011 10:02 am
:thumbup: :wave:
Stef
Vehicle: '98 LTD
Real Name: Stefan
Mon Aug 15, 2011 10:09 am
O ja, kry iemand wat kan CO2 weld, nie jou local exhaust plek nie....daar is 'n rede hoekom hulle net exhausts weld :twisted:
Die punte is darem "of the better ones I've seen" volgens ORRU scrutineers :angel: :mrgreen:
