Foldable Sand Tracks - Grip 'n Go
ORRA Call Sign: X27
Mon Feb 20, 2012 5:08 pm
I got hold of these foldable sand tracks called Grip n Go
Made from durable HDPE plastic and tested to take 4 tons (or was it 4.5 tons, cannot remember, lets play it safe and say 4 tons). The steel pin is EN8 steel
Comes in a set of two
Total length extended: 1130mm
Folded dimensions:
L = 390mm
W = 220mm
H = 110mm
Weight = about 3.1 Kg
It sells for R950.00 per set at www.4x4direct.co.za
I know the first argument will be that you cannot use it as bridge, but I like the fact that they do not take up much space.
Traveler
Vehicle: Pathfinder 2.5 LE AT
Real Name: Heinrich
ORRA Call Sign: X81
Mon Feb 20, 2012 5:19 pm
That is a brilliant design.
Know what you don't know.
ORRA Call Sign: X27
Mon Feb 20, 2012 5:21 pm
That was also my first impression
If my bag lady can keep up with the workload I am going to see if she can also make me some bags for it.
Bushwacker
Town: Vryheid Natal
Real Name: Piet
Mon Feb 20, 2012 6:02 pm
pietpetoors wrote: bag lady
:shock:
Niel
Real Name: Niel
Mon Feb 20, 2012 11:47 pm
Dit lyk goed Pieter
Mountain Man
Town: Ekurhuleni
Vehicle: Land Cruiser 79 Series 4.5 EFi
Real Name: Craig
Tue Feb 21, 2012 1:08 pm
I think it is cheaper to lower tyre pressure.
ImageIf You Don't Have a SFA, You Don't Have An Offroad Vehicle.
Shumba138
Town: Villeurbanne
Vehicle: None
Real Name: Stephanie
Fri Jun 12, 2015 1:08 pm
Have you tried them yet?
Cause they are FAR less expensive than the MAXTRAX so might be a good solution...
