IFS Rock sliders and steppies.
- GeorgeJvR
- Town: Louis Trichardt
Well seeing that my previous DIY item was in Wegry, i wanted to give the other magazine chance, unfortunately i don't hear any thing from them ...
Gerrie let me know if you want this...
Seeing that I could not find a decent rock slider to fit my needs I decided to build my own, as I needed the slider and a stepping plate for the shortys.
After I did my research I took to the drawing bord
Welding the sliders to the chassis, did not fancy me that much. Therefore this design was best for me. The rear of the slider I used some existing mountings On the driver side you have the Brake lines running next to the chassis rail, remove one or two clips holding the pipes and use it to space the pipes from the chassis. At the fuel tank you need to inspect where the brake pipes goes and place you mounting in such a position to just clear all. Next I cut the square tubing to the correct length, and used these supports to get the level and placing , in order for me to start with the mountings
Remember to disconnect your battery when welding on a vehicle.
Next was the round tubing and 90 degree bends, and a test fit.
Kom wat wil ek bly 'n Bul!
- GeorgeJvR
Re: IFS Rock sliders and steppies.
Once every thing was tag welded in place, I Welded it solid, test fitted it again and then it was of to the painters.
What materials did I use;
50mm Square tubing 3mm 6M R365
48mm round tubing 2mm 6M R161
48mm 90 degree weld-on bends x4 R40.00
60mm flat bar 8mm 6M R246
M8 HT bolts and nuts R40
For the stepping plate I could not get off cut 4mm alu plate, there for used a mild steel checkered plate, I bought an off cut piece for R120.00
Galvanizing and cut for the stepping plate R350.00
Painting R450.00
Next was the checkered plate, I had it cut and galvanized, unfortunately I did not like the color so I had it painted in an alu color paint.
Painting R450.00
- Ali3n
- Town: Roodepoort
- Club VHF Licence: B338
Looks good George but just a quick question. That flat bar you used to bolt do the sliders to the chassis, wont it bend? Why did you not go with rectangular tubing?
PRESENTLY DISADVANTAGED
- HennieO
- Town: Bellville
- Vehicle: '98 Hilux DC 2.7;2012 MB ML350;2016 MB C220 BLUETEC; 1999 VW GOLF 1.6; VW Caddy P/V
- Real Name: Hennie
TOP JOB!!
- MOFASA
- Real Name: Johno
- Club VHF Licence: X119
Nice job.....
How long did it take?
Did you powdercoat it?
[rimg=206x128]
[rimg=206x128]
- GeorgeJvR
Alien
I can lift the lux with my high-lift jack with only 3mm movement on the steps
Space for the rectangular tubing is limited.
Thanks Hennie
Johno
To long say 2 weeks+/- weekends and one day of leave at the office
Normal spray paint.
Thanks Hennie
Johno
Normal spray paint.
- Ali3n
- Town: Roodepoort
Cool. It looks damn good. Well done.
- MOFASA
- Real Name: Johno
So when you taking another day leave on a monday or friday. Want to know when to order mineGeorgeJvR wrote:Alien
Thanks Hennie
Johno
To long say 2 seeks+/- week end and one day of leave at the office
Normal spray paint.
[rimg=206x128]
[rimg=206x128]
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
- Club VHF Licence: X117
Lyk baie lekker
- GeorgeJvR
Sorry Johno you're on your own here
- Club VHF Licence: X93-
Welgedaan George - Dit lyk baie mooi
- 4x4Maniac
- Town: Centurion
- Real Name: Werner
- Club VHF Licence: X120
Lyk baie nice... Nou moet jy nog n stel bou vir myne :p
Het nie die highlift points gesien nie, waar jack hy op?
ORRA CALLSIGN X120
AKA Epsilon on 4x4Community
(2011 JKUR)
Rugged Ridge Light Guards
KC Spotlights
Previous:
(2011 JKUR)
KC Spotlights
Previous:
- GeorgeJvR
Werner
Ek druk sommer die highlift jack onder die slider in as ek hom wil optel.
- GeorgeJvR
As ek die tyd gehaat het sou ek hulle gebou het en weer ge-smous het, maar dit is tyd wat ek eerder aan ander dinge wil spandeer.
Sorry manne.
Sorry manne.
- Polarbear2008
- Real Name: Theunis
- Club VHF Licence: X49
George
Het jou bakkie daai voorste mudflaps gehad? Of het jy dit later opgesit?
Myne het rubbers aan weerskant van die gewone step wat onder die wheel arches sit en sodoende het dit nie voorste mudflaps nie. Ek hou van jou ontwerp! Wel gedaan!
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
- GeorgeJvR
Theunis ek het hom so met die mudflaps gekoop
- 4x4Maniac
- Town: Centurion
- Real Name: Werner
Mmm nie eers daai musflaps gesien voor nie, sal vir myne ook voor wil kry, agterstes behoort voor op te pas as ek so vinnig kyk... Enige iemand wat n xtra stel het?
ORRA CALLSIGN X120
(2011 JKUR)
KC Spotlights
Previous:
(2011 JKUR)
KC Spotlights
Previous:
Very nice George, looks very strong.
- MOFASA
- Real Name: Johno
GeorgeJvR wrote:Sorry Johno you're on your own here
Still look good might chande the design on mine a bit....
[rimg=206x128]
[rimg=206x128]
- GeorgeJvR
If it wasn't for the shorties i would to
- Polarbear2008
Ek sal moet uitvind of hulle anders is, want ek het onlangs na een gekyk wat dit ook op gehad het, en daar is n gat in die halfronde deel (wat na die deur se kant toe wys) waar daar n grommet of skroef ingaan. ek vermoed die vorm is soortgelyk maar die 100% dieselfde nie.
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
- MariusF
- Vehicle: Toyota Fortuner 3.0
- Real Name: Marius
Baie nice!!
Ek hou nogal van die Replacement bumper...het jy hom ook gebou?
- GeorgeJvR
Marius ek het hom by Nudge-M gekoop
- Town: Alberton
- Vehicle: Fortuner
- Real Name: James
welgedaan,lekker om so handig te kan wees.
