I need some help/advice from the electronic gurus please....
I have one of the "earphone jack" type pin thingies that I have to push in quickly before I can start the bakkie. You do not have to leave it in....I was thinking of taking that thing out and replacing it with one of those very small 6mmx6mm tact/tacktile momentary button switches and hide it somewhere.
Will it not do the same job in this instance? The difference being out of sight. My logic tells me I'm just replacing a switch with another switch.
Thank you in advance
SFA immobilizer/anti theft device modification
- ôita
- Town: Piet Retief
- Vehicle: 1994 Toyota Hilux D/cab 4x4 SFA, 3RZ conversion,TrailGear Duel Transfercase with 4.7gear,Front & Rear Difflocks,2" Lift,OME & Mikem Suspention,Snorkel,L/R fuel tank, 32" M/T tyres, my son in the passenger seat
- Real Name: Kobus
"Stronger than a New Zealand Kauri tree and, as we found out, virtually indestructible, the Hilux is an unapologetically manly car." - Top Gear Verdict
- Cleaner
- Real Name: Ernst
- Club VHF Licence: X31
Re: SFA immobilizer/anti theft device modification
It could work, depending on how advance the electronics of the Immobilizer system is. If it is just 'n closed circuit contact that needs to be present momentarily, then it will work, but I have seen some of those earphone type plugs that is more complicated.
They have a resistor of specific value inside and unless that value registered is the same, the immobilizer won't switch. This is to prevent the circuit from just being closed by bypassing the "dongle". You can test this by opening the part where you plug the headphone jack in, the female side and short the pins on the back out with a short wire. If the vehicle can still start, then it is just a closed circuit contact and you can put in any type of switch you like to close the circuit momentarily to start the vehicle.
- ôita
- Town: Piet Retief
- Real Name: Kobus
Thanx Ernst...
