Hulp - wie het 'n bead breaker...
Posted: Tue Oct 18, 2011 8:48 am
by Gerrie
Hi ouens. Ons soek 'n bead breaker (daai tipe wat jy onder aan 'n Hi-lift jack se poot sit om die bead te breek) vir 'n paar foto's oor hoe om 'n band af te haal.
Wie in die Kaap kan my help? Asseblief!!
Re: Hulp - wie het 'n bead breaker...
Posted: Tue Oct 18, 2011 5:15 pm
by Bushwacker
Jy kan die hi lift direk op die band sit en jack, miskien 2 of 3 keer langs mekaar tot dit mee gee :thumbup:
http://www.youtube.com/watch?v=6Ou6YaT5AJM
Posted: Tue Oct 18, 2011 5:31 pm
by george
Of ry/trap hom af met die bakkie :dance1: Moet natuurlik net eers die spaar opsit
Posted: Wed Oct 19, 2011 7:44 am
by Royco
Personally, I would NOT use a HiLift jack.
Looking at these pictures makes me think....
viewtopic.php?f=14&t=18203" onclick="window.open(this.href);return false;
Posted: Wed Oct 19, 2011 8:16 am
by Gunta
You can buy a bead breaker from 4x4 Megaworld. There is nothing wrong with a high lift jack. The problem is you get idiots that don't know how to use it properly. If you know how to use it , it is the most valuable piece of equipment with more uses than a swiss army knife.
Posted: Wed Oct 19, 2011 8:20 am
by Royco
Gunta wrote:You can buy a bead breaker from 4x4 Megaworld. There is nothing wrong with a high lift jack. The problem is you get idiots that don't know how to use it properly. If you know how to use it , it is the most valuable piece of equipment with more uses than a swiss army knife.
I would fall into the camp of "idiots that don't know how to use it properly", so I would not use it to de-bead.
Guess I need to learn... :blushing:
Posted: Wed Oct 19, 2011 8:43 am
by Gunta
Roy, don't feel bad, one just needs to go on a course to learn how to operate it properly when you buy one. It can be extremely dangerous in the wrong hands. Alot of the stuff is common knowledge, the problem is not everyone has common knowledge. You should ask Thys to do a course down there on how to use a high lift jack.
Posted: Wed Oct 19, 2011 8:58 am
by Gerrie
Soos my Pa altyd sĂȘ: Common sense ain't common...
Ek sal dit ook nie self probeer as iemand my nog nie gewys het nie, maar dan kom die groot vangplek.
As dit jou enigste opsie is in die middel van die bos, dan kom die kennis dat dit wel werk tog handig te pas... :blackeye: Pasop net vir die handle wat terugswaai!
Posted: Wed Oct 19, 2011 9:25 am
by Gunta
One thing to remember with a high lift jack is NEVER use one hand.
Posted: Wed Oct 19, 2011 12:54 pm
by ThysdJ
Gunta wrote: it is the most valuable piece of equipment with more uses than a swiss army knife.
I beg to differ Mark... it cant peel a potato... :twisted: :twisted: :twisted:
Posted: Wed Oct 19, 2011 1:24 pm
by Gerrie
I reckon if you strike a hi-lift with the right type of stone, you can get a spark to start a fire? Truly remarkable...
Ons het nou maar besluit om die foto's te neem sonder die tipe bead breaker. Dit is in elk geval nie iets wat jy algemeen kry nie.
Posted: Wed Oct 19, 2011 2:43 pm
by Gunta
No but you can make mash potato. :lmao:
Posted: Wed Oct 19, 2011 2:47 pm
by Gerrie
If you don't use the jack correctly, you can also make tenderised face (very much like tenderised steak!)
Posted: Wed Oct 19, 2011 6:36 pm
by Theodorus
Ek is n man met n plan maar het myLUX seer gemaak omdat ek nie my hi lift jack geken het en na hom gekyk om hom uit te figure nie soos ek normaal maak nie ek stem saam vat n tyd en leer hom
I am here: http://maps.google.com/maps?ll=-26.013559,28.025077" onclick="window.open(this.href);return false;
Posted: Thu Oct 20, 2011 7:49 am
by Gunta
You get tenderised face because people use one hand and when that handle slips you are in trouble. One should always keep some Q20 so you can spray the moving parts everytime you use it because they get sticky and will cause an accident if it jumps out.
Posted: Thu Oct 20, 2011 12:58 pm
by ThysdJ
Gunta wrote:it is the most valuable piece of equipment with more uses than a swiss army knife.
you can also not use it as a toothpick, or a nail file... :twisted: :twisted:
Posted: Thu Oct 20, 2011 1:23 pm
by Gunta
You dont need it in Cape Town because you okes have no front teef. :lmao:
Posted: Thu Oct 20, 2011 1:28 pm
by ThysdJ
Gunta wrote:You dont need it in Cape Town because you okes have no front teef. :lmao:
you leave my teef out of it... we do have fingernails though... :twisted: :twisted: :twisted:
Posted: Thu Oct 20, 2011 1:42 pm
by Gunta
he he :lol:
