Spot Light Lens covers
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Hi Guys.
I got my Hella spotlight clear lense covers today from Midas.Thanks F_D you mentioned it in one of the other threads.This protect the spotlight lenses when driving on dirt roads.
Re: Spot Light Lens covers
George, can you post a pic. Is it so clear that you can use the spot without removing the cover?
Can one buy these spots separately or can one buy the lenses separately. My one spot's lens has a small hole in.
- george
- Town: Velddrif
Hi Piet
Have a look at F_D's toys.His got a picture there.viewtopic.php?f=2&t=77&start=0
They are transparent and you keep them on when using.I think it is a very clever idea.
You buy then seperatly at Midas.They go for R98.50 each.
Regards
Regards
What size fuse do you have on your spots? Mine has a 20 AMP fuse and it seems as if blows like once a month. I could not see a short circuits on the wiring, all I can think off is that it is too small
- george
- Town: Velddrif
Hi Piet
I am not sure.It is the standard ones it came out with.Are yours running via a relay?
- Cookie Monster
- Town: Port Elizabeth
- Real Name: Justin
I had a look here in PE but they dont have at the local Midas
Hi Piet,
Midas can indeed supply you with clear lens covers. I had posted the part numbers before, but it does depend on what size spots you have. The photo referred to viewtopic.php?f=2&t=77&start=0 has the clear lens covers fitted - you can't even see them!
What size globes do you have in your spots? A 20A fuse would certainly be strong enough for two 55W globes, but marginal if there are two 100W globes wired to just one fuse. Start-up current will weaken the fuse before eventually blowing it. If you have 100w globes and both go through the same fuse, then 25A should suffice. If that blows, then you have an intermittent short circuit somewhere along the line.
CM, nor did our local branch, but they ordered hem for me and even delivered them to me the next day, before 11:00. That was SERVICE!Cookie Monster wrote:I had a look here in PE but they dont have at the local Midas
- george
- Town: Velddrif
Same here.I went on Friday and they did not have.They ordered for me and it was here on Sathurday.Great service
Pieter
Here's a link to a write up I did and Eric moderated on wiring of spotlights. Can you PDF it and put it on here as well.
http://www.4x4community.co.za/forum/sho ... php?t=8006
- Cookie Monster
- Real Name: Justin
I think i need to order mine :)
- Niel
- Real Name: Niel
Hi Piet
From your bakkies picture it seems like hella commets. Contact Midas in Parow (they have the warehouse) the other might not have and will have to order from Parow for you. When I bought mine 2 months ago it was R 68 per cover.
