OK
Ek is nuut in die Toyota wereld, ry al 25 jaar Land Rover en het verlede jaar vir die baas in D/C D4D 4X4 laat kry en ek het 3 weke terug die S/C 4X4 D4D gekry, so spaar my in paar oomblikke
Ek het gister in Hi Lux met Camil suspensie gesien, as die vraag al vantevoregevra is vergewe,
Het vandag Camil laat sit op die Jag Cruiser laat sit weens prys en beskikbaarheid,
Wat is die algemene opinie oor Camil?
Camil Skokbrekers
Re: Camil Skokbrekers
I met a guy in Cape Town who SWEARS BY his Camil shockers, reckons they're a better ride than OME
He's just been up to central africa and back in his SFA DC Hilux
He's a real nice guy (as are all Hilux drivers!) if you wanna give him a call his name is Pat Bailey and his cell is: 074 112 4468 or Cape Town (021) 6894981
You can tell him that Rich the Electrician gave you his number.
Cheers
Rich
Cheers
Rich
I think it depends on your application, some guys says yes others no, I personally would not fit them since I have seen a vehicle or two with them that bounces and looses traction when climbing up steep inclines.
The original springs and the coils sometimes have different spring tensions and the work against each other. Then also the shock mounts were not originally designed to take the ekstra strain of the added spring to the shock, and I remember reading about a guy on some forum a while ago who's shock mounts broke off in the rear while carrying load. I have also seen on some vehicles that they also limit articulation as the shocks they use limits downwards travel as they are too short.
- Niel
- Real Name: Niel
Iknow Fransdw2002 alsao has it fitted on his 2.5, sc 2007 and he is very happy with it.
See topic: viewtopic.php?f=1&t=453&p=10780&hilit=c ... ion#p10780
