New clutch
michael01
Town: Gauteng
Vehicle: 1995 Hilux
Real Name: Michael
Tue Jun 12, 2012 12:03 am
Hi guys
Just a little help here please, I need to get a new clutch put in my dads 2000 Hilux DC 4x4 what do you guys recommend as a replacement? I have heard that Luke is a good brand? Is there anything else i could look at?
Also i noticed driving today that the speedo needle jumps up and down while driving need to get this looked at as well, where or who would i take this to get fixed?
i stay in the south of JHB close to Alberton, Any help would really be appropriated guys
thanks
Tue Jun 12, 2012 12:37 am
Go with the Luk - Repco clutch .... a lot of the stealers repack these as OEM parts. The speedo needle is most likely because of a 'hurt' cable, if it's got a kink or if it's been re-routed to create a sharp bend it will cause the needle to jump.
Tue Jun 12, 2012 8:21 am
The jumping needle can also be due to a speedo cable which is on its way out, just before the cable snap they tend to do that.
LUK or Sachs for the clutch
quickie
Town: Durbanville
Vehicle: Hilux 85'
Real Name: Sean
Tue Jun 12, 2012 9:21 am
I was always one for keeping my Bakkie original, I had a heavy Duty Toyota Clutch Fitted years back, at 160000km, at 349000km it showed no signs of wearing out in a hurry.
My speedo Cable started, bouncing replacing it is cheap, simple job to replace too... (once the dash/clock section is removed)
LouisZ
Tue Jun 12, 2012 10:36 am
Luke is fine :thumbup: The speedo cable like said can be going.
LouisZ
Tue Jun 12, 2012 10:38 am
On these Toyota packs a nice Sachs clutch kit in their Toy boxes. Only way how to say if it is OW Toyota if there is stamped in AISIN.
quickie wrote:I was always one for keeping my Bakkie original, I had a heavy Duty Toyota Clutch Fitted years back, at 160000km, at 349000km it showed no signs of wearing out in a hurry.
michael01
Town: Gauteng
Vehicle: 1995 Hilux
Real Name: Michael
Wed Jun 13, 2012 12:00 am
Thanks Guys
Taking it to a friend this next week to get the gear box checked out, also will pick up a speedo cable, that i'll see if i can get from Gemini parts???
thanks again for the advice
LouisZ
Wed Jun 13, 2012 11:10 am
Gemini will have!
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Wed Jun 13, 2012 11:17 am
Before going to the expense of replacing the speedo cable, try cleaning/re-greasing it. My SFA's speedo also jumped, a good clean of the inner cable and lube fixed it 100%.
If the cable is anything like the SFA one, then you can detach it on the gearbox side and remove the inner cable without having to disassemble the dashboard.
    Users browsing this forum: Google [Bot]
