New Member Looking for some info
- Town: Welkom
- Vehicle: 3000TD D/C
- Real Name: Jacobus
Hi guys im new to the forum joined recently
I Recently bought a 2000 D/C 3000TD with 325 000 Km on the clock but i want to find out what is the most common problems with them?
A guy told me earlier that i made a mistake as the head on the 3000TD cracks easily?
Any more info on these bakkies would be appreciated
Thank you
Thank you
- FIRSTGEER
- Town: King WilliamsTown
- Real Name: Tony Geer
- Club VHF Licence: HC 109
Re: New Member Looking for some info
Welcome Jacobus.The current odometer reading should bear testament to the engines reliability but then one doesn't know the engines history of the engine as far as previous repairs are concerned.Good luck and enjoy the vehicle.There are very few other brands of engines to have that mileage.
Welcome Jacobus!
As far as I've heard, the heads can give problems, but much depends on how the vehicle has been treated. If it's worked hard consistently carrying heavy loads or towing, or hammered, that's not good. A FSH would help to determine the vehicle's history and how it's been treated. If it doesn't already have one, fit and EGT gauge and drive it conservatively - you might get another 325K kilos. Enjoy it!
Welcome Jacobus. The fact that the engine is on 325,000Km and is still going strong says to me it's been looked after well. Hope it give you many more happy kms and memories!
- Pumba
- Town: Durbanville
- Vehicle: Toyota Hilux 3.0 D4D 4x4
- Real Name: Kobus
- Club VHF Licence: HC112
Welkom Jacobus
Ek het ook al gehoor van daai probleem maar ek het nog nooit iemand raakgeloop wat dit mee gebeur het nie.... Geniet die bakkie!
Jesus was blunt: "No chance at all if you think you can pull it off by yourself. Every chance in the world if you let God do it." Mark 10:27(Message)
The heads on turbo diesels crack when they get too hot while towing or if it is driven like a racking car.
If you treat it nicely and remember that it is in fact a diesel it will take you another 300k km.
The Prado 120 shares the 3000 turbo diesel engine of the KZTE, ie just before the D4D range.
My neighbour has this Prado.
the head cracked and was replaced. Think it cost something like R12k. Thus actually a cheap item to fix.
The guys go for the AMC (?) head ....
If memory serves my right, even Hoppy had to replace the head on his 3000 diesel.
- Haboob
- Town: King Williams Town
- Real Name: Edge
- Club VHF Licence: HC129
+1
Look after her and drive a Diesel like a farmer and not like a racing driver and you should get many more kilometres out of her...
+1
HABOOB means "Dust Storm"
- Town: Roodepoort
- Vehicle: Toyota Hilux KZ-TE
- Club VHF Licence: L4
Hi Jacobus. Baie welkom.... ek het 'n goeie vriend in die vervoerbedryf met 'n 2001 model en hy sleep gereeld swaar sleepwaens met onderdele Wes-Kaap toe.... syne staan op 460,000.... enjin nog nooit oopgemaak nie!
Jy kan die advies oor die EGT meter gerus ter harte neem! Ek het self een op myne (202,000 kms) en sorg maar altyd dat hy nie oor 700 gC gaan nie, maar hy kom slegs hier naby as ek sleep teen lang hoogtes...
As jy mooi agter hom kyk gaan hy agter jou kyk...!
Grondpad Alliepad!!!
- Town: Welkom
Mud Dog wrote:Welcome Jacobus!
Dankie vir die terugvoer!!
Die bakkie dink ek nie is hard gery nie want dis n ouerige man se bakkie gewees wat iewers in die Noord-Kaap op n plaas was,bak agter mekeer niks nie net verf wat hier en daar af is!!
Wat diensrekord aanbetref is in sy boekie net n paar keer gestempel op 20 000,60 000 120 000 en toe op 200 000km
Neem aan hy is self gediens.Wat die EGT guage aanbetref het hy nie een nie,waar kan ek een kry en wat is die prys min of meer?
- Town: Welkom
Dankie vir die terugvoer!!EchoMan wrote:Hi Jacobus. Baie welkom.... ek het 'n goeie vriend in die vervoerbedryf met 'n 2001 model en hy sleep gereeld swaar sleepwaens met onderdele Wes-Kaap toe.... syne staan op 460,000.... enjin nog nooit oopgemaak nie!
Dit stel my darem bietjie gerus dat daar n paar van hulle is met nog hoër kilos as die een!!
As ek die EGT meter het waar sit ek die guage?
- Town: Welkom
- Town: Welkom
Dankie vir die terugvoer!!Haboob wrote:Welcome Jacobus. The fact that the engine is on 325,000Km and is still going strong says to me it's been looked after well. Hope it give you many more happy kms and memories!
+1
Sal hom soos n boer ry want dit is immers n boer se bakkie gewees!!
Beplan om enjin oor n paar maande oor te laat doen net vir veiligheid
- Haboob
- Real Name: Edge
Don't fix it if it aint broken...
You can do things like timing chain and a complete grease & service...
If there are oil leaks, then replace the seels and check the wheels for play (movement that may indicate wheel bearing problems)...
Check that all the mountings are still fine & that all the nuts & bolts are properly tight, then you should have another 300 000 km's left in her...
If you want to fit an EGT then it will set your mind at ease...
ENJOY...
ENJOY...
