Hi there
i just bought an LED Spotlight bar and i am not sure where to fit it. i got two fitment spots in mind, under the nudge bar or on top of the roll-bar. kindly advice on whether there will be a diffence in lighting quality depending on the mounting spot ? the bar is about 70cm
MOUNTING LED SPOTLIGHT BAR
- Alex2539
- Town: Walvis Bay
- Vehicle: HILUX LEGEND 45 V6 4.0 4X4
- Real Name: Alex
Bonded to Yotas
Re: MOUNTING LED SPOTLIGHT BAR
Hi Alex. Generally the higher you mount it the better light coverage you will have. Also it would be less prone to be damaged tan if it were mounted low down under the nudge bar.
Personally I would try position it at a similar level to the standard headlights.
- coetzer94
- Town: Pretoorsdorp
- Vehicle: Silver Hilux DC 2.8 GD-6 2016
- Real Name: Vian
I mounted the bar behind the bumper and lower grill so its nice and protected, the grill does not affect lighting.
- antlo69
- Town: Pretoria North
- Vehicle: Toyota Hilux 3.0 D-4D, leveling kit, 17" with A/T BFg's, sadly stil some Tupperware, wish list growing by the day
- Real Name: Antonie
[img]//images.tapatalk-cdn.com/15/11/30 ... 6fa7b4.jpg[/img]
This is what I have done to SWAMBO'S Hilux.
Used two L shaped brackets that I have mounted onto the slam track behind the bumper.
"Must be a Toyota, must be a diesel and must run on BFG's"
Also speak to the guys at CYMOT.
They may (should) have some photos of installations and options ....
- Alex2539
- Town: Walvis Bay
- Real Name: Alex
Bonded to Yotas
- Alex2539
- Town: Walvis Bay
- Real Name: Alex
Added up placing it on the nudge
Sent from my GT-I9190 using Tapatalk
Bonded to Yotas
