2013 SRX 16''steel rims and tires sizes
pieta.swanepoel
Vehicle: Toyota Hilux SRX 2.5D-4D 4x4 SC
Real Name: Pieta
Thu Apr 20, 2017 1:45 pm
Hallo,
question regarding tyres for my 2013 SRX with OEM 16' steel rims: what would be the widest recommended tyre one should fit on these rims?
Spec is 205/80R16, alternative is 235/70R16
I would like to fit decent tyres with 75 or 80% profile and stronger sidewall, but am not sure if it will fit the steel rims? Not really looking for wider but higher. And not really looking for a lift either.
245/75R16 tyres seem to be more available?
Else, I should start looking for mags
Thank you
Pieta
Kortbroek
Town: Stellenbosch
Vehicle: 2.5 d4d 4x4 Hilux
Real Name: Hendrik
Fri Jun 02, 2017 11:28 am
Hi Pieta
Stel jy nog belang om mags op jou bakkie te sit?
Ek het tans "16 x 8.5 zero offset Aline Rims" op my bakkie. Ek sal verkies om dit terug te verander na die staal rims toe.
Indien jy belangstel kan ons dalk ruil.
Farmerbrown
Town: Mooi River KZN
Vehicle: 96 SFA D/C 4x4 2.4
Real Name: Malcolm
Fri Jun 02, 2017 4:35 pm
I got a set of second hand 15" toyota rims and put the 31" tyres on. When I had my hilux . Or else just go with the 245/70 R16 .
2.4 1996 SFA D/C
2.5 2015 hardbody 4x4 S/C
2013 Everest 4x2
2.5 2012 AWD Kuga(SOLD)
yz250 2 stroke
tw 200 farm bike
pieta.swanepoel
Real Name: Pieta
Sun Jun 04, 2017 9:30 am
Hendrik, 8.5" wydte rims is te wyd vir my. Soek iets soos 7" want is op soek na hoer profiel band. En dan moet ek breer band ook vat. Miskien is 15" rims die beter opsie
Frontier 320
Vehicle: Isuzu KB320
Real Name: Garreth
Sat Jul 01, 2017 12:32 am
pieta.swanepoel wrote:Hendrik, 8.5" wydte rims is te wyd vir my. Soek iets soos 7" want is op soek na hoer profiel band. En dan moet ek breer band ook vat. Miskien is 15" rims die beter opsie
I've got a set of 16 inch rims (they are LX Isuzu rims, very well sort after and 265 75 16 BF muds.
Send me a message if you keen for them .
Hilux Heap
Town: Brakpan
Vehicle: '93 Hilux Raider 4x4 DC. Basic offroad frt bumper with Warn Tabor 9k winch, Roll bar, Towbar, std half door fiberglass canopy with roofrack. 2x 65 lt fuel tanks, 31x10.5R15 HT tyres
Mon Jul 03, 2017 10:41 am
Hi Pieta,
I have the 15" white rims on my 93 Hilux DC 4x4. Running 30x9.5x15 BFs (245/70/15). The BF has a higher sidewall than the Wrangler and the Coopers. Might be what you are looking for. The 9.5 is only 245 wide and sidewall180mm high. You can even try the 31x10.5x15 BF (265/15, wall 200mm) or 32x10.5x15 BF (265/15, wall 210mm).
Hope this helps.
Image,Image
Town: Bellville
Vehicle: Langpad (RAV4)
Mon Jul 03, 2017 12:22 pm
Piet ek dink nie die 15'' pas op die 2010 en ouer Vigo's nie.
My SRX, 2010 model, het uitgekom met 16'' staal rims.
Ek het later 245 bande opgesit
Leonb
Town: Nelspruit
Vehicle: Toyota hilux 2.5 D4D 4X4 DC SRX
Real Name: Leon
Mon Jul 10, 2017 2:25 pm
Hi Pieta
Hi i have 16" steel rims if you are interested
send me a pic of you rims if you still have them
Kortbroek
Town: Stellenbosch
Real Name: Hendrik
Thu Jul 13, 2017 10:02 am
Hi Pieta
Hi Leon. Ek stuur vir jou 'n PM
