Fridge Idée
- Gertc
- Vehicle: 3.0L Fortuner
- Real Name: Gert Combrink
- Club VHF Licence: Xray05
Fridge Idée
Lus om te speel?! of is dit Sukkel?
We all love driving your 4x4’s. What is more relaxing than to drive with a cold one in the hand (cold coke that is.) But how do you keep it cold? Well you can buy it cold or you try and keep it cold yourself.
So I bought myself one of these hot/cold cooler boxes. The inside is just big enough to keep 6 “coke” from boiling on the cold setting. And Small enough on the outside so that it will fit nowhere in the Hilux. And uses 5AMP’s Plus. No way to keep it running when the engine is switched off, unless you like to push or jump start your 4x 4.
Well I was thinking of removing my centre console between the 2 front seats and replace it with a compressor driven fridge. The idée is to extend it all the way to the back seat.
That will give you space for 10 x 500ml “Coke’s “ or +/- 20 cans or 2 x 2L cokes laying horizontal.
The compressor will be a 12v Danfoss compressor or one of the Engel swing motor types. Both of them use less than 3Amps. And will be mounted behind the back seat.
The Evaporator will be mounted between the cab and the loading bin. You should get enough ventilation to cool the refrigerant.
And if you fit 2 x 7a/h batteries you should get about 4 hours of cooling when the vehicle
is parked and dad have to wait for mom to finish her shopping. Or you went for a tour at Table Mountain.
Ok let me have it now. Good or Bad idée?
Re: Fridge Idée
Gert, the idea itself might not be too bad, but I would be a little apprehensive about locating the condenser (the evaporator is the one inside the box) in the gap between the cab and load-body. This area is prone to becoming choked with leaves / twigs which would restrict airflow. I also think that a lot of heat rises through this gap, coming from the exhaust and under the cab from the engine. Ideally one would like to keep all the refrigeration components close together for efficiency, so that location would be good from this aspect. how big would this condenser be?
- Scooter
- Town: JHB
- Real Name: Scott
Re: Fridge Idée
The idea is great and if you could make a smaller compressor (only big enough to run this size unit) it would be even better.
If planning to use the BD35F, it is a large compressor, coupled with all the electronics, I dont see how you would fit it in. :?
- Town: Kathu
- Vehicle: 2.4 Hi Lux 4x4 DC 95'
- Real Name: Eben
- Club VHF Licence: ZS3EP
Re: Fridge Idée
Wel Gert as dit werk sit ek my bestelling nou al in vir een....
Al nadeel is dat jy nie moet van plan wees om jou bakkie te verkoop nie
Eben Pienaar
2.4 Hi Lux 22R 95'
2.4 Hi Lux 22R 95'
- 2.8 d/cab SFA
- Town: Boksburg
- Vehicle: Yamaha R1
- Real Name: John
- hentey
- Town: worcester
- Vehicle: 2700i 4x4
- Real Name: hentey pople
Re: Fridge Idée
ALTERNATIVE......... Buy a 200 cruiser.Standard equipment.But then ,who wants to drive a fuel guzzler like that..... I think that is reason enough to try your idea.Go for it!!!!! :roll: :roll: :roll:
Re: Fridge Idée
Gertc wrote:Lus om te speel?! of is dit Sukkel?
i think it's a great idea Gert, have a go :!:
is there any chance you could increase the internal height a little to accomodate dumpies, they taste better than cans
- Gertc
Re: Fridge Idée
Thanks I’m already busy with the template for the fridge. I will try and get some pictures.
This is something I have to build.
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
- Club VHF Licence: X117
Re: Fridge Idée
Great idea,
But after all the time, effort and money! Wouldn’t it be better to just go with an Engel? I know its hard work getting out your van for a beer, but think about it, it a proper fridge so it ice cold beer!!! And you don’t need a dual battery system. Fit a lighter plug in the back of your van connected to your main battery with a fuse. Job done!!!
I fitted a dual battery system in my old man’s Hilux for his Engel. Now I know that the Engel draws so little that we could have done without the dual battery system.
- Scooter
- Town: JHB
- Real Name: Scott
Re: Fridge Idée
Wayne, indeed they do draw a very small amount of power for what they are doing, but doing without a dual battery system to run it is probably the worst idea. That is unless you only plan on using the fridge while you are driving. Stop over somewhere for two days, in a place without electricity and oops you will be staying longer than expected with a flat battery and you wont have cold beers to make the time go quicker. :evil:WayneSchalk wrote:I fitted a dual battery system in my old man’s Hilux for his Engel. Now I know that the Engel draws so little that we could have done without the dual battery system.
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Re: Fridge Idée
Just a question.
How much does the compressor cost?
- Gertc
Re: Fridge Idée
4 x 4 Mega world quotes me R.1200 on a Engel compressor
- Gertc
Re: Fridge Idée
Original centre console
Starting with the mould
Giving it shape
final template for bottom half of fridge.
still needs to be sanded to perfection- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
Re: Fridge Idée
I measured my small engel (20 L), it will fit in between my KZTE's seats if i move the two front seats 40mm each to the sides.
i've driven a few beetles, so the offset position won't scare me, but having my brandy, coke and ice so close certainly does!
- Gertc
Re: Fridge Idée
I will start next week with the inside box then I will measure the capacity and let you know .
- hentey
- Town: worcester
Re: Fridge Idée
Gee Hoppy, I had to read your post a second time.I agree,That must be scary tempting,specialy now that you get it mixed in a bottle.
Re: Fridge Idée
Here come great things!
- Gertc
Re: Fridge Idée
I calculated the inside of the fridge, and it worked out to round about 15l.
I also decided to get rid of the condenser between the cab and loading bin. I want to get brake line pipes. And run it next to the chassis of the hilux. Making use of 2 or 3 runs should be enough. No need to worry about ventilation or leaves blocking the condenser.
- hentey
- Town: worcester
Re: Fridge Idée
Gert are you going to install a fan for the condenser If not what is cooling it down when you are not moving Just curious
- hentey
- Town: worcester
Re: Fridge Idée
[quote="Gertc"]I calculated the inside of the fridge, and it worked out to round about 15l.
I also decided to get rid of the condenser between the cab and loading bin. I want to get break line pipes.
Do you mean brake line pipes
- Gertc
Re: Fridge Idée
OOOoooops Yes should have been brake line pipes.
I tested my 40L Engel and the condenser doesn't really heat up. So I'm going to try running the BRAKE line pipes and by using enough pipe I don't think it will be a problem. The pipes will be spaced 2 or 3 cm apart. There shouldn’t be a problem of heat accumulating in one place sins the condenser will consist out of 3 pipes 1.4m long installed horizontally.
- Gertc
Re: Fridge Idée
Update.
I finished the outer box mould today of my fridge. The next step will be to start creating the final outer box from the outer box mould.
Then I want to start with the inner box. But still a little unsure how and what to use as an evaporator. Thought about 1.6 mm stainless plates spot weld some pipes to it and then mould it into the fiberglass box. But that is next weeks or the week after problem.
I will keep you up to date and post some pic`s .
Re: Fridge Idée
Copper plate would probably be better, and easier to work with.Thought about 1.6 mm stainless plates spot weld some pipes to it and then mould it into the fiberglass box
M2CW.
- Gertc
Re: Fridge Idée
Copper corrodes to easy. Stainless can take more punishment than copper and gives a better finish.
Re: Fridge Idée
Sorry, my misunderstanding. I assumed you were going to do a moulded plastic inner, but the stainless idea incorporating the evaporater and inner lining into one piece is definitely better. You'll probably have to silver-solder the copper tubing to the stainless, braizing could work if done carefully with the right flux.
Good luck all the same.
- Gertc
Re: Fridge Idée
I'm thinking of securing the copper pipes to the stainless with straps that is being spotwelded onto the stainless plate.
Re: Fridge Idée
Yeah, probably better so that you don't weaken the pipes. There should still be enough heat transfer, but I was wondering if there is'nt a product like an epoxy / gel / paste / glue that has a high heat transfer rate, something like what was used on PC's between the CPU and heat sink. Then you could run that along the full length of the tube against the plates, for max efficiency.
- Gertc
Re: Fridge Idée
Heatsink Thermal Compound! just don't know what the reaction would be when cooled down to -2 C
Re: Fridge Idée
Test it and see .... should still work well, even if it's 'in reverse'. Just make sure it's non-corrosive, for the copper mainly.
Good luck and keep us posted as to how it all works out.
- Gertc
Re: Fridge Idée
I finally finished the evaporator for my fridge. Looks small but can take 16 x 500ml cokes(Castle's) or 4 x 500ml coke's and 2 x 2L coke's. More than what I bargained for.
Used 0.6mm galvanized plate. Wrapped it in 6.35 mm copper pipe and soldered it together. Must still fit the capillary tube and filter before I can start mould it in its place.
- george
- Town: Velddrif
Re: Fridge Idée
Lyk goed Gert.
P.S Wanneer maak jy klaar met die kombuis
- Gertc
Re: Fridge Idée
Is jy en my vrou Familie?
- Gertc
Re: Fridge Idée
Kan nie meer wag nie. een van die dae!
Re: Fridge Idée
Hey Gert
Loop teel nou klaar daai kombuis en as jy klaar is kom doen sommer myne ook!!
- Gertc
Re: Fridge Idée
Jy is nie veronderstel om so vroeg op n Donderdag te begin drink nie.
Jy sien jy praat baie as jy so vroeg begin drink.
Re: Fridge Idée
Maar dis dan nou eers woensdag
- Gertc
Re: Fridge Idée
SSSSSSSo jy het begin! HHHHHHHIK. Hhhhhhik :roll:
- Gertc
Re: Fridge Idée
Dis nou mooi! Dis nou baie mooi.
Ek het by n 4 x 4 plek prys gekry op n Engel 40 l kompressor R1200 +/-. en nou dat ek hom 2 maande later wil bestel nou se HOOF kantoor van engel hulle mag nie compressor los verkoop nie. moet yskas instuur en dan vra hulle R.2695 vir n compressor en evaporator.
Genoeg om al jou toys uit die kot tewil gooi. Ek teel sommer my kombuis klaar so kwaad is ek nou.
- george
- Town: Velddrif
Re: Fridge Idée
Teel jou kombuis en loop kry vir jou 'n Danfoss kompressor
- Vehicle: 2008 D4-d Fortuner
- Real Name: Uys
Re: Fridge Idée
Sit 'n Danfoss BD50 in. Ek verstaan hulle is so R2200 met die black box.
- Gertc
Re: Fridge Idée
Danfoss BD35F beste prys en dan moet ek 180km agter hom aan ry. R3100 + petrol
- Real Name: Uys
Re: Fridge Idée
Is dit by Reco? www.reco.co.za
- Gertc
Re: Fridge Idée
jip Vereeniging is goedkoper as JHB R.233 goedkoper.
- Real Name: Uys
Re: Fridge Idée
Hmmm.....
Skielik raak 'n koue bietjie baie duur!
- Gertc
Re: Fridge Idée
Sou baie snaakser gewees het as dit met iemand anders gebeur het.
Re: Fridge Idée
Skoolgeld bra-Gert, skoolgeld... Nice friets anyway... en jou koue biertjie gaan baie lekkerder smaak as hy eers in daai friets koudgemaak is...
- Gertc
Re: Fridge Idée
Sal maar my haal geweer moet gaan uit grawe en kyk waar ek kan gaan geld trek.
maar glo my my fridge gaan werk. ni vandag nie nie more nie maar glo my hy gaan werk.
Hou maar dop
Hou maar dop
- Scooter
- Town: JHB
- Real Name: Scott
Re: Fridge Idée
Sorry to hear that Gert. Was that price for the compressor and control box? The way I understood reco the last time I enquired was that the comp and control box were sold seperatley and cost about the same?
- Gertc
Re: Fridge Idée
Reco in Vereeniging R3100 that is for the compressor and control box.
- Gertc
Re: Fridge Idée
Ok you guy's convinced me to can my fridge idèe So I desided to go for the cheaper version.
- Scooter
- Town: JHB
- Real Name: Scott
Re: Fridge Idée
Gert, you may have read this already but have a look here on the community forum. One of the guys there seems to think a compressor from reco is only 2K. I wonder if he gets discount because he buys from them all the time or maybe he just hasn't called for the latest price.
Perhaps you should contact him and find out.
http://www.4x4community.co.za/forum/sho ... hp?t=32192
Re: Fridge Idée
Gert,
I don't know how these prices compare:
BD35 @ R2200 excluding VAT
BD50 @ R2460 excluding VAT
In both cases the control box is included and features 24/12V DC input.
Courier fees from JHB are probably around R100 or so.
- Gertc
Re: Fridge Idée
The final product.
Still waiting for the compressor
Re: Fridge Idée
Hey Gert... you did first check that a six-pack or two does fit in there, didn't you...
Looks velly lekker! I like the colour-coding.
- Gertc
Re: Fridge Idée
I designed the fridge with a 6 pack in hand. I ment in mind.
end up with more space than 6 pack at the end of the night.
- Gertc
Re: Fridge Idée
The original centre console
The new fridge console
- Scooter
- Town: JHB
- Real Name: Scott
Re: Fridge Idée
Mooi man. Well done Gert.
Have you ordered a compressor, if so, what did you go for and end up paying?
- Gertc
Re: Fridge Idée
I went for Danfoss BD35F. Reason, Availability.
Prices R. 3078.00
Yes the fridge is expensive. But I think it is worthwhile. It is a 16 L fridge that is out of the way. And always ready to be use. If you compare it to the engel 16L fridge that is on the market of R 5400 and it is bulky. You will have to keep it in the back of your load bin.
Prices R. 3078.00
Re: Fridge Idée
That is expensive. I phoned Hussein twice since speaking to you - last time was 30 minutes ago, but was still unable to get hold of him. Left a message for him to phone me, but you have already ordered?
