Rear Wiper Intermittent Setting
- Town: Midrand
- Vehicle: 3.0 D-4D 2X4 Manual Fortuner
- Real Name: Willem
Hello All - on the new "facelift" Fortuner, (as I understand, but have not seen it) the rear wiper control stalk includes a setting for intermittent operation of the rear wiper. A feature which, if you own one of the original Generation 1 Fortuners, you may regard as very usefull, as on the previous models there was only "on" and "off" for the rear wiper. While I am not planning on swopping my current Fortuner for the new one, it would be nice to have just this one feature incorporated in my current car. Is it possible from an auto-electrical perspective? Who could give me a technical answer on this and is there somewhere specifically that I can go to have it done?
- Gertc
- Vehicle: 3.0L Fortuner
- Real Name: Gert Combrink
- Club VHF Licence: Xray05
Re: Rear Wiper Intermittent Setting
Yes it can be done. They cut the current wiper switch wire and fit a spesial timer inline with the wiper switch wire. A nice DIY project!
- Town: Midrand
- Real Name: Willem
But this suggested solution implies that you would then ONLY be able to operate the rear wiper in Intermittent mode, right?
- Gertc
yes unless you install 2
Dankie Jaco, baie interesant
- Town: Midrand
- Real Name: Willem
"unless you install 2"...? two of what?
I dont find any article when I follow the link... can someone help please?
- Gertc
Two timers . One on the front wiper and one on the rear wiper.
- Town: Midrand
- Real Name: Willem
Gertc, what I mean is I need both the standard "fully on" and intermittent functionality form the one switch on the rear wiper. The new Fortuner does hsve this while theold one does not, only has fully on. So if you insert the timing circuit into the harnass, it will convert the rear circuit to a intermittent only setup, correct? WHihc means that now you can only use the rear wiper in intermittent mode, not fully on??
