3D4D bonnet scoop
Rianc
Vehicle: 3d4d Fortuner 4x4
Real Name: Rian
Mon Nov 25, 2013 2:41 pm
I have a 2010 Fortuner with the smaller off-set bonnet scoop for the intercooler. Is it possible to replace this with the later model's wider scoop "centre" without to much modifications? I have not measured the later model's scoop hight, it seems a bit flatter, although its wider thus I presume that the intake air volume should be the same or even more? If possible, should the bonnet also be cut? Who has done this and what is the pro's and cons?
RianC
Saint_Diesel
Real Name: Jacques
Club VHF Licence: HC319
Tue Mar 03, 2015 8:20 am
I do note that this an old post, but did anyone successfully replaced the 3 slot with a newer 4 slot scoop?
If so what work/change is needed?
venom38
Town: johannesburg
Vehicle: hilux d4d
Real Name: Corne
Tue Mar 03, 2015 9:11 pm
Very good question. I contemplated buying a bonnet from a scrapyard but the lines on the new ones differs. The new scoop does increase the effieciency of the intercooler as the 3 fin gives way to little air to the fins. Possibly the 4 fin is also not very efficient but still a huge improvement over the small 3 fin.
antlo69
Town: Pretoria North
Vehicle: Toyota Hilux 3.0 D-4D, leveling kit, 17" with A/T BFg's, sadly stil some Tupperware, wish list growing by the day
Real Name: Antonie
Wed Mar 04, 2015 8:48 am
Your biggest problem will be to get just the scoop. There are no pirates available and salvage yards only sell them with the bonnet for the new face lift models. Toyota charge between R2500 - R3000 for just the scoop alone iirc.
Iff anyone find some of these scoops for cheap ill take x 5 please
Kampster
"Must be a Toyota, must be a diesel and must run on BFG's"
Markdil
Vehicle: Hilux dc
Real Name: Mark
Tue Jul 12, 2016 9:17 am
will it really make such a difference? or just the look?
Stekel01
Vehicle: 3D4D Fortuner
Real Name: Johann
Club VHF Licence: HC241
Tue Jul 12, 2016 10:42 am
I had this discussion on another forum and the most sensible answer was: According to the manufacturer there is no difference in power from the 3 vane to 4 vane...so this must be cosmetic?
Sent from my SM-G920F using Tapatalk
ThysdJ
Club VHF Licence: HC102
Tue Jul 12, 2016 11:42 am
An extra 5cm of bonnet scoop is not going to give such an increase in power that it will be noticeable. Remember you inter-cooler has a plastic cover onto which the scoop seals to prevent water from flowing into the engine bay. This plastic cover also needs to be changed, as well as the inter-cooler to have a noticeable effect.
lukestoyzx
Town: Griffith
Vehicle: 07 Hilux SR5
Real Name: Luke
Tue Jul 12, 2016 3:54 pm
Will be doin this soon!Image Link Broken
Ranger
Town: Alberton
Vehicle: Hilux 4.0 V6 manual
Real Name: Gustav
Wed Jul 13, 2016 1:12 pm
A larger front mounted intercooler will be a better option.
