3D4D bonnet scoop
Posted: Mon Nov 25, 2013 2:41 pm
by Rianc
I have a 2010 Fortuner with the smaller off-set bonnet scoop for the intercooler. Is it possible to replace this with the later model's wider scoop "centre" without to much modifications? I have not measured the later model's scoop hight, it seems a bit flatter, although its wider thus I presume that the intake air volume should be the same or even more? If possible, should the bonnet also be cut? Who has done this and what is the pro's and cons?
RianC
Re: 3D4D bonnet scoop
Posted: Tue Mar 03, 2015 8:20 am
by Saint_Diesel
I do note that this an old post, but did anyone successfully replaced the 3 slot with a newer 4 slot scoop?
If so what work/change is needed?
Posted: Tue Mar 03, 2015 9:11 pm
by venom38
Very good question. I contemplated buying a bonnet from a scrapyard but the lines on the new ones differs. The new scoop does increase the effieciency of the intercooler as the 3 fin gives way to little air to the fins. Possibly the 4 fin is also not very efficient but still a huge improvement over the small 3 fin.
Posted: Wed Mar 04, 2015 8:48 am
by antlo69
Your biggest problem will be to get just the scoop. There are no pirates available and salvage yards only sell them with the bonnet for the new face lift models. Toyota charge between R2500 - R3000 for just the scoop alone iirc.
Iff anyone find some of these scoops for cheap ill take x 5 please
Kampster
Posted: Tue Jul 12, 2016 9:17 am
by Markdil
will it really make such a difference? or just the look?
Posted: Tue Jul 12, 2016 10:42 am
by Stekel01
I had this discussion on another forum and the most sensible answer was: According to the manufacturer there is no difference in power from the 3 vane to 4 vane...so this must be cosmetic?
Sent from my SM-G920F using Tapatalk
Posted: Tue Jul 12, 2016 11:42 am
by ThysdJ
An extra 5cm of bonnet scoop is not going to give such an increase in power that it will be noticeable. Remember you inter-cooler has a plastic cover onto which the scoop seals to prevent water from flowing into the engine bay. This plastic cover also needs to be changed, as well as the inter-cooler to have a noticeable effect.
Posted: Tue Jul 12, 2016 3:54 pm
by lukestoyzx
Will be doin this soon!
Posted: Wed Jul 13, 2016 1:12 pm
by Ranger
A larger front mounted intercooler will be a better option.
