Catalytic coverrter removal?
Posted: Mon Mar 30, 2015 1:02 pm
by Pumba
Menere, vragie (nie seker of dit al erens bespreek was nie...?)
Ek is vertel dat dit n goeie idee is om die catalytic converter op my 30L D4D Fortuner (met 184000km op) te verwyder :? . Is this true
Hulle se my brandstof verbruik mag dalk verberer afhangend van hoe vuil hy is
Re: Catalytic coverrter removal?
Posted: Wed Apr 01, 2015 2:36 pm
by Pumba
Posted: Wed Apr 01, 2015 3:02 pm
by the BuTch3R
I'm not a mechanic, but by my logic, by removing the Cats you will reduce the overall weight of the vehicle and therefore should enjoy an improvement in your fuel consumption.
The same logic applies to the engine. If you remove your engine, because it is so heavy, your vehicle will use almost no fuel at all :wth:
Posted: Wed Apr 01, 2015 3:12 pm
by Pumba
Posted: Wed Apr 01, 2015 7:33 pm
by 4xlux
Hi. Dit is def 'n goeie idee. Die gasse kan net vinniger ontsnap, dit maak dat die combustion kouer sal wees. Die tweede oxy senser moet gespace word. Sal nie 'n probleem wees nie. Die diesels raas dan ook dan nie meer as dit uit gehaal word nie.
Posted: Wed Apr 01, 2015 7:54 pm
by Pumba
Dankie Francois
