Photos of IFS steering box on an SFA
- Musselcracker
- Vehicle: 1989 SFA D/C
Hi there
Does anyone have some pictures of how the IFS steering box is attached in place of the SFA box in an hi steer cross over steering modification!
THANKS I am just struggling to figure out how this operates! :wth:
Re: Photos of IFS steering box on an SFA
AFAIK it fits in the same place, same holes .... the pitman arm then tracks left and right instead of "push - pull".
There are threads here where this has been done ... sure there must be pics as well, if no-one posts any.
- Toybox
- Vehicle: Hilex
- Real Name: Jonathan
- Club VHF Licence: X100
Its best to move it as far forward as you can, otherwise you run the risk of the 2 rods contacting under compression. Another good plan is to plate the frame. The chassis has little lateral strength and tends to crack over time.
One thing in particular to check is your oil pan clearance. There needs to be enough space below your engine to allow for compression. I can't remember what the 4y looks like underneath. I'm pretty sure its fine but just take a look to make certain.
A pretty good option is Hoppy's Lo steer modification. The geometry is almost identical except the tie rod is located under the springs instead of on top of them.
- zepplin
- Vehicle: Crooza VX 80 EFI
- Real Name: Steve
- Club VHF Licence: HC 127
My tire rod is located in my tool boxToybox wrote:The geometry is almost identical except the tire rod is located under the springs instead of on top of them.
- Musselcracker
If i move the box as far forward as possible wont I have to lengthen that rod that comes from the steering wheel??
- Musselcracker
Only problem i can see with the lo steer is that the tie rod is a little exposed ( no different as it is now) but could have better protection above the leaf springs?
- Toybox
- Vehicle: Hilex
Ha ha ha, well spotted. Fixedzepplin wrote:My tire rod is located in my tool boxToybox wrote:The geometry is almost identical except the tire rod is located under the springs instead of on top of them.
- Toybox
- Vehicle: Hilex
Yes the steering shaft has to lengthened. Same as when you do a body lift. Loosen fitting on splined section, pull out to the length you need, re-tighten the fitting. If necessary remove it completely and weld in a section of steel rod.
Protection is better on top but its a more costly conversion. The Lo steer conversion is all locally sourced parts.
- gert-redelinghuys
- Town: polokwane
- Vehicle: 1996 hilux 2.4 4x4 dc raider rear locked 31 maxxis bighorns 2 inch lift
- Real Name: gert
hope this help
lock and crawl
niks loop soos `n john deere nie , behalwe `n hilux bakkie met `n john deere sticker agter op die bak
- Musselcracker
Thanks Gert....
I was hoping to see just the orientation of the power steering box
- krazy_kameleon
- Town: Fourways
- Real Name: Rick
BlumTRD sells the hi steer arms, they just bolt on. you just need to get the tierods.
give him a shout, I have been wanting a set for myself - just need to get on top of my cash (or lack thereof)
looks like really nice stuff - replica of the Ozzy snake racing kit
- Bushwacker
- Town: Vryheid Natal
- Real Name: Piet
Will the Cruizer 80 series steering system fit the Hilux SFA
Chris, look at this link (Courtesy of "Missouriman") ..... should give you a much better picture.Musselcracker wrote:Thanks Gert....
http://forum.ih8mud.com/79-95-toyota-tr ... hread.html" onclick="window.open(this.href);return false;
Just remember that they are LHD over there and so are their steering boxes, but the same principle applies to RHD.
