Hilux rear 4-link suspension set-up....
Posted: Sun Feb 19, 2012 10:42 am
by THROTTLE-BOY
Got a "Rally Bakkie" in at M&P Fabworx for a complete 4-link suspension set-up.The owner has specified his needs and what He wants to do with the Rig. We have already got most of the mounting hardware fabbed up and the rear links are welded as well ready for fitment in the week. All the link bushings are Tig welded for extra strength and the rest will be Mig welded onto the chassis.
This set-up gives exellent articulation while adding great diff stability under load. The Rig has a Lexus V8 that should give it enough power to play with as well !
- IMG_2323.JPG (84.69 KiB) Viewed 7318 times
- IMG_2331.JPG (65.72 KiB) Viewed 7318 times
Re: Hilux rear 4-link suspension set-up....
Posted: Sun Feb 19, 2012 11:43 am
by zepplin
THIS I wanna see!!!!! Keep the updates & pics coming please MArk.
Posted: Sun Feb 19, 2012 12:00 pm
by Traveler
Mark, I need to come and visit your shops when in the Vuildriehoek again.
Posted: Sun Feb 19, 2012 6:20 pm
by THROTTLE-BOY
Traveler wrote:Mark, I need to come and visit your shops when in the Vuildriehoek again.
You're welcome .....just let me know when....We are usually always busy with some or other Rig at the shop !
Heres the Tig welded bushings on the links....
- IMG_2332.JPG (52.11 KiB) Viewed 7295 times
Posted: Sun Feb 19, 2012 7:59 pm
by 96-Luxi 4x4
Mark Looks good
please post all pics. what does something like this cost? And what coils and shocks do you use?
I thought of this on my Bakkie, for better articulation, and a softer ride with the coils instead of Leaves.
Please give me your thoughts
Posted: Mon Feb 20, 2012 11:00 am
by THROTTLE-BOY
96-Luxi 4x4 wrote:Mark Looks good
There's great benefits with a 4-link and articulation is only one of them. Drivability is a lot better than a leaf sprung Rig as well. The fuel tank is an issue on a street driven Hilux because it's in the way of the links. The cost installed is about 12K excluding the shocks.
Heres a pic of No7 from the rear !
- IMG_2348.JPG (66.86 KiB) Viewed 7258 times
Posted: Tue Feb 21, 2012 3:58 pm
by 96-Luxi 4x4
Cool Thanks
something i always wanted to do
busy with V8 now. Endless pit this Hilux. Think Ill have to be happy with the suspension I have for now
Posted: Sun Mar 04, 2012 9:20 am
by THROTTLE-BOY
Got the 4-link finished yesterday afternoon.....works like a dream with no binding at full flex.....
Heres some pics....
- IMG_2454.JPG (50.29 KiB) Viewed 7181 times
- IMG_2441.JPG (60.39 KiB) Viewed 7181 times
- IMG_2469.JPG (51.3 KiB) Viewed 7181 times
Have been busy with a KZTe that had it's front end suspension hacked out....
We stuck a locked solid front axle in on blades, running Longs and 35"s with no body lift....this is going to be 1 badass Rig when We're done...
- IMG_2432.JPG (60.88 KiB) Viewed 7181 times
- IMG_2425.JPG (62.17 KiB) Viewed 7181 times
Posted: Sun Mar 04, 2012 10:44 am
by 519franco
how much is it for this conversion
Posted: Sun Mar 04, 2012 3:45 pm
by pietpetoors
Is there a reason why you use blades in front of the KZ and not coils?
Posted: Sun Mar 04, 2012 6:59 pm
Using coils would mean making up a 3 or 4 link suspension which can be awkward to fit around the motor, also you can't take a link off the top of the diff housing as it's set to one side and therefore not symmetrical. To minimise axle wrap the link points on the axle need to have some decent vertical spacing for leverage. I can imagine, although not impossible it would involve a lot more work and expense. The leaf packs already provide a lot of the stabilisation required.
Posted: Sun Mar 04, 2012 7:13 pm
by THROTTLE-BOY
Thats it Andy.....theres another way .....using Cruiser control arms, this gets you away from the motor but does limit articulation a bit.....the other down side is a Panhard rod to control the diff that usually takes all the Shots in an obsticle first ! Tri-angulated 3-links also an option again with a Panhard rod. The coils also become cumbersome and get in the way of the tyres....best to get a set of King or Fox coil-over shocks with this combo.
Posted: Mon Jul 17, 2017 4:14 pm
by Black beast
Hi everyone it seems that this post has been a while back...i need to know more about the 4 link suspension ive been doing some research but just cant seem to get my head around this...how expensive is this and where can i get a qoute
Sent from my SM-P555 using Tapatalk
Posted: Mon Jul 17, 2017 7:10 pm
Yes, it is an old thread and sometimes the OP's fall by the way side. Mark hasn't been active here for some time now but I'm sure there are other members that could give you a few indicators.
Posted: Mon Jul 17, 2017 7:13 pm
P.S. You could try contact Mark by PM or e-mail (click on the bubble where it says"Contact" at the bottom of his profile text) in the hope that he's still using the same -e-mail address.
