Hi
does anybody knows the dimmentions off the factory shocks for the LN105 sfa diesel front and back?
I want to replace them with longer ones for better articulation.
Do you also know how longer can I install without changing anything else and have no problem?
The S/N of the car is:
JT131LNA409051975
Thank you
ln 105 shocks dimmentions
- kritsotis13
- Town: irakleio crete
- Vehicle: hilux LN105 2,4D 1997 sfa
- Real Name: manos
- 519franco
- Town: Richards bay
- Vehicle: 87 Hilux 3L v6 Ford
- Real Name: Franco
Re: ln 105 shocks dimmentions
well i just replaced my shockes with gabriel heavy duty 4x4 shockes and they are +/- 610 open and +/- 400 closed cant rember exact messurments
HAPPILY BUILD 3L V6 1987 TOYOTA HILUX
viewtopic.php?f=136&t=18393" onclick="window.open(this.href);return false;
FORD> Full Off Road Damnation
FORD> Its not oil leaks,, its swearing power
Sponser: MY DAD
Builder: ME: FRANCO DU PLESSIS
Be careful not to fit a shock that is too long otherwise it will bottom out before the suspension. That just needs to happen once and the shock will be totally ruined. The shock must also arrest the outward travel before the shackles are fully extended, otherwise they can invert which can also cause damage. Fitting extended shackles or revolver shackles can overcome this and allow for more outward travel, but you will still have the bottoming out issue unless you alter the bump-stops.
- kritsotis13
- Real Name: manos
dear Dog, thanks again
that is why I am trying to find out the dimmentions because I can not take them off the car myself.
I have the manuals but it is not there.
