swapping out a 4y with a 22r
krazy_kameleon
Town: Fourways
Vehicle: 1993 Hilux D/C 4X4 2.4 22R (fuel injection in the pipeline)
Real Name: Rick
Post by krazy_kameleon »
Hi All,
I have just bought a 22r to replace my 4y.
I erroniously presumed that the 22r would just fit straight in - not so
am I missing something here? is there a different engine mounting to use?
before I break out the grinder and welder (again!) I wanted to know if anyone else has done this engine swap and what they experienced.
Rick
Borntofish
Vehicle: Hilux 86
Real Name: Werner
Re: swapping out a 4y with a 22r
Post by Borntofish »
I have done it the other way around, 22R to 4Y. The mounts needs to be changed and you will also need a different bellhouse.
krazy_kameleon
Town: Fourways
Real Name: Rick
Yes, I've got the correct bellhousing but had assumed the mounts would be the same.
How did you handle the mounting points?
By the way, why did you change to a 4y?
Hoppy
Vehicle: Hilux SFA & IFS
Real Name: Allan 0721291160
Post by Hoppy »
The mounting brackets welded to the chassis on the 22r is more forward than the 4y.
You can remove them neatly and reposition them or make a plate with 4 holes that bolts onto the existing holes and themn thakes the mount on top.
Note; The mounting brackets and sump is different on the 4x4, 2x4 and cressida.
krazy_kameleon
Town: Fourways
Real Name: Rick
Thanks Al,
I have GeorgeJVR's old motor so the sump is right.
I was going to position the engine mount brackts on the block on the 4 holes behind where the bracket is now. It seem to be almost perfect. May just need to slot the holes a little
On the drivers side though there is a sensor that will n be in the way. Oil level sensor???
I do have a 50mm body lift and have raised my g box 50mm too so it does change the game slightly.
Thanks again for the advise guys
scout
Town: White River
Vehicle: 91 Hilux dc -pro comp , arb bb , winch , 33'' muds
Real Name: Jonathan
Post by scout »
why would you lift the fbox 50mm? or is this a stupid question?
" Yes I know we are lost , but we are making good time "
krazy_kameleon
Town: Fourways
Real Name: Rick
As far as I'm concerned Jonathan there is no such thing as a stupid question, only a stupid answer...
I go into the reason here viewtopic.php?t=15289
but in short, I raised the body 50mm and didn't want the problems that come with the body lift - fan shroud, gear lever etc
so I raised the motor and box the same amount, never seen it done before but I'm sure it has been.
The only disadvantage I could think of was it raised the center of gravity but I reasoned that if I made the track wider (bigger tyres or spacers r both) in the same proportion, the CoG should remain the same
GeorgeJvR
Town: Louis Trichardt
Post by GeorgeJvR »
:shock: :wth:
Shucks...
Well i gess we all learned something new here.
Sorry Rick, was not knowing of the diffrent mounting points
Kom wat wil ek bly 'n Bul!
krazy_kameleon
Town: Fourways
Real Name: Rick
No Worries George, we live and learn.
I didnt have a clue either
at least it is now "posted" on the forum and others can be prepared before they attempt it.
looking forward to having Rokorok up and running even if the interior is still stripped out!
krazy_kameleon
Town: Fourways
Real Name: Rick
here are some pics of the mounts
LouisZ
Post by LouisZ »
Had the same when I did the diesel to 4Y swap about 2 years ago.
Hoppy
Post by Hoppy »
The diesel and the 22R uses the same mounting position, only the 4Y is different.
I lifted my challenge Hilux's body, engine & gearbox 70mm, and then moved it the same amount back into the firewall.
The weight on the front wheels is less and my transfer crossmember is straight (better break over angle) together with 35" tyres and the 400mm i took out of the chassis, it works realy well.
krazy_kameleon
Town: Fourways
Real Name: Rick
Thanks for sharing Hoppy,
some points to definitely consider while we are at it.
P.S. I love that bit in your signature about "real Hilux's are Built NOT bought..."
