Ek groet die Hiluxmanne
My Lexus engine het nog die fan se hidoliese pomp in ek laat die olie net sirkuleer.Het nog in gedagte om n hidroliese winch van hom af te dryf.Niemand kon my nog se of dit moontlik is nie.Die pomp se druk en vloei is nie aan my bekend nie.Kan iemand asb help?As dit nie moontlik is nie gaan ek die pomp uithaal en af blank.Al die terugvoer sal SOOOOOO waardeer word!!!!!!!!
Hilux(Vaaltyn die Jerusalem Horse) Groete
Hansman :? :? :?
hydraulic winch
- KOBUSL
- Town: WOLSELEY
- Real Name: KOBUS
Re: hydraulic winch
Hans, ek sien op Warn se webwerf is hidroliese wenaste. Miskien kom jy daar reg. Hou maar die $$$$$ reg. lol
Re: hydraulic winch
Bevestig self Hans, maar ek glo nie daai pomp gaan voldoende wees. Gebruik hom eerder vir 'n olie vekoeler.
- WESKUSKLONG
- Town: St Helena bay
- Vehicle: Hilux KZTE with ARB front locker/Safari Snorkel / 33x12.5x15 tyres / Long range tank / Battery system / Thomas compressor/ 2Engel fridge freezers/Cruise Control.
- Real Name: Rudi
Re: hydraulic winch
Use it for cooling the oil and install a winch on the power steering pump.
- hansman
- Town: pretoria
- Vehicle: hilux sfa
- Real Name: hans
Re: hydraulic winch
Hello Andy en Rudi
Baie dankie! I would like more info on using the pump for an oil cooler.Must I use an remote oil filter and cooler and how must I do the plumbing. I am very interrested and will ap. the info.Thanks again.
Hansman
Hansman
- SYRON CONVERSIONS
- Town: Tamboekieland
- Vehicle: SFA HILUX
- Real Name: SIMON
Re: hydraulic winch
Me afrikaanse is not too good, but if you connect the hydraulic winch to your power steering pump, you will have to add an additional oil cooler for it as well.
simoan
simoan
- Genissie
- Town: Hartenbos
- Vehicle: LC 80, 4500
- Real Name: Andries
- Club VHF Licence: X254
Re: hydraulic winch
just a thought, there's a lot of electronics on that lexus motor that can get wet when immerse, whick might easily result in cutting the engine. my point is you will have no winch then, rather stick with an electrical winch
