sfa brake master cylinder upgrade with back disk brakes.
Vlak vark
Town: Phalaborwa
Post by Vlak vark »
so I have received my new brake master cylinder today and installed it. the brake force is so great that I have burst a pipe going to the back. ( pipe were rubbing against the fuel line and were a bit thin.) for the first time the back wheels locked. unfortunately I first have to repair the pipe tomorrow to have the full outcome. at this stage I do think there is a huge improvement on braking so far. I'm currently in town so as soon as get back home I will load some pictures and the full details of the cylinder.
Tarquin
Town: Plettenberg Bay
Vehicle: Toyota 2.8D D/C 4x4 & Toyota 2.4D single 4x2
Real Name: Tarquin
Re: sfa break master cylinder upgrade.
Post by Tarquin »
:subscribed: :subscribed: :subscribed:
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
Hopefully nothing more will break when you brake! :twisted:
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Post by The Legend »
Vlak vark
Town: Phalaborwa
Post by Vlak vark »
so the part number from partquip is BM254.8025PQ
The pictures are from new to old
New Master
(260.09 KiB) Downloaded 875 times
(244.31 KiB) Downloaded 875 times
old Master
(224.31 KiB) Downloaded 875 times
The Legend
Real Name: Dawie
Nico ek merk dat beide die ou en nuwe master brake cylinder nie die drade op die reservoir cap het nie.Is die ou een ook n pirate part?
JohanM
Town: Meyerton
Vehicle: Prado 120 4.0 V6
Club VHF Licence: HC126
Re: sfa brake master cylinder upgrade.
Post by JohanM »
Lollie wrote:Nico ek merk dat beide die ou en nuwe master brake cylinder nie die drade op die reservoir cap het nie.Is die ou een ook n pirate part?
Dawie, ja dit is n partquip onderdeel, nie Toyota nie.
MY SFA het so n look alike maar OE Toyota Master cylinder in soos daai partquip. Ook die een wat ek vervang het agv ouderdom het so gelyk. My SFA kan ook sy wiele rook op die teer as ek hulle laat stilstaan. :twisted:
Vlak vark
Town: Phalaborwa
Post by Vlak vark »
ek glo hy is n pirate. hy het gelek op die agterste seel.
die seel kids wat te koop is pas die laaste seel nie. en het begin te lek. R150 vir n nuwe piston en seels was net nie die moete werd nie.
Post by CasKru »
is die nuwe een 'n 1" silinder?
Vlak vark
Town: Phalaborwa
Post by Vlak vark »
CasKru wrote:is die nuwe een 'n 1" silinder?
ja Cassie. hy meet 25.4mm
Post by CasKru »
Dankbaar. Is daai die KZ-TE se eweknie?
Vlak vark
Town: Phalaborwa
Post by Vlak vark »
ek het gister 2 nuwe pype ingesit gister wat na agter na die load sensor toe gaan.
sal vandag bloei en toets.
Vlak vark
Town: Phalaborwa
Post by Vlak vark »
so I have tested the brakes today and there is definitely a huge improvement.
Tomorrow it is time for the disk brakes at the back.
I have cut disk back 5mm on the diameter to fit onto the side shaft, so tomorrow is do or die.
The Legend
Real Name: Dawie
Nico
Is jou skyfremme op agter?
Vlak vark
Town: Phalaborwa
Post by Vlak vark »
Lollie wrote:Nico
nee ek moet nog 2.5mm afvat op die side shafts sodat die disks sal pas. sal dit in die week doen.
Bosfebok
Town: Roodekrans
Vehicle: 1995 Hilux Raider 2.2
Real Name: Otto
Club VHF Licence: X248
Post by Bosfebok »
Weet iemand of die twee master cylinders dieselfde is?
My vraag : Sal die KZTE master cylinder net so pas op my SFA (ek het 'n KZTE booster ook)?
Hoeveel kos die cylinder wat jy gekoop het?
Otto X248
20.5" LED BAR
Nudge-M front bumper
80l Long Range Fuel Tank
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
Vlak vark
Town: Phalaborwa
Post by Vlak vark »
Otto, saam met afslag was hy R954. die dia van die kz en sfa is die selfde, so ek kan nie sien dat dit n verskil sal maak nie. of die booster sal pas, sal jy maar moet meet.
Bosfebok
Town: Roodekrans
Real Name: Otto
Post by Bosfebok »
Otto X248
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
Vlak vark
Town: Phalaborwa
Post by Vlak vark »
Vlak vark wrote:
Lollie wrote:Nico
het die een side shaft afgegrind disk opgesit saam met caliper en die wiel vasgemaak. gelukkig het ek dit gedoen voordat ek begin het met die adapter, want die caliper druk vas teen die rim so ek moet die disks nog 10 mm afsny op die diameter.
Post by CasKru »
Vlak vark wrote:Otto, saam met afslag was hy R954. die dia van die kz en sfa is die selfde, so ek kan nie sien dat dit n verskil sal maak nie. of die booster sal pas, sal jy maar moet meet.
Ek dink nie daai stelling is waar nie. Sover ek weet is die KZTE 'n 1" master en die SFA 'n 3/4" master.
Bosfebok
Town: Roodekrans
Real Name: Otto
Post by Bosfebok »
Dit was my understanding ook...en toe gaat koop ek die hele booster en master cylinder... sal maar check of die goed pas en of dit 'n verskil maak....
Otto X248
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
Vlak vark
Town: Phalaborwa
Post by Vlak vark »
Cassie ek het gevra vir n kz master en die wat hulle daar aan gebring het was 23.8 mm. Hulle kon dalk die verkeerde een gebring het. wie weet?
Post by CasKru »
Maar daai is nader aan 'n duim as wat die aan 3/4" is. So ek dink het dan die regte KZTE ene en die een wat jy van jou wa af gehaal het was dalk reeds een gewees.
Vlak vark
Town: Phalaborwa
Re: sfa brake master cylinder upgrade with back disk brakes.
Post by Vlak vark »
ek het vandag klaar gekry met die disks agter en WOW. Dit is nog die beste wat my trok nog gebriek het. geen skeef trek nie. dit was defnitief die wag werd. moet nog net die handrem uit sort.
