Gearmax
mosteran
Town: Springbok
Vehicle: Fortuner 4x4, 1994 Hilux dbl cab 4x4
Gearmax
Post by mosteran »
Te danke aan Hoppy kan ek ook nou spog met n gearmax difflock.
More gou die vacuum pyp, solenoid en drade opkoppel.
En dan natuurlik gaan TOETS :celebrate:
dd6
Vehicle: 1995 SFA
Real Name: Jaco
Re: Gearmax
Post by dd6 »
Veels geluk!! Geniet hom!
Re: Gearmax
:thumbup: :thumbup:
Just fit a little LED warning indicator that lights up when it's on ... otherwise you never know if the switch has been bumped and accidentally engaged. There is a terminal for this purpose at the diff itself that earths when the locker engages. ;-)
Re: Gearmax
Post by CasKru »
Lekker man lekker. heeltyd speeltyd
Hangover
Town: Deneysville
Real Name: Stef
Re: Gearmax
Post by Hangover »
Mud Dog wrote::thumbup: :thumbup:
Wise word from the ou toppie...
Hangover(A.K.A die speelding)
1976 FJ45 4x4
1UZ-FE 4.0vvti
2" OME Suspension lift
1.5" Shackle lift
35" Geo MT's
Custom Bullbar
Lockright Locked rear
York OBA
20" LED bar
Nighthawk 100W spots
Dakar
2013 3.0D-4D 4x4 Hilux Dakar
mosteran
Town: Springbok
Re: Gearmax
Post by mosteran »
Thanks Andy, did install a switch with indicates when its engaged.
Also though to install red led to indicate if switch is on.
Re: Gearmax
mosteran wrote:Thanks Andy, did install a switch with indicates when its engaged.
Good idea - the standard units have that feature. :thumbup:
mosteran
Town: Springbok
Re: Gearmax
Post by mosteran »
Do you know if the standard units are available somewhere?
Re: Gearmax
You might be able to get from a dealer, you could also try breaker yards. I imagine that Gearmax should also keep something similar if not original Toyota, or al least advise where to get.
This is what it looks like ........
(45.16 KiB) Downloaded 507 times
The first indicator (red) glows when the switch is activated - the second one (green) lights when the locker kicks in at the diff. When one switches off to disengage the locker the green one might still remain on if the diff is under a bit of wind-up stress and the locker cannot disengage. As soon as the wind-up is relieved the locker kicks out and the light goes off - This is particularly handy if you've switched off coming onto a hard surface, to avoid damage.
mosteran
Town: Springbok
Re: Gearmax
Post by mosteran »
Thanks Andy :thumbup:
