4Y Engine swop
Ingo15
Vehicle: Hilux 1983 Model
Real Name: Ingo
Thu Jan 15, 2015 7:04 pm
I got a beautifully restored 1983 Hilux, RN46 Range.
It has a very good 4Y motor, but I am lusting after more power and diesel.
What motor can be fitted to the existing bell housing?
I dont mind changing engine mounts and other stuff, but I am uneasy about adaptor plates - but willing to learn.
Your thoughts and ideas?
Ingo
Thu Jan 15, 2015 7:27 pm
Welcome to the forum Ingo
There are a lot of wise men (not me) here who will be able to help you :thumbup: :thumbup:
robvan87
Town: Nelspruit
Vehicle: 1987 Hilux, NudgeM Bar, ProComp 4" Lift, 33" Hankook Dynapro MT's
Real Name: Robert
Thu Jan 15, 2015 9:36 pm
Lexus v8! Welcome
Sent from my SM-N910F using Tapatalk
Wikkels
Town: Kathu
Vehicle: 1997 Toyota Hilux 2.4 D/C SFA - 2013 Mitsubishi Triton 2.5 4x2 D/C
Real Name: William
Thu Jan 15, 2015 9:43 pm
Welcome Ingo. Some of the other guys can correct me if I'm wrong..... but when looking at a diesel engine a 2CT or a 2LT will bolt onto the existing bell housing. The engine mounts will have to move though.
The man who smile when things go wrong thought of someone to blame it on!
Ingo15
Real Name: Ingo
Fri Jan 16, 2015 6:45 pm
Thanks for the input.
Lexus - too big and heavy (and thirsty?) for me.
The 2CT / 2Lt - are they not rather low on power and torque?
Jacques T
Vehicle: SFA Hilux
Real Name: Jacques
Fri Jan 16, 2015 7:26 pm
Ingo15 wrote:Thanks for the input.
Actually
The 1uz engine weighs around 175 kg. (http://www.lextreme.com/forums/showthread.php?t=3611" onclick="window.open(this.href);return false;)
I guess that does make the lexus a full 1kg heavier than the 4y's gross weight 174 kg. (http://deutzengine.en.made-in-china.com ... oyota.html" onclick="window.open(this.href);return false;)
and seriously, what would you consider heavy on fuel? What consumption do you get with the 4y?
I have personally blown a 2l, and a 2l2 engine in a single cab SFA by over revving them by not altering the gear or diff ratio's. I know that the KZ-T conversion also needs modifications to the ratio's and I believe the same applies to the C range of engines too. Diesels doesn't like to be revved high constantly. This shouldn't be a problem if you change gears quickly and not drive faster than 100.
(see viewtopic.php?f=98&t=2356" onclick="window.open(this.href);return false;)
Only diesel that sounds worth investing in seems to be the Mazda WL engine (viewtopic.php?f=3&t=35967" onclick="window.open(this.href);return false;)
If you change to any of the above engines, you WILL have to change your bell housing. In some cases, you'll replace your mountings and radiator too.
If you want to do a conversion, be prepared to make things fit.
dd6
Vehicle: 1995 SFA
Real Name: Jaco
Fri Jan 16, 2015 7:57 pm
Convert the 4y to fuel injection for more power.
Willied
Town: Witbank
Vehicle: '90 Hilux
Real Name: Willie
Sat Jan 17, 2015 5:34 pm
Welcome to the forum..
First question; How much do you have to spend? This one question will answer all your questions..
Wikkels
Town: Kathu
Real Name: William
Sat Jan 17, 2015 8:32 pm
My father in law fitted a 2L2 in his Chev Luv with a Hilux gearbox and transfer case. The power is more than sufficient for its application. Its been running with that engine for almost 10 years now. No issues at all. He used to spend a lot of time in the kalahari dunes with his Chev and was very pleased with the engines performance.
Ingo15
Real Name: Ingo
Sun Jan 18, 2015 8:36 pm
Will the 2.7 EFI Petrol be a problem to fit and mount to the existing bellhousing?
Seems like a good motor with lots of performance?
Ingo15
Real Name: Ingo
Sun Jan 18, 2015 8:40 pm
Hi Willied
On the question of how much can I spend...
I hope to spend as little as possible, on the other hand if the best option costs R20k than it may be worthwhile??
No for the answers...:-)
Ingo15
Real Name: Ingo
Sun Jan 18, 2015 8:43 pm
Sorry, my last sentence should read:
"NOW for the answers..." not "No for the answers"
Jacques T
Vehicle: SFA Hilux
Real Name: Jacques
Mon Jan 19, 2015 8:09 am
Ingo15 wrote:Will the 2.7 EFI Petrol be a problem to fit and mount to the existing bellhousing?
Probably not. Every engine block series is different. usually bellhousings from the same range are the same (eg a 1l, 2l, 2l2, 3l, and 5l will use the same bellhousing, but it will be different from the 2c and 1kz-te)
In rare cases like the 1kz-te and KD range which basically uses the same block, you might be lucky.
viewtopic.php?f=1&t=2165" onclick="window.open(this.href);return false;
I would suggest that you try to get a 2.7 (3RZ engine) with it's gearbox, wiring harness and computer for the best reliability if you want to go this route.
Scott
Vehicle: Hilux SFA
Real Name: Rodney
Mon Jan 19, 2015 9:35 am
I have fitted a kzte motor with 5Lt manual pump and got a bell housing from importers.There is some modifications and there is a huge difference in power.
Pith Helmet
Town: Xai-Xai
Real Name: Mark
Sat Dec 31, 2016 10:55 am
Wow it seams this conversation died a year ago. I would have liked to see the "wise mens" input about changing engines as I am sitting with a dying 5L Diesel engine and would like to hear peoples comments about swapping it out for a 3L engine (apparently they bolt in). Has anyone done a similar heart transplant ?
    Users browsing this forum: Baidu [Spider]
