Fix oil leaks on swivel hubs SFA front axle
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Tue May 16, 2017 4:56 pm
Fix oil leaks on swivel hubs on sfa front axle once and forever doing it the correct way
1) Get the dubbel lip oil seal of TG TRAIL -gear (imported from U.S.A)
2) If there is any signs of wear (doesn't matter how small) on the spindle bushes replace it with the original Toyota one (Not the short pirate one).
3) Replace all the gaskets and vilt seals with new ones
4)Most important of all use the "tool" to make sure that shims on the swivel hubs is fitted correctly
(30.72 KiB) Not downloaded yet
(31.88 KiB) Not downloaded yet
(34.09 KiB) Not downloaded yet
Bliksempie
Town: Pretoria Montana
Vehicle: 2.4 SFA
Real Name: Robbie
Club VHF Licence: HC115
Wed May 17, 2017 6:54 am
Dawie, ek het dit so 2 maande terug gedoen end dit was glad nie die mees aangename takie gewees nie. Ek het meer geld spandeer aan lappe om alles skoon te maak as aan parte.
When Life knocks you down, make sure you fall on your back. If you can look up, you can get up
Wed May 17, 2017 8:39 am
Toe ek laas myne ook oor gedoen het was dit die selfde hier... daar is darem maar baie grease wat daar moet uit
niclemaitre
Town: Stellenbosch
Vehicle: 87 DC 2.8D
Real Name: Nic
Wed May 17, 2017 9:31 am
Hi there
Do you have parts numbers for the required parts?
Nic
Happy trails
Nic
SFA '87 DC "Rooies"
The Legend
Real Name: Dawie
Wed May 17, 2017 6:24 pm
http://www.hilux4x4.co.za/front-axle-re ... /index.php
Nic open above link.You will find all the partnrs you may need. if you want to use the imported dubble lip oil seel which
I used you can get it from Ultimate off road in Benoni.The part nr is OT001 and their contact nr is 083 384 5342 or 083 269 1355
    Users browsing this forum: Google [Bot]
