Dakliggie/cablight
- hentey
- Town: worcester
- Vehicle: 2700i 4x4
- Real Name: hentey pople
Dakliggie/cablight
Het die ou simpel dakliggie seker 20 keer vervang.Seker die comminste ou dingetjie aan n Hilux,al is dit ook aan kan mens nog steeds niks in die nag met dit sien nie.Pluk toe my mo@r nouie oggend en ry af outozone toe.Koop vir my n LED nommerplaat liggie en monteer dit teen die bestaande ou liggie vas.Jislaaik kerels,nou moet ek n sonbril opsit as die dingetjie aangaan.Ek kan nie glo dat mens met n R100 so baie frustrasie uit die lewe kan haal nie.Ek deel die brokkie inligting met julle want dit het verseker my lewe baie vereenvoudig.Indien enige van julle hierdie mod oorweeg.....maak net gou want ek gaan die patent laat registreer.
- JohanM
- Town: Meyerton
- Vehicle: Prado 120 4.0 V6
- Club VHF Licence: HC126
Re: Dakliggie/cablight
Hentey,
Daai klink na 'n blink plan!!! Sit so paar prenties op vir die mense wat nie mooi kan lees nie.....
- GTO
- Town: Fish Hoek
- Vehicle: 2002 2700i 4x4 DC ; 1995 2.4 SRX
- Real Name: Stephen
I also have problems with my interior light.
I found this:
http://www.4x4direct.co.za/shop/index.p ... ucts_id=57" onclick="window.open(this.href);return false;
I found this:
1985 Suzuki DR600S
1984 Honda ATC200ES BIG RED
1985 Suzuki DR600S
Stephen, I am not so sure those will fit. The Hilux interior light is a bit shorter than 4.2cm. Will have to take mine out and measure it, I would prefer going LED anytime.
Hentey have you got a fix for the reverse lights? My SFA's reverse lights are useless!
Fit rear mounted spots, Bretton, but connect then to a switch with a LED in the toggle or with an indicator light to show when they are on. Left mine on by mistake once ... drained the battery in ½ an hour.
You should have fitted a LED spotlightdrained the battery in ½ an hour
LED torches hadn't even been invented yet when I fitted those spots!OOOOMS wrote:You should have fitted a LED spotlightdrained the battery in ½ an hour
- GTO
- Town: Fish Hoek
I was going to check the length on the weekend, I have been through a few bulbs in the past 2 years, the bulb in there at the moment doesn't seem to make proper contact, if I move it slightly it works again for a few days.Family_Dog wrote:Stephen, I am not so sure those will fit. The Hilux interior light is a bit shorter than 4.2cm. Will have to take mine out and measure it, I would prefer going LED anytime.
1985 Suzuki DR600S
1985 Suzuki DR600S
- Scooter
- Town: JHB
- Real Name: Scott
Stephen, I don't know about the IFS and later trucks but i do know that those globes won't fit the SFA if anyone is thinking of getting one.
The SFA has a medium globe that most spares places don't even stock
Of course those with SFAs could always change the fitting with a later model
That is a common fault with them. A bit of electrical Contact Cleaner usually sorts it out, with some light sanding on the globe contacts with very fine grit water-paper. But the standard globes are only 3W, the LED globes, if they can be made to fit, would be much brighter and consume far less current.
- GTO
- Town: Fish Hoek
Thanks Eric for the tipFamily_Dog wrote:That is a common fault with them. A bit of electrical Contact Cleaner usually sorts it out, with some light sanding on the globe contacts with very fine grit water-paper. But the standard globes are only 3W, the LED globes, if they can be made to fit, would be much brighter and consume far less current.
1985 Suzuki DR600S
1985 Suzuki DR600S
- warrenaken
- Town: JHB
- Vehicle: 3.0 KZ-TE 4x4
- Real Name: warren
- Club VHF Licence: X04
Just an update, i replaced my interior cab and canopy lights with LED, will get some pics, but the cab light makes a big difference. I also got a work light on the back and replaced that globe with an H3 LED, It is not as bright as the std 55w globe, but in darkness provides enough light and does not run the battery down if left on. I took a few pictures and have attached the ones that best represent the light it throws out. Would be nice to have one of each on seperate switches!
Toyota Hilux KZ-TE
This is my R13.00 solution to the cablight problem
See http://www.hilux4x4.co.za/LED-interior-light/index.php for the full story.
Looks like a space ship...pietpetoors wrote:This is my R13.00 solution to the cablight problem
- GTO
- Town: Fish Hoek
I am not keen on drilling holes in the light cover surely there is enough space inside to fit the LED's?
1985 Suzuki DR600S
1985 Suzuki DR600S
There will be enough space yes, I just thought that the cover will defuse the LED light too much and that is why I drilled the holes. Perhaps I should take them out and just let them lie inside and see how bright they are then, will let you know.I am not keen on drilling holes in the light cover surely there is enough space inside to fit the LED's?
- Town: PE
- Vehicle: 2700i D/C
- Real Name: Craig
Contact AndyF on the 4x4 community forum he supplies a large range of LED bulbs and products
http://www.4x4community.co.za/forum/sho ... 148&page=2" onclick="window.open(this.href);return false;
http://www.4x4community.co.za/forum/member.php?u=2020" onclick="window.open(this.href);return false;
Unfortunately he has not seen the light and still drives a Land Rover
05 Hilux 2700i D/C Legend 35 4x4
- warrenaken
- Town: JHB
- Real Name: warren
Interior LED Festoon smd fitted.
Got the flat pannel one for 'directional' light, apposed to the one that has led's all the way round
MUCH brighter and whiter
Toyota Hilux KZ-TE
- hentey
- Town: worcester
Warren is that off the shelf available or did you manifacture it yourself?Looks like I should have asked first and then acted.Where did you buy it?Looks like the answer!
- warrenaken
- Town: JHB
- Real Name: warren
Got my sister in the UK to get it, about R11.00
This looks like a worthy "upgrade". Warren, do you have a part number for it, perhaps we can initiate a group buy on this and share the postage. Should fit SFA and IFS, both of which have the short festoon bulb. Not sure what the newer Lux's use.
- warrenaken
- Town: JHB
- Real Name: warren
Hi Eric,
She got them off ebay, Hong Kong by the looks of it.
I ordered the 6LED, but the 8 arrived, slightly too big but fits at a slight angle. I would suggest the 6.
Think the KZTE is a 31mm? will look for the pakage, think i kept it for the old bulb.
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
That will be great.This looks like a worthy "upgrade". Warren, do you have a part number for it, perhaps we can initiate a group buy on this and share the postage. Should fit SFA and IFS, both of which have the short festoon bulb. Not sure what the newer Lux's use.
- GTO
- Town: Fish Hoek
I checked the length it is 31mm and my bulb has blown again :evil:
I see a 31mm is available(expensive for what it is?)
1985 Suzuki DR600S
1985 Suzuki DR600S
Saturday I went to Yebo electronics, bought a few hi-bright white leds, 2 pieces of strip board... and a few 5.5 ohm resistors...
Made a new interior light(4 leds), as well as 2 reverse lights(6 leds/8 leds)... I'll post pics later... the only issue I have is that the led light is sort of stark cold blue white... it looks better when its warmer... I'll probably add a layer of yellow/orange gel filter plastic to warm it up a bit!
Mr B
Mr B
Pehaps ou should add one yellow LED for the tint
Pieter, yes I did think of this option, I'm just not too keen on replacing LEDs... the trackboard 'tracks' are rather thin... it's easy to land up joining 2 tracks with solder... and then it becomes a pain to clean/separate... unless you got one of those solder sucker goodies and a 'third hand' tool...
The guy at Yebo told me it is better to put the LEDs in parrallel with resistors, rather than using 4 in series to get the volts right... hence the use of stripboard and the 5.5 ohm resistor per LED...
Here are the pics...
I'm going to mod/build a new version some time for the reverse lights... 7 white leds and 2 yellows... the present 8 led version is bright enough...
Mr B
Mr B
A close up of the 6 led reverse light version, I made a mistake by soldering the leds flush on the stripboard, making bending the leds to 'spread' the light impossible... this I corrected on the 8 led version...
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Lekker as mens slim is....Well done Mr B
I'll make you some Trevor... and you make me a rear bumper... I'll pay the post for yours... you pay the postage for mine...
Deal?
Deal?
Bretton, the 5.6 Ohm resistor seems to be very small. I don't know what the specs on those LEDs are, but they would probably require a voltage drop of some 10v minimum to be absorbed by the resistor, and there current rating is what, say 30mA? Therefore, 10/.03 = 333 Ohms, which sounds better to me but still a bit on the hairy side. Do you have the specs on the LEDs at all? In practise, I would probably use a 470 - 560 Ohm resistor, but that is for the older type LED, I have not yet looked up the voltage & current requirements of the new super-cooper bright white LEDs but somehow wonder if its rated at such a high voltage that they work with such a small resistor. The colour code of the resistor is green - blue - black - black, isn't it?
- Town: Mokopane
- Vehicle: Hilux 2.7i 4x4 DC
From YeboI have not yet looked up the voltage & current requirements of the new super-cooper bright white LEDs
High brightness white LED in standard 5mm package.
Water clear package. Luminous intensity 10cd typical at IF = 20mA. The cathode is the short lead.
Specifications:-
Luminous Intensity: 7000 - 10000mcd
Viewing Angle: 20°
Chromaticity Coordinates:
X .29
Y .28
Spectrum Radiation Bandwidth: 21 nm
Forward Voltage: 3.0 - 3.6 V
Recommended Working Current: 20mA (at 3.3V)
Thanks Jaco! So allowing for, say, 10.2 voltage drop (13.8 - 3.6) and dividing by .02, we should then use a 510 Ohm resistor, or preferred value of 560 Ohm. Your LEDs are not going to last with 5.6 ohm resistors, Mr. B...
Resistor colour code: green - blue - brown - black will suffice.
- GTO
- Town: Fish Hoek
I went to Yebo Electronics Plumstead yesterday, I ended up buying a Power LED 1W Star type and 470ohm resistor.Sales guy reckoned this one is equivilent of 10 normal LED's.Cost R 38
- LED.jpg (12.67 KiB) Viewed 5315 times
1985 Suzuki DR600S
1985 Suzuki DR600S
Thanks guys... me not being a electronics junkie, I had to take the advice of the electronics guru at Yebo... I told him the supply voltage could be anything for 13.5V to 14.4v... he whipped out a calc and said I need a 560ohm resistor per LED is parallel... and thats exactly what I did... next time I might use a power led as well... only concern I have is it's angle of illumination... as a std. LEDs angle is pretty narrow... it's not too expensive to experiment... thanks Eric, next time I wire up another circuit I'll use your advice!
Perhaps this is a better solution
- Niel
- Real Name: Niel
will post some pics of the one I fitted must say it is impressive
- Niel
- Real Name: Niel
The ones I installed this week. The brightness is awesome in comparison to the old globes.
Those look really cool, where did you get them Niel, and how much moola??
Niel, did you fit both of them? :haha:
- george
- Town: Velddrif
Nieal,waar het jy daai liggie gekry?
- Town: PE
- Real Name: Craig
Andy Imports all those LED productsWolweseun wrote:Contact AndyF on the 4x4 community forum he supplies a large range of LED bulbs and products
- Niel
- Real Name: Niel
I bought it from Andy and he can be contacted on zero 84 5 two 843 six 8. Pls do mention that you are from the hilux forum. Thanks Craig
- Niel
- Real Name: Niel
Pieter, yes one in the car and the other in ther hilux but i will help you if you haak vas :haha:pietpetoors wrote:Niel, did you fit both of them?
OK, I received my dome lights.
I went for the ones with 15 LEDs because the smaller board will fit in most dome lights.
To compensate for the smaller board i opted for the 5mm LEDs instead of the 3mm LEDs most shops sell.
I installed one in the Tazz, it really takes 2 minutes. You remove the globe, replace it with the globe fitting, stick the board to the dome light fitting (it comes with double sided tape on the back), replace the lens cover and you are done.
I added it to the shop at http://www.hilux4x4.co.za/theshop/index ... ucts_id=52 at R60.00 each
I can also think of many other uses for it besides the dome light, If I had this last week i would have rather put this in the canopy's kitchen than the LED strip I used, the square thing would fit better.
Niel pointed out to me that some vehicles have limited space between the globe fitting and cover.
This one did go into the Tazz as a tight fit but the cover still closed properly.
The thickness of the board including the double sided tape is 5mm
- george
- Town: Velddrif
Lyk baie goed Het jy al een in die bakkie gesit?
Ek het mos laas die gewone LEDs in die doppie ingesit en die drade sommer aan die kontakpunte vas soldeer.
Dus kan ek nie nou die lamphouer gebruik nie, ek sal eers daai klomp soldeersel moet gaan afhaal. Sal dit seker later vandag doen.
Om jou idee te gee hoe helder hierdie liggies is, in baie huise het ons mos daardie ingeboude spotlights wat gewoonlik 'n 50w gloeilamp het. Ek het van hulle ook hier wat ek toets wat 18 LED het, die 18 LED skein veel sterker as 'n 50w gloeilamp. 18LED is 2.7 watt. Hierdie dakliggie het 15 LEDs, dit is dus so goed soos jy sit een van daardie 50watt spot lights in jou kar. Die LED se ligverspreiding is net baie beter as die van 'n gewone ou tungsten liggie.
- swartvark
- Town: Gordons Bay
- Real Name: Tiaan
Dit lyk baie goed, Piet.
Swartvark se dakligdop is al wit en gekraak, so ek sal maar 'n nuwe dop ook moet kry. Ek wonder of Midas dit sal aanhou.
MUD........GLORIOUS MUD!!!!!
NEED A CAR?
talk2tiaan@gmail.com
0829294028
- Niel
- Real Name: Niel
Daai LED werk vlippen goed
- george
- Town: Velddrif
thanx for mine.They work great Easy to install
Het hy maklik gepas George
- george
- Town: Velddrif
Daar is baie spasie.Ek het hom net nie lekker geplak gekry nie.Daar is nie baie kontak area nie.pietpetoors wrote:Het hy maklik gepas George
- george
- Town: Velddrif
Ek het myne ook dwars gedraa nou sit hy lekker. Het 'n blond oomblik gehad :shifty:george wrote:Daar is baie spasie.Ek het hom net nie lekker geplak gekry nie.Daar is nie baie kontak area nie.pietpetoors wrote:Het hy maklik gepas George
Nou weer gekyk dit werk rerig goed.Dit gaan lekker in die karavaan ook werk
Maar hoe gaan jy jou bakkie in die karavaan kry?! :wth:george wrote:Ek het myne ook dwars gedraa nou sit hy lekker. Het 'n blond oomblik gehad :shifty:george wrote:Daar is baie spasie.Ek het hom net nie lekker geplak gekry nie.Daar is nie baie kontak area nie.pietpetoors wrote:Het hy maklik gepas George
- george
- Town: Velddrif
Met moeiteMaar hoe gaan jy jou bakkie in die karavaan kry?!
Solank dit nie met geweld is niegeorge wrote:Met moeiteMaar hoe gaan jy jou bakkie in die karavaan kry?!
