Hi guys
I know these guys level out the front on the Vigo shape, but I do recall a thread where it was mentioned that they are also in a position to level out a KZ-TE, has anyone tried them out yet and are you satisfied? Your inputs will be appreciated as usual.
Regards,
Level it out
- Donkey
- Club VHF Licence: X122
Level it out
Tumelo Maketekete
Re: Level it out
Hi Tumelo, have you had the tortion bars adjusted?
- Donkey
Re: Level it out
Hi Mark
No, not yet. Is it something I can do myself or do you know someone around Jhb who'd be able to assist? Thanks.
Regards.
Regards.
Tumelo Maketekete
Re: Level it out
Hi Tumelu, any tyre fitment centre with allignment equipment will be able to do it for you
Just speak to the chap doing the allingment before you pull up the ramp what you want and make sure he can do it. Then have the allignment done again!
- Donkey
Re: Level it out
Thank you Mark will do so next alignment, are you in a position to describe what they look like, have no idea.
Tumelo Maketekete
Re: Level it out
Tortion bars 'two' are on the inside of your front wheels (one on either side) Bars with a bolt on, but you need to know what you are doing otherwise you will mess it up doing it youself. Bush trick for temp correction, but otherwise let the guys that know rather do it :wink2:
- Donkey
Re: Level it out
Thanks, will let the experts check them out.
Tumelo Maketekete
