2002 IFS Ball Joint Lift
peetvdw
Vehicle: Jeep
Real Name: Peet
Post by peetvdw »
The best decision for my Hilux.
I started of with the cheap lift option for my Hilux a few years back... putting some more tension on the tortion bar. Really bad decision, take most of you flex away, makes your Hilux jump around like a little rabbit and causes a very hard ride.
Now I have ball joint spacers from Crawler http://www.4crawler.com" onclick="window.open(this.href);return false; and loving it.
With all my modification to a standard Hilux suspension my lux is starting to flex nicely for a IFS that is.
My list of mods:
• 33" Hankook Tyres
• 50mm Body Lift
• Removed Load Leafs
• 35mm Ball Joint Spacers
Peet van der Walt
http://www.youtube.com/user/MonsterHilux" onclick="window.open(this.href);return false;
mtbbiker
Vehicle: Toyota hilux 2700i 4X4DC
Real Name: Eugene
Club VHF Licence: B199
Re: 2002 IFS Ball Joint Lift
Post by mtbbiker »
peetvdw wrote:The best decision for my Hilux.
My list of mods:
• 33" Hankook Tyres
• 50mm Body Lift
Hi Sorry for the Hi-jack. I see you have done the Diff breather mod. What did you use for the connector to the diff ? Did you do the same (Use the same connector) for the front diff ? Do you have pictures of the front ?
Eugene
peetvdw
Vehicle: Jeep
Real Name: Peet
Post by peetvdw »
No problem,
I used a small gas pipe connector (I'm sure the front is the same). Can't remember the exact size. The connector is a straight fit which I sealed with thread tape. I sealed the other end of the pipe with a oil sponge filter.
I didn't do the front. It is only required to do the front when you do long distances in 4WD H.
Hope this helps.
Peet van der Walt
Piesang
Town: Grabouw
Vehicle: '99 Hilux SRX d/c 4x4
Real Name: Pieter Pieterse
Post by Piesang »
Peet ek het die selfde padjie as jy geloop. Eers die t/barr's en toe die ball joint lifts en ja dit het 'n baie groog verskil gebring.
