hi guys
my 99 2.7 4x4 has abs ... but does not seem to work at all
the stealers say it is the actuator that needs to be replaced.
does anyone know if it can be fixed or if there is a replacement part available that is good value for money?
merry x mas
ruhan
abs not working
- Town: polokwane
- Vehicle: hilux
- Real Name: ruhan
abs not working
as dit nie n toyota is nie........... dan is ek nie verslaaf nie
- Polarbear2008
- Real Name: Theunis
- Club VHF Licence: X49
Re: abs not working
Ruhan
by "actuator" do they mean the ABS pump?
Here is a link to a 2.7 that is being stripped for spares. (I know it is in Cape Town, but they are not available every day!) http://capetown.gumtree.co.za/c-Cars-Ve ... Z239969339" onclick="window.open(this.href);return false;
All the best and let us know if you get it fixed.
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
- Bushwacker
- Town: Vryheid Natal
- Real Name: Piet
Re: abs not working
I removed the ABS out of my 2003 (now lexus) KZ (SFA concersions fault)
What's it worth?
What's it worth?
Re: abs not working
Allow me to recommend the Abflex 2
You can have Perfect Abs in just 3 minutes a day with the Ab Flex II.
Just 3 minutes a day equals 200 sit-ups!
You´ll get 6 different abs exercises with this one machine, which has direct resistance that immediately isolates the abs!
Abflex II isolates and works your abs in a very effective way!
Re: abs not working
Thys,
It's my guess that you need less water with your Bell's...
Re: abs not working
That mmight be so Uncle Eric, but you should see my abs...Family_Dog wrote:Thys,
- Town: polokwane
- Vehicle: hilux
- Real Name: ruhan
Re: abs not working
hi guys
sorry for not responding earlier.... ek raak partykeer nogal besig ....
but thanks for the replies...
i do mean the abs pump ... is what i am looking for.. unfotunatly i have not got a clue of price...
piet if you want to sell yours .....
thanx
thanx
- Town: Randburg
- Vehicle: KZTE
- Real Name: Donovan
Re: abs not working
Hi Mandevu
I had a similar problem with my KZTE ABS pump, which I think is similar to the 2.7. The actuators and controller piggyback on the pump itself.
A new one was about R14k and I couldn't get a refurb / secondhand unit in the country.
Eventually I found a refurb unit on E-bay and had it sent in for less than R3k.
After I had it fitted and checked the dealer stold me I then had to replace all the sensors as they were not working. Two weeks later I found out the one sensor cable was not properly connected.
I would recommend the e-bay route as the UK and USA had several units available.
