Diff breathers
george
Vehicle: Prado 90 VX 3.4 V6
Club VHF Licence: HC107
Wed Feb 02, 2011 1:49 pm
I still need to extend my diff breathers on the 2.7.
I see on the 4x4com site they talk about a 1/8 BSP fitting you can use.
What did you guys use.
Maddoglips
Town: P.E.
Vehicle: Raider 2.2 4x4; Mikem 50mm raised suspension, long range tank, Monroe gasses all round.
Real Name: Zane
Wed Feb 02, 2011 1:54 pm
George Check the shop, I think Cassie sells Kits for the diffs?
Good luck
Wed Feb 02, 2011 2:29 pm
Maddoglips wrote:George Check the shop, I think Cassie sells Kits for the diffs?
Good luck
George, Zane is correct. I sell these kits. They use a 1/8 BSP Quick Connect Elbow on one side and a quick connect with brass filter on the other.
Similar to this
Wed Feb 02, 2011 2:31 pm
Cas, kan jy vir die D4D ook kry?
george
Wed Feb 02, 2011 2:35 pm
Cassie ek soek 'n stel :thumbup:
Wed Feb 02, 2011 2:36 pm
Sover ek weet is hulle almal dieselfde size. Daai wat ek het pas op die SFA en IFS. Net nie seker of die op die Vigo ook pas nie maar kan nie dink dat hulle daai fitting size sou verander het nie
Hi-Hilux
Town: Tsumeb
Real Name: Trevor
Wed Feb 02, 2011 2:39 pm
waar is die shop? Cassie wat kos my SFA se kit? Voor en agter?
Wed Feb 02, 2011 2:44 pm
Vir 'n SFA het jy twee sets nodig en hulle prys R180 each
Royco
Town: Stellenbosch
Real Name: Roy
Club VHF Licence: X88
Wed Feb 02, 2011 2:49 pm
Vir die Vigo het ek ook seker 2 stelle nodig? :wth:
Sal jy vir my die "shop" se bank details PM asb?
Tx
Image Image Image Image
Wed Feb 02, 2011 2:53 pm
Royco wrote:Vir die Vigo het ek ook seker 2 stelle nodig? :wth:
Tx
Ek dink jy het net een stel nodig.
Wed Feb 02, 2011 3:01 pm
:shock: :shock: :shock:
Okay... so smaak vir my die IFS het ook twee stelle nodig want die differential is mos nie deel van die ratkas nie. Hy is net bietjie beter weg gesteek.
george
Wed Feb 02, 2011 3:08 pm
Dan moet ek twee vat.Wonder of 'n mens by hom kan uitkom
Royco
Town: Stellenbosch
Real Name: Roy
Wed Feb 02, 2011 3:10 pm
Ek sal vanaand onder gaan kyk... nie seker vir wat ek moet soek nie...
Ek sal probeer om foto's te neem - muskien help dit :crazy:
But I've read a lot (on this forum) that these breather are very important if the diffs get in water.
((Just hope it's not too late!!)) I crossed the Eerster river a few time last winter :alvarin:
Hi-Hilux
Town: Tsumeb
Real Name: Trevor
Wed Feb 02, 2011 3:16 pm
mit Rabbat bitte
george
Wed Feb 02, 2011 3:19 pm
Hi-Hilux wrote:mit Rabbat bitte
Ja,bitte
george wrote:Dan moet ek twee vat.Wonder of 'n mens by hom kan uitkom
Ek dink dit gaan moeiliker wees om te vit as die SFA sin. Jy gaan heel waarskynlik die voorste engine cover moet afhaal ens.
Royco wrote:Ek sal vanaand onder gaan kyk... nie seker vir wat ek moet soek nie...
Hulle is baie belangrik. Jy behoort fine te wees as die water nooit hoër as die helfde van jou wiel was nie. Die ander manier om dit te minimaliseer is om baie stadig in die water in te ry. Die probleem is wanneer die diff warm is en jy ry in die water in dan koel hy skielik af en suig dan lug. So as jy stadig gery het en jou diff het klaar af gekoel was die druk binne en buite die diff dieselfde gewees en sou die water nie sommer in loop nie.
Maar dit is maar altyd beter om die breather te skyf want R180 versus R4000 na R5000 ... no brainer
Bazzer
Vehicle: Toyota Hilux 2700i DC 4x4, Toyota Hilux 3.0D4D 4x4 Auto
Wed Feb 02, 2011 3:35 pm
Cassie
So for the IFS (2.7) do you need 2 sets or just one? Where do I place my order ?
Wed Feb 02, 2011 3:39 pm
Cassie jy maak die ouens deurmekaar............... :roll: :roll: :roll:
1 Set per vehicle :thumbup:
Hi-Hilux
Town: Tsumeb
Real Name: Trevor
Wed Feb 02, 2011 3:50 pm
nei man! 1stel het dit dan vir voor en agter in? So dis 360 vir n stel? Of wat?
Wed Feb 02, 2011 3:54 pm
Hi-Hilux wrote:nei man! 1stel het dit dan vir voor en agter in? So dis 360 vir n stel? Of wat?
Wed Feb 02, 2011 4:03 pm
Okay lets clarify.... a set is made up of 1 connector to connect to the diff and one connector to connect with filter on the other end of the pipe. The set includes cable ties, cable tie shoes, and binding spur to protect the tube. So in general you will need two sets per vehicle.
I have some in stock (not sure of the qty). I can get some reasonably quick if you want more. So if you are interested place your name here with the qty you would like.
George x2
Royco x2
Bazzer x2
Hi-Hilux
Town: Tsumeb
Real Name: Trevor
Wed Feb 02, 2011 4:05 pm
en sonder die cable ties? Ek het genoeg cable ties
Wed Feb 02, 2011 4:07 pm
Hi-Hilux wrote:en sonder die cable ties? Ek het genoeg cable ties
R175
Hi-Hilux
Town: Tsumeb
Real Name: Trevor
Wed Feb 02, 2011 4:15 pm
Nou is dit n bargain! Sal jou pm want Mark moet vir my dalk Keanu se persent stuur dan doen ons alles gelyk
Wed Feb 02, 2011 4:21 pm
Hi-Hilux wrote:Nou is dit n bargain! Sal jou pm want Mark moet vir my dalk Keanu se persent stuur dan doen ons alles gelyk
:thumbup: :thumbup: :thumbup:
warrenaken
Town: JHB
Vehicle: 3.0 KZ-TE 4x4
Real Name: warren
Club VHF Licence: X04
Wed Feb 02, 2011 5:43 pm
Someone sent me a thread off the 4xForum from 2006, had a photo guide of how to do the dif breathers. The pdf id about 500k so wont let me upload here, but if you going to do the mod, i will send it to you.
Toyota Hilux KZ-TE
Wed Feb 02, 2011 7:44 pm
Okay... I have stock to make up 7 Kits...
Derren
Vehicle: 2001 Hilux KZ-TE D/C
Real Name: Derren
Wed Feb 02, 2011 8:48 pm
I would like 2 please.
Toyota Hilux D/C KZ-TE 2001
TJM Bumper, TJM XGS Suspension (with Bilstein shocks), Gomad Alu-Canopy, Snorkel, Chip & Intercooler, Dual Battery
Hyundai ix35 2.0 2011
Four Wheel Drive Club - Western Cape
Hilux4x4.co.za Club
JohanM
Town: Parys
Vehicle: Prado 120 4.0 V6
Club VHF Licence: X45
Thu Feb 03, 2011 7:49 am
Cassie Ek wil ook he asb..
George x2
Royco x2
Bazzer x2
JohanM x2
Gunta
Real Name: Mark
Thu Feb 03, 2011 8:25 am
warrenaken wrote:Someone sent me a thread off the 4xForum from 2006, had a photo guide of how to do the dif breathers. The pdf id about 500k so wont let me upload here, but if you going to do the mod, i will send it to you.
Warren, can you send it to me please. mark@tasselberry.co.za
Stef
Vehicle: '98 LTD
Real Name: Stefan
Club VHF Licence: X107
Thu Feb 03, 2011 8:50 am
Baie waar, maar die standaard breather het 'n proppie wat kan op & af beweeg (dis nou op SFA, nie seker oor ander), so teoreties hoort die doppie vas te suig as die diff te vinnig afkoel en dus water uit te hou.
Natuurlik is voorkomende matreels beter.
Hilux01
Town: Secunda
Vehicle: Toyota Hilux 3.0D4-D dc 4x4
Real Name: Henk
Club VHF Licence: X85
Mon Feb 07, 2011 9:02 am
Cassie kan ek ook vir die KZ-TE n stel by jou kry? (of ek reken as ek so lees is dit 2 stelle :taunt: )
R360 hoe gemaak met betalings?
2013 Toyota Hilux 3.0D4-D dc 4x4
Bush Lapa Miskruier 810
Gerbers Alu Canopy
ORRA Call Sign: X85
Mon Feb 07, 2011 10:47 pm
Stef, that's the intention of that little valve, but they get dirty and don't seal properly. Then if it does seal as it should and your shaft seals (pinion and half shafts) are weak, it will suck water in there if the vacuum created is at all significant. I would rather fit high level breathers (to bonnet height against the firewall) with fuel filters on the end for 'free flow' of air. Just a thought. ;-)
Dingo
Real Name: Scott
Tue Feb 08, 2011 7:44 am
Morning Guys
I extended the breathers the other day on my SFA
Went to the local hardware and got an adaptor ( I think a 1/8" ) that fitted into the diff breather hole and another adaptor (I think 3/8") that had a 10mm tube on the one end. Then went to the local spares shop and bought some 10mm rubber hose.
The adaptor fitted perfectly and I just clamped the hose onto the 10mm tube adaptor and to the original breather on the other end of the hose.
The front I ran up to next to the brake booster and the rear I ran up to where the load valve sits. The rear one I did a couple of turns in the pipe and angled the hose downwards so as not to let water sit in the pipe.
Total cost was;
adaptors = 2 x R17
10mm tube adaptor = 2 x R12
3m 10mm hose = R54
hose clamps = had at home
labour to do job = 3 beers :thumbup:
Stef
Vehicle: '98 LTD
Real Name: Stefan
Tue Feb 08, 2011 7:51 am
I hear you M8...Fortunately the diffs were rather "cold" during the crossings I've done and I checked the valves :silent: Like I said prevention is better, so the plan is to check the diff oil for water before even driving it again and to fit the extended breathers just to be safe :thumbup: Currently trying to source 1/8 BSP nipples for the job (money is tight this month :blackeye: )
Tue Feb 08, 2011 8:16 am
You could also try the suppliers of LPG and LPG equipment. AFAIK they should have that swage nipple. ;-)
Tue Feb 08, 2011 8:36 am
You can also buy the parts from Toyota.
Breather Plug (part #90930-03136)
Union fitting (part #90404-51319)
And some fuel hose and clamps and Bob's your uncle
Stef
Vehicle: '98 LTD
Real Name: Stefan
Tue Feb 08, 2011 12:39 pm
Tx Cassie :thumbup:
Haven't searched too far & wide yet, had the flu for the last week or so, put a much higher premium on sleep. Thought I'd try the pneumatic places first, I really like those connectors where you just stick the hose in & tighten the nut, just looks cooler than clamps :twisted: :lol:
I see RS compomenents also have some @ R20 for packet of 5, but the 1/8 sizes are mostly quick couples it seems, will have to do the travelling bit.
the BuTch3R
Vehicle: '89 Hilux SFA - SOLD; '95 Hilux - STOLEN; '67 Series 2A Land Rover; 3.5 V6 Pajero; 120 Prado VX 4.0
Real Name: Shaun
Tue Feb 08, 2011 12:46 pm
Dingo wrote:Morning Guys
Total cost was;
adaptors = 2 x R17
3m 10mm hose = R54
How about a few pictures there Scott ? :thumbup:
Dingo
Real Name: Scott
Tue Feb 08, 2011 1:01 pm
Hi Shaun
The bakkie has gone in for bearing and seal kit on the front diff, so unfortunately it's not with me.
I'm getting it back towards the end of the week and will take pics for you then.
Gunta
Real Name: Mark
Tue Feb 08, 2011 2:46 pm
Why didn't you attempt to do the seals yourself. There are some nice manuals on how to do it. How much did they charge you?
Dingo
Real Name: Scott
Tue Feb 08, 2011 3:59 pm
Hi Mark
Did think about it, but time is a problem and I wasn't too comfortable doing the inner oil seal behind the pivot knuckle ( whatever it's called ). Normal wheel bearings and seals I would've done.
Louis from 4x4 MegaWorld is doing it and charging me R 2100 incl parts. He is also doing a few other bits and pieces, I felt that he was more knowledgable than me and folks on the forum only seem to have had good service from him.
Royco
Town: Stellenbosch
Real Name: Roy
Wed Feb 16, 2011 8:16 am
Thanks Cassie. Got my breathers :yahoo:
Now to find the time to fit them :think:
Wed Feb 16, 2011 8:40 am
Royco wrote:Thanks Cassie. Got my breathers :yahoo:
Stef
Vehicle: '98 LTD
Real Name: Stefan
Fri Mar 04, 2011 12:29 pm
Couldn't find the breather plug from the stealers, no stock....
Found a few pneumatic places that could supply, hopefully I'll make it time this afternoon to check one of them out that actually has stock; fittings tubing etc.
Is there anyone that still needs breathers? Maybe I could sommer buy enough for a few sets...
Gunta
Real Name: Mark
Fri Mar 04, 2011 2:30 pm
I need one for the front. :thumbup:
Stef
Vehicle: '98 LTD
Real Name: Stefan
Tue Mar 08, 2011 10:55 pm
Managed to swing by the place on my way back to Pta 2day..
Bought the last 8mm one he had in stock (so much for "i have stock"), can get more if needed. Unless of course you prefer 10mm tubing (outer dia.); there is stock of the 10mm fittings (bit bulky though, 1/8th BSP thread with this huge brass head). Tubing a bit expensive @ R10/m, want to see what hoses Autozone have & if it will work with the push on fitting, but that will probably be around R6 - R7 per metre anyway
Tue Mar 08, 2011 11:15 pm
Stef, this is a standard size nipple (8mm) used in the LPG appliance field. Those guys should have stock, give them a try. ;-)
Stef
Vehicle: '98 LTD
Real Name: Stefan
Tue Mar 08, 2011 11:35 pm
Mud Dog wrote:Stef, this is a standard size nipple (8mm) used in the LPG appliance field. Those guys should have stock, give them a try. ;-)
Been to a few in the area, but no one had in a 1/8" & asking for BSP makes them frown somewhat :mrgreen:
Besides, how purdy is this? :thumbup:
Over engineering I suppose, but just looks so much more like it was factory fitted... :angel:
Gunta
Real Name: Mark
Wed Mar 09, 2011 7:19 am
will they be getting more stock?
Stef
Vehicle: '98 LTD
Real Name: Stefan
Wed Mar 09, 2011 9:30 am
Asked the same question; oke doesn't seem keen to keep large stock. But if I need some he'll arrange to get stock in.
Bit of a schlep but his prices on fittings are extremely good compared to other suppliers, it's the pneumatic tubing that's expensive...everywhere.
I'm looking to put some kits together if there is a demand, possibly around R300 for a full SFA kit (both diffs), cheaper if I could get alternative tubing and buy fittings in bulk. Will start a new thread once I do
Wed Mar 09, 2011 7:26 pm
I've still got to the same thing to this 'new' bakkie .... had to drain both diffs and replace the oil because both were contaminated with water. But I prefer, and will use a swage nipple fitting so that I am no tied down to pneumatic tubing. The ordinary rubber fuel hose is more flexible (and cheaper). ;-)
Stef
Vehicle: '98 LTD
Real Name: Stefan
Wed Mar 09, 2011 10:56 pm
Different strokes for different folks! :mrgreen:
Had a look at the GAV range of fittings 2day at Builders WH...8mm nipple = R18 and a reducer to 1/8" = R24 thus a total of R42, times 2 plus clamps...the pneumatic ones are normally around R30 each.
Fuel hose around R7 per meter vs R10/m for pneumatic tubing, R13-R16 at some other places,at worst a R63 difference (assuming 7m of tubing), R35 if one takes the saving of the fittings & clamps into account...
defintely pneumatic for me... :wink2:
Wed Mar 09, 2011 11:23 pm
And what are you doing with the ends of your breather pipes so that they don't get dirt / water in there?
What I did before was to fit a fuel filter to each breather end, bending the pipe so that the filter faces down and not up. If you do get water up to that level for some crazy reason, it won't enter the pipes .... at worst just a few drops will get into the filter but will be expelled again next time there is air expansion in the system (when the diffs warm up again). Works perfectly without any need for maintenance of any kind ... ever. Not sure if you can push pneumatic tubing over the nipple of a fuel filter, or if you can get a sharp enough bend to look neat without using elbow joints. :think:
Tjokkie
Town: Heidelberg GP
Vehicle: 2011 Hilux D4D D/C 4x4 (no mods...yet), Hilux 3.0 KZTE D/C 4x4 with minor mods
Real Name: Rikus
Thu Mar 10, 2011 8:19 am
1/8 BSP is a fairly common hydraulic thread.
If you guys are really wanting to go all the way, you may also try the racing style fittings (anodized alluminium).
Aeroquip agent in Pta (Hydraquip) and Germiston (Rudmans Hydraulic) used to stock them.
Stef
Vehicle: '98 LTD
Real Name: Stefan
Thu Mar 10, 2011 8:29 am
Still working on that :blushing: ...want to use a mountable Y-piece/ T-piece to accept the tubes from the diffs & fit a filter on the other end.
The proper brass filter is around R30 and it's plastic counterpart R10-R15 depending on the size, neither one waterproof of course. Pneumatic tube won't fit over the fuel filter but with 8mm outer dia. one can join the two with a piece of fuel hose, should you really want to.
Whether your filter points up/down is not as critical as the highest point of your line as water will push up the tube to match the level outside, but even that could be overcome by just coiling the tube twice or so close to the diff IMO. :think:
I suppose one could extend the line after the T and push the pneumatic filter (small in Dia) up the snorkel, but a bit of an overkill I think...I'm just going to mount as far up the firewall as possible. :thumbup:
Tjokkie wrote:1/8 BSP is a fairly common hydraulic thread.
Right on Rikus, haven't tried Aeroquip yet...
Thu Mar 10, 2011 8:49 am
I never tested it at the time, but I reckon that by the time the water reaches the filters the diff will have cooled down considerably and any suction at the filter from contracting air volume will be minimal. The point of mounting the filter facing down is that the filter would have to fill up first before water enters the pipe. This allows for a larger volume of water to be taken up without any problems. Even external water pressure won't push up very far if the filters become submerged since there will be back pressure from the air volume, and of course the external pressure would only be slight. :winkx:
Stef
Vehicle: '98 LTD
Real Name: Stefan
Thu Mar 10, 2011 10:28 am
My thoughts exactly :wink2: ...and without any other vent in the line it would be really difficult for water to enter anyway, especially on a small dia. tube
Only benefit of the upside down fuel filter would be the added volume then...
So I guess 6 of one and half a dozen of the other, fuel filter volume or a few extra coils in the tube :mrgreen: really a matter of preference?
Thu Mar 10, 2011 11:08 am
:lol: :lol: :lol: You're stubborn like me! :lol: :lol:
I don't necessarily think so, Stef ..... lets for argument's sake say that you get into deep water quickly and the breather ends are submerged before the diff has time to cool down sufficiently and it manages to suck up a full filter volume. How many coils of narrow diameter tubing would be required to make up the same volume so as to avoid water getting to the point that it starts running back down the tubes to the diffs? Then when the diff heats up again, with a filter facing down all the water will be dispelled, whereas with coils how much stays behind in the troughs of the coils? ..... of the water that stays behind, how much will get into the pipe to the diffs with normal expansion and contraction from daily use afterwards. :think:
It's a small issue because how often will you ever go that deep, if ever, but I feel that if you're going that far with the installation you might as well get the best benefit. :D: ;-)
Stef
Vehicle: '98 LTD
Real Name: Stefan
Thu Mar 10, 2011 12:16 pm
Mud Dog wrote::lol: :lol: :lol: You're stubborn like me! :lol: :lol:
:naah: I think you & my wife have the same star sign :lol: besides, work is boring...
Mud Dog wrote: How many coils of narrow diameter tubing would be required to make up the same volume
On 6mm inner dia vs 50mm about 69,4mm for every mm of the filter's length :twisted: (I calculated) but how much volume does one need?
Mud Dog wrote:Then when the diff heats up again, with a filter facing down all the water will be dispelled, whereas with coils how much stays behind in the troughs of the coils? ..... of the water that stays behind, how much will get into the pipe to the diffs with normal expansion and contraction from daily use afterwards. :think:
That's a good question... but I guess with the push on connectors & transparent tube it is a 5min job to inspect & drain the water. :think:
