rear diff
T Giles
Town: Letterkenny
Vehicle: Toyota hilux
Real Name: Turlough
Thu Dec 08, 2011 3:48 pm
hi all,
T Giles here. I am a new member.
I am on my 2nd Toyota hilux ,had a 2000 single cab 4 the last 3years now i have a 2002 hilux crew cab 2.5 D4D, I was very happy with my 2000 hilux and even happier with my 2002 hilux. but have a prob my rear diff will not lock i can hear the moter turn when i push the diff lock button but dose not lock. any help would b appreciated , T Giles
Fri Dec 09, 2011 12:26 am
Did this problem just start or has it been like that since you bought the vehicle? .... or maybe after work was done on the diff?
I ask because if you can hear the motor then you don't have an electrical problem ... it will be mechanical. Here I see one of two probabilities .... if it's just started then it's possible that the worm gear is stripped, .... if it's always been like that since you had it or after someone has worked on it, then it's possibly the above by co-incidence or the actuator is not engaging the diff lock 'fork' in the diff.
Either way, you would have to disconnect and remove the actuator motor, clean and inspect it. Sometimes the problem is nothing more than an accumulation of muck inside.
Best of luck that it's nothing serious. ;-)
