KZ-TE Intercooler and Chip
- Shimano
- Town: Strand Cape Town
- Vehicle: Hilux 4.0 V6 4x4
- Real Name: Wynand
- Club VHF Licence: HC125
Hi,
I am a new member and would like to know if anyone can give me advice on the Steves Auto Clinic intercooler and chip conversion on the KZ-TE.
Is it worth the money and is the difference in power and fuel consuption noticable?
Toyota Hilux 4.0 V6 4x4
- Niel
- Real Name: Niel
Re: KZ-TE Intercooler and Chip
Wynand, welcome to the forum and I can only add the following.
I have not done this myself but I have spoken to a number of chaps that did and they all say it is worth while but I never asked the fuel consumption question. I am sure she will be a bit lighter on fuel as well.
The only thing that bothers me with the intercooler is the placement below the motor. You effectively loose 1.5 cm clearance on the approach. They do fit a thick bash plate but that said I still have my concerns when regularly knocking the bash plate and the damage on the longer term.
Then there is the other school of thought - leave it motor alone. Heard that a few times. Hope this helps.
Hi Shimano,
Welcome to the Forum!
Can't help you with the SAC thing, but Niel is our resident KZ-TE Diesel Expert. I'm sure others will chip in with their advice as well.
- Niel
- Real Name: Niel
You say the kindest things, thanks EricFamily_BullDog wrote:but Niel is our resident KZ-TE Diesel Expert.
Wynand, herewith the brochure from SAC.
- Shimano
- Real Name: Wynand
Thank you for all the info Niel.
Much appreciated.
Much appreciated.
Niel It was meant as an insult actually.Niel wrote:You say the kindest things, thanks EricFamily_BullDog wrote:but Niel is our resident KZ-TE Diesel Expert.
- Niel
- Real Name: Niel
:roll: :roll: :roll: :roll: Bennie Bennie
- Rampie
- Vehicle: '10 Pajero Sport
- Real Name: Andre
SAC Vanderbijlpark have done 2 of my vehicles, a 2002 KB250 d/c and the current Hilux 2.5D4D. Excellent value for money, I'm just waiting for the ship to come in, then they'll do Swambo's Vito also.
I have more than 100 000 happy km's with my intercool and chip. Just lots of joy out of this truck.
Fuel comsumption is in the 8.5km/l region, although I heard guys claiming 10....
The new housing for the intercooler is much thicker and stronger than the paper thin stock bashplate.
If you've got the bucks, sommer also fit an EGT gauge.
- Shimano
- Real Name: Wynand
I have had the conversion done and so far I am impressed. Gained 19KW and 69NM according to the Dyno results on the wheels. Fuel consumption is at 9.3L/100Km - a huge improvement.
- JohanM
- Town: Meyerton
- Vehicle: Prado 120 4.0 V6
- Club VHF Licence: HC126
The conversion is a very simple process and can actually done by yourself if you feel like it, but I know SAC doen not warrant any fitments done not by them.
The conversion is a very good one and does add a lot off more driveability to the vehicle and should be lighter on diesel if you keep the same driving style afterwards, and not use the extra power all the time.
Regarding the chip, when the chip is fitted, make sure that you get a Bridge plug also for it. have had scenarois where the chip actually has failed and then KZ-TE wont start. The bridge plug bypasses the chip and the tuned settings in the ECU, so it reverts it back to STD.
I have done in the 3 years that I have been at SAC Vanderbiljpark many conversions and almost everybody were really happy with the result.
The only thing that needs to be kept in mind is that due to the position that the intercooler sits, I reccommend that it be cleaned on a regular basis as to avoid grass and mud from blocking the core of the intercooler which in turn leads to "loss of power" due to higher temperature's on the charge air going into the engine.
- Niel
- Real Name: Niel
Johan, the position of the intercooler bothers me as well for the very same raeson and damaging it in off road situations. Where els can the inter cooler be fitted. Also prevention additional turbo lag?JohanM wrote:The only thing that needs to be kept in mind is that due to the position that the intercooler sits, I reccommend that it be cleaned on a regular basis as to avoid grass and mud from blocking the core of the intercooler which in turn leads to "loss of power" due to higher temperature's on the charge air going into the engine.
- JohanM
- Town: Meyerton
Neil,
I know when the Prado KZ-TE conversion were done, we put the intercooler ontop of the engine which was better, but the Bonnet of the prado had already the channeling inside it, so that we just fitted ducts in the grill that channelled the air to the intercooler that was sitting ontop of the engine. There were no outside modifications of the vehicle on the Prado's that we did like on the Hilux. Also the intercooler of the prado was slightly bigger that the KZTE hilux intercooler.
You should be able to fit it to yours as well, but then you will have to have the bonnet modified to fit the D4D scoop ontop so that the intercooler gets the cool air by a panelbeater as you will have to cut the bonnet and seal it to prevent rust.
I think it migght actually look nice on your van, a D4D scoop with the intercooler ontop. Just gives it a more butch look.....
- Town: Polokwane
- Vehicle: 2002 Mitsubishi Colt V8
- Real Name: Jan
Cirrus of Pretoria manufactures an intercooler that is fitted in front of the radiator, it is also available in diy kit form, fitting mine in September (bonus maand). I also do not like the under bumper location of the SAC cooler.
- Buffalo Soldier
- Town: Al Ain
- Vehicle: Nissan Pathfinder
- Real Name: Ockert
If I am not mistaken, someone on this forum had a cooler fitted ontop of the engine, with a scoop (tor vanger). If memory serves me correct, it was from an Isuzi. Could someone please direct me to this thread? I want to fit a cooler, but not in front of the existing radiator. It restricts the airflow, causing the engine to run hotter than usual. I would like to get the details about that installation.
Thanks.
Thanks.
- Niel
- Real Name: Niel
They cost R3900 excl transport from JHBvastrap wrote:Cirrus of Pretoria manufactures an intercooler that is fitted in front of the radiator, it is also available in diy kit form
Apparently Dastek also manufacture intercoolers.
Jan, are you fitting the chip as well? Dastek?
- Gertc
- Vehicle: 3.0L Fortuner
- Real Name: Gert Combrink
- Club VHF Licence: Xray05
what is the size of the inter cooler core used by SAC?
- Vehicle: KZTE
- Real Name: Johann Hechter
I had the intercoller and chip installed on my 2002 KZTE which made the vehicle a pleasure to drive. I was warned by Toyota that I am to pick up problems and shoul remove the chip I did not. Now after 60000km blew a head gasket. The head is still to be removed to establish any further damage to the head.
Any similar experience or comments pls.
- Vehicle: 2002 face lift KZ-TE DC. Mod’s / dual batter - kinda ;) / Active suspension / Intercooler / free flow / ECU Chip / sports flow air filter
- Real Name: Martin
Johann, I fitted mine about 4 years ago and 110 000 km's later still going strong.Johannh wrote:
U just have to clean the intercooler everynow and again. At some stage i would like to move mine to the top with a scoop.
One Africa, One Hilux needed :)
Refer to my post here: viewtopic.php?f=3&t=9829&p=105341#p105341
Dalk mag daar 'n probleem met jou radiator wees en nou word die coller en chip blameer???
- witmamba
- Town: Sasolburg
- Vehicle: D4D 4x4 Lux + D4D 4x4 Tuna
- Real Name: Hans
Hi Manne!
Ek het 'n steve's intercooler en dastek chip te koop vir 'n KZ-TE. Kontak my as daar belangstelling is op o82 4nege2 48o3
Life only starts . . . . where comfortlevels end
- J.C Avis
- Town: Otjiwarongo
- Vehicle: 2002 Toyota Hilux D/c 4x4 3.0 KZ-D-4D. Suspencion lift,160 liter spare tank. Navigator spots. Double battery system. Tour 'trallies'. Spare wheel carrier. Roof rack. Canopy.
- Real Name: Japie
Ek het ñ sac ombouing op my KZ en die bakkie het al 201000 km op,foutloos. Ek wil net graag weet,hy is voor opgewen met sy torcions en wil graag balljoint spacers insit,gaan dit help dat hy sagter ry?? Dan het hy nie meer so erg spanning op die torcions nie?? Help my reg asb. Agter het hy die veer bo oor die as,lekker vir laai,maar ry soos n plank! Ek wil dit uithaal en shackels langer maak,sal dit werk? Ek wil ook graag weet die dikte van die spacer wat gemaklik is en hoe lank kan mens die shackel in mm langer maak. Ek het Brighstones A/T op en op my speedo kry ek 160km/h,is dit normaal vir n geligte bakkie met die tipe bande en sac conversion? Dis 15 duim,265. Ek is nuut op die forum en wil more probeer my bakkie se foto op te laai,maar weet nie waar om te begin nie????
J.C Avis
- Town: Table View - CT
- Vehicle: 4x4 3.0KZ-TE 2002
- Real Name: Lourens
Japie dit is baie interessante vrae wat jy het.
Ek sal graag ook meer wil weet ivm die torsion bars , agter vere , ens , maar ek dink ons gaan nie AL die antwoorde hier kry nie.
Miskien kan jy 'n nuwe OPSKRIF maak en dan hierdie vrae vra.
Jy sal dan die regte mense kry wat daarin belangstel om KZE te lig, ens.
Ek hou ook dop vir antwoorde hier......
Ek het net 1x ekstra agter bladveer in en torsion bars opgestel.Ry lekker sag.. (dit is mos 'n LUX , nie Merc nie.)
- Town: Durbanville
- Real Name: Richard
Morning All!
I also have a question regarding the SAC chips. Anyone have more details on these chips? I have KZTE with SAC chip and intercooler fitted (bought it like that). I get about 7km/l, 8 if I'm lucky. So was suggested to me to take it to SAC for them to check the "settings" on the chip, they might be out.
Anyone know of someone closer to Dville, Bellville, Brackenfell that is able to do these tests as well? Milnerton and arranging transport back and forth is an issue : (
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Hi RichardTsa wrote:Morning All!
You can also try these guys http://www.gandcauto.co.za/frameset.htm
I dont have experience with them,but they do the Dastek thing
- Town: Durbanville
Thanks George
After doing a bit of searching I also saw G&Cauto, Koos Swanepoel Dev and Dynotech.
Between these the prices have ranged from R600 - R1083.
I've had a horrible experience with G&C(to the tune of 16K!!... they couldn't rebuild a 4Y!!), as have many other people, as I found out after my incident! Stay far away!
I've done business with DynoTech, even though you have to wait for an appointment, Isak know his story!
- george
- Town: Velddrif
Thanks B.Aint this forum GREATMr_B wrote:I've had a horrible experience with G&C(to the tune of 16K!!... they couldn't rebuild a 4Y!!), as have many other people, as I found out after my incident! Stay far away!
- muntu
- Vehicle: 2002 Hilux KZTE 4X4 D/C
- Real Name: Martin
Hi,
I bought a 2002 KZTE 4X4 last week. It has 169,000 Km's on it…..It came with that Dastek chip with Intercooler and has cruise control (after mod, sits on top of the gear lever). When I drove it first, I noticed it had a lot of power and low fuel consumption (it also had a small whistling noise). That all changed since yesterday when I noticed it started to have a bit less power and oil stains on the left side of the engine (left, standing in front of the engine).
I took it to a diesel mechanic here in Breedel and he confirmed my fear, the turbo had packed up. He also noticed that the two rubber pipes going to the intercooler were actual water coolant pipes and were the wrong pipes.
He will have my KZ sorted by Friday he says. The vehicle has a traceable Toyota service history up to 135,000 Km's and I just serviced the vehicle myself yesterday, the 170,000 Km's service (requires oil, fuel and air filter to be replaced). Toyota in Dunswart ran a diagnostic on the car and said it has absolutely no problems and all engine parameters were perfect (they did warn me that they would not be able to pick up if the turbo was on its way out.
What would you guys recommend that I do in regards with the service history gap (is there a way I can see what has to be done to the car from 135,000 Km's up to now) and second should I ask the mechanic to disconnect the chip and drive it as a normal vehicle?
Your input much appreciated!
- louis fourie
- Club VHF Licence: X101
Don't take out the chip, and get a 2nd opinion on the turbo. Blew my ECU and "Mechanic" wanted to overhaul the engine, replace the turbo etc. etc. 160 K later standing on 320 K still running strong
- muntu
- Real Name: Martin
Thanks Louis!! When driving with this chip in, what is the best rpm to drive at and shift gears at? I don't want to destroy the engine as this thing seems to have a lot of power. Also do I need to change the oil every 5000 km's instead of 10,000 km's?
- louis fourie
I change oil every 10 000. Revs is not the problem - if you take it too high the truck gets thirsty. EGT (Exhaust gas temp) is the bugger. If it is too high you can crack the head.
